Help Database DBI connect failed
Virtualmin version 7.30.3
Hello my friends
I have a problem every once in a while it stops for example every 24 hours Stop
To solve a problem, I restart the mysql program and it works again
I would like to solve a problem once and for all
Waiting for the solution and your help and thank you
A temporary fix would be adding something like max_connections=250 to /etc/mysql/mariadb.cnf
A better solution would be finding out which program on your system is misbehaving and opening all those connections. See MariaDB max connections - Stack Overflow
