Hello! I am using Fedora Core 4 x86_64, fully updated. I upgraded webmin to the most recent version, installed the most recent version of virtualmin from the webmin modules box, and get the following error upon testing the virtualmin install:
>The status of your system is being checked to ensure that
>all enabled features are available, that the mail server is
>properly configurated, and that quotas are active …
> Mail server Sendmail is installed and configured.
> Apache is installed.
> In Webalizer’s global configuration, the Webalizer
>incremental file is set to an absolute path. Use the]Webalizer module to change it to a relative path, like just
>webalizer.current.
>… your system is not ready for use by Virtualmin.
sooooo, in Webalizer, I clicked on “Edit Global Options” and found the line for Webalizer Incremental File and it’s already set to:
/var/lib/webalizer/webalizer.current
which seems to be what the config checker wanted. Any ideas on what I’ve done wrong?
Thanks!
Dave
