hi there,
my host blocked my email port because it says there are hundreds of outgoing messages in very short period of time.
i am not much of a technical person so I am still not sure where to start or what is causing the problem. Following is the maillog
http://pastebin.com/zPTZT2w4
Can anyone help me sort out the issue?
Hi!
I’m learning about server administration with virtualmin and maybe we can elucidade some issues
Is it possible that your server is open, as a relay? (Check at http://mxtoolbox.com/ under SMTP test)
Are you using a firewall like CSF?
Is any domain of the email listes in your log hosted on your server?
Regards
Loewenhaupt
