After login, i get into “Post-Installation Wizard”, Thing that I not sure for this is “Primary Nameserver” the default is ‘ontv24.biz’ but my friend put ns1.ontv24.biz
For right now i left it default, can you guys, confirm which one that I need to put in? ontv24.biz OR ns1.ontv24.biz ? (Pic : http://prntscr.com/5j0y9m)
I dont want to running two Droplets for these case.
i just get into VPS after many years with shared hosting, and i see others people have ns1 and ns2.mydomain.com, i think it will be cool if i can have it.
Is this true? i need two VPS for get ns1 and ns2.mydomain.com?
that’s weird because my friend dont tell me about this before.
You don’t need two servers – many folks run DNS on just one system. The ns1 and ns2 names can both point to the same IP address. Or two different IP address on the same server.
That’s not as redundant as two different servers, but for many use cases that’s no problem.
Yup, that’s looking good! That means BIND is listening on your local IP, and your public one.
The next thing to check is to see if a firewall is blocking traffic… what is the output of this command:
iptables -L -n
Also, I wanted to verify – is your domain “ontv24.biz” setup as a Virtual Server on this system currently? And is the “BIND DNS Domain” feature enabled in Edit Virtual Server -> Enabled Features?
Sorry I don’t really understand about “domain “ontv24.biz” setup as a Virtual Server”
I provide domain “ontv24.biz” is only for ns1. ontv24.biz and ns2.ontv24.biz and Address to Virtualmin Panel.
When I was used Sharehosting, I just put ns1 and ns2 in registrar and then add domain in cpanel. But for this case, I get confused, which one I need to put in?, ns1 and ns2.digitalocean.com OR ns1 and ns2.ontv24.biz?
I don’t do anything yet for domain ontv24.biz and “BIND DNS Domain” Configuration.
