HI, i ahve multiple webs on my server but one when i try to see the log i get this
Error: Plugin load for plugin ‘geoip’ failed with return code: Error: Can’t locate Geo/IP.pm in @INC (@INC contains: /usr/libexec/webmin /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 . /usr/share/awstats/lib /usr/share/view.cgi?config=dnd.arkalseif.infougins) at (eval 2) line 1. Can’t locate Geo/IP/PurePerl.pm in @INC (@INC contains: /usr/libexec/webmin /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 . /usr/share/awstats/lib /usr/share/view.cgi?config=dnd.arkalseif.infougins) at (eval 3) line 1. Error: Need Perl module Geo::IP or Geo::IP::PurePerl
in the config tab i enabled and then disabled geo ip but keeps showing this error.
so i tried to install both, i installed cpan and then i installe Geo::IP::PurePerl and Geo::IP
then i went to the config tab, press the save and regenerate button and keeps showing that error.
the other awstats reports are working.
im using centos 6.9 with virtualmin (all default)
any idea? im lost and try a lot with google links
