Help Not work Usermin
Virtualmin version 7.30.4
Hello
I can send emails from my Virtualmin server but cannot receive incoming emails. Need help resolving this issue.
|SPF:|PASS
|DKIM:|‘PASS’
|DMARC:|‘PASS’
Please help
Are you with a provider that has a firewall that might be blocking ports? You give us virtually no information that is helpful here.
Hello
@ID10T
I don’t use any other services, only Cloudflare.
Open ports verified
my domain : onesoftpro.com
What do you need to know? Tell me and I will answer you. :rose:
I tried Cloudflare once and it broke my mail so I dropped it and never looked back. There are posts on here about how to work with email and Cloudflare if you search. Leaving out Cloudflare was a big miss in the original post. :wink:
But the email is direct to the server without using Cloudflare
Direct IP email service with server
Hello
@ID10T
Usermin problem
index does not appear and does not show file size
Either open through the mobile application
All emails appear and receive emails
Can receive and send normal through the phone e-mail program
What is the solution to a problem? usermin
Not only this account all emails not only this
Hello
@ID10T @Joe
We need someone with experience in usermin
To solve the index problem
You might want to change the title to Usermin not working since you are receiving emails. I really can’t help with Usermin though. Sorry.
Hello dear
@ID10T
I received mail through the mobile app
But in Usermin nothing has arrived, there is a problem with Usermin
Subject title has been changed
You maybe proxying the mail server? That won’t work. Is the IP the same as server?
all setting seem fine, not proxy. Seems like a firewall as that IP is different to the mail.onesoftpro.com IP. Very unusual as its normally a block on outbound.
Look like mxtools incorrect info there. I sent a test email to your domain and the greylist has rejected for what time period so you server is recieving.
then did a proper bounce due unknown user.
hello ,
@stefan1959
Email is working and the problem of not showing in usermin has been solved
Messages through this topic
But it only sends, it does not receive mail
Nothing has arrived yet. I have sent many messages to verify.
Not receiving messages
But it appears in messages in the Mail Queue.
webmin > servers > Postfix Mail Server > Mail Queue
Also it did not appear on the phone previously it appeared because it is the same on the site
So to be clear. The mobile client isn’t working?
What do you have on this page?
seem like you alias database hasn’t been built.
Maybe run systemctl status postfix
and see if postfix complains
In Postfix check both Mail Alais and Virtual Domains, does it look ok?
