SYSTEM INFORMATION | |
OS type and version | AlmaLinux 9.4 |
Webmin version | 2.111 |
Usermin version | 2.010 |
Virtualmin version | 7.20.1 |
Theme version | 21.10 |
Package updates | All installed packages are up to date |
can any one help me to Installing PHP 7.4 to ( my main PHP is PHP 8.3.9)
dnf module install php:remi-7.4
Last metadata expiration check: 3:16:58 ago on Thu 18 Jul 2024 12:07:12 PM CEST.
Dependencies resolved.
The operation would result in switching of module ‘php’ stream ‘remi-8.3’ to stream ‘remi-7.4’
Error: It is not possible to switch enabled streams of a module unless explicitly enabled via configuration option module_stream_switch.
It is recommended to rather remove all installed content from the module, and reset the module using ‘dnf module reset <module_name>’ command. After you reset the module, you can install the other stream.
