hi i got this error after i install virtualmin in my vps centos server pls help me to fix this error --------->>>>>>>
Virtualmin is configured to setup DNS zones, but this system is not setup to use itself as a DNS server. Either add 127.0.0.1 to the list of DNS servers, or turn off the BIND feature on the module config page.
[color=#FF0000]… your system is not ready for use by Virtualmin.[/color]
"Either add 127.0.0.1 to the list of DNS servers, or turn off the BIND feature on the module config page."
You can find the DNS servers list in Webmin:Networking:Network Configuration:Hostname and DNS Client. Add 127.0.0.1 to the front of the list of DNS servers.
Or, edit /etc/resolv.conf and do the same, by adding a new nameserver entry.
Or, you could use our automated install script which will configure everything for you–you’re going to be spending a lot of time configuring your system if you keep trying to do it manually…and if you don’t know a lot about Linux, it can be an intimidating process.
Our automated install script for Virtualmin GPL is available for CentOS 4 and 5, Debian 4.0, and Ubuntu 8.04LTS (FreeBSD will probably also work, though it’s untested). It is available for a few additional platforms for Virtualmin Professional.
