I am in big trouble…if you have any idea please assist.
I have been using webmin/virtualmin for a year now and 2 days ago I had an issue on my vps( centos 7) and i had to remove apache and install it back.
The problem I have now is all sites are set as default…meaning they all point to the same address no matter what URL you enter…
Usually i just go to VIRTUALMIN-> SERVER CONFIGURATION-> WEBSITE OPTIONS and I set one website as default…I usually have 2 options yes or no…but now all my websites are set to default with no option to untick yes…I am adding a screenshot to make it clear.
I know it must be something simple…but I am wasting too much time on that and the websites are all down cause they point on the same IP which is the site that was originally set as default before I removed apache…Any help would be appreciated
thanks for the quick reply…
Well when I re-installed apache I just went back to each website options un-ticked apache and save, then ticked it back and saved again…so i think this isn’t an issue…I really don’t want to reinstall the whole thing…I will read the links you sent hopefully I will be able to sort it…thank you…
I guess if I could know where exactly, or what decide if a site is default for the ip or not…I would be able to sort it out
note: further ideas are welcomed guys
