Hey guys,
I recently bought a vps with a company called Awardspace. I have spoken to them about this issue for the past few days and unfortunately they have been unable to resolve the problem and are offering to completely whipe the server and start over, which could take days and is something I would very much like to avoid.
Basically, I have in the past few months been learning my way around linux and the webmin framework. I was particularly interested in the postfix application as I was keen to look at a way of building my own interface where my clients can create their own email accounts (instead of using the control panel provided by Awardspace).
Anyways, after running through the documentation and having some real fun with it all, things have suddenly suddenly stopped working. In particular, when emails are sent to the email accounts which were created originally within the Awardspace control panel, they are not received. When emails are sent from these accounts to external servers (yahoo.co.uk for example) they work fine and are recieved at the other end.
Some log file stuff:
When I restart postfix, I get no errors
Jun 19 17:06:50 vps1052 postfix/master[13788]: daemon started -- version 2.7.1, configuration /etc/postfix
However, when an email is sent to one of the email accounts I get these errors
Jun 19 17:07:34 vps1052 postfix/smtpd[13801]: warning: database /etc/aliases.db is older than source file /etc/aliases
Jun 19 17:07:34 vps1052 postfix/smtpd[13801]: connect from nm12-vm0.bullet.mail.ird.yahoo.com[77.238.189.196]
Jun 19 17:07:34 vps1052 postfix/smtpd[13801]: 88FCE48315: client=nm12-vm0.bullet.mail.ird.yahoo.com[77.238.189.196]
Jun 19 17:07:34 vps1052 postfix/cleanup[13806]: 88FCE48315: message-id=<1371658917.84347.YahooMailNeo@web172703.mail.ir2.yahoo.com>
Jun 19 17:07:34 vps1052 postfix/qmgr[13790]: 88FCE48315: from=, size=3216, nrcpt=1 (queue active)
Jun 19 17:07:34 vps1052 postfix/pipe[13807]: 88FCE48315: to=, relay=maildrop, delay=0.23, delays=0.21/0.01/0/0.01, dsn=2.0.0, status=sent (delivered via maildrop service)
Jun 19 17:07:34 vps1052 postfix/qmgr[13790]: 88FCE48315: removed
Jun 19 17:07:34 vps1052 postfix/smtpd[13801]: disconnect from nm12-vm0.bullet.mail.ird.yahoo.com[77.238.189.196]
This is my main.cf file:
# See /usr/share/postfix/main.cf.dist for a commented, more complete version
Debian specific: Specifying a file name will cause the first
line of that file to be used as the name. The Debian default
is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Debian/GNU)
biff = no
appending .domain is the MUA’s job.
append_dot_mydomain = no
Uncomment the next line to generate “delayed mail” warnings
#delay_warning_time = 4h
readme_directory = no
TLS parameters
smtpd_tls_cert_file=/etc/ssl/certs/ssl-cert-snakeoil.pem
smtpd_tls_key_file=/etc/ssl/private/ssl-cert-snakeoil.key
smtpd_use_tls=yes
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
See /usr/share/doc/postfix/TLS_README.gz in the postfix-doc package for
information on enabling SSL in the smtp client.
myhostname = vps1052.vpsunit.com
mydestination = localdomain, localhost, localhost.localdomain, localhost
relayhost =
mynetworks = 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128
mailbox_command = procmail -a “$EXTENSION”
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
virtual_mailbox_domains = hash:/etc/apache2/domains.lst, hash:/etc/apache2/subdomains.lst
virtual_mailbox_base = /var/mail/vhosts
virtual_mailbox_maps = hash:/etc/postfix/vmailbox
virtual_minimum_uid = 100
virtual_uid_maps = static:993
virtual_gid_maps = static:993
virtual_transport = maildrop:
maildrop_destination_recipient_limit = 1
smtpd_sasl_application_name = smtpd
smtpd_sasl_auth_enable = yes
smtp_sasl_security_options = noanonymous
smtpd_sasl_local_domain =
smtpd_sasl_authenticated_header = yes
smtpd_recipient_restrictions = permit_mynetworks,permit_sasl_authenticated,reject_unauth_destination
virtual_alias_domains = hash:/etc/postfix/virtual
And this is my /virtual file
info@pixelpug.co.uk info@pixelpug.co.uk donny@pixelpug.co.uk
If there is anything else that I can provide that may help to resolve this issue please let me know and I will get the information as quickly as possible.
Thanks in advance for any help.
