Hey Guys ! Just Joined VitualMin Community a Few Mins Ago…
So, Well I Need Help of you guys to setup my Website…
Things I Have :
(A) A Linode VPS
(B) A .com Domain From GoDaddy
For Privacy And Security Reasons Please Let The IP of my VPS be 1.2.3.4 and Domain be abc.com
So, I just installed VirtualMin Following The Docs. and as un-expected VirtualMin setup didn’t asked me any questions like FQDN and all…
On the other hand I had already set up-ed 2 NameServers Via My GoDaddy Domain Control Panel Viz., ns1.abc.com and ns2.abc.com both pointing to IP 1.2.3.4
It sounds like you were able to access Virtualmin… but yeah a quick and easy way to access it after initially performing the install, would be to use a URL such as this:
Not everyone has a working FQDN immediately after install, that’s often something that needs to be setup within Virtualmin.
Now that you’re logged into Virtualmin, the next step is to add your domain… you can do that by going into Create Virtual Server, and then inputting your domain name there.
From there, you’d just need to configure DNS.
Where is your DNS hosted for that domain, do you have that setup at a third party currently? If so, then you could just setup the IP addresses for it to point to your Virtualmin server.
Just to get things up and running, you might want to leave it as-is now, and we can always tweak that later.
The next step after completing the post-install wizard would be to go into System Settings -> Re-Check Config, and see if things appear to be working properly.
Okay When I’m trying to do the same you told, It came back with an ‘Primary nameserver cannot be resolved from the rest of the Internet : Host localhost.localdomain not found: 3(NXDOMAIN)’ error…
I’ve checked ‘Skip check for resolvability’
Hope That 'll not mess up anything !
What I would do is to go into System Settings -> Features and Plugins, and there, disable the Mailman feature. Then try running the Re-Check Config again.
