GPG Key for Debian
I’m upgrading a GPL Virtualmin version to PRO. But in Debian Etch fo using the repository deb http://software.virtualmin.com/ i need the GPG Key.
Where can i find it?
I have this error during the upgrade:
Creating Virtualmin license file …
… done
Updating available packages from APT …
Get:1 http://debian.fastweb.it etch Release.gpg [378B]
Hit http://debian.fastweb.it etch Release
Ign http://debian.fastweb.it etch/main Packages/DiffIndex
Get:2 http://www.backports.org etch-backports Release.gpg [189B]
Hit http://debian.fastweb.it etch/main Packages
Get:3 http://www.backports.org etch-backports Release [43.7kB]
Hit http://www.backports.org etch-backports/main Packages/DiffIndex
Get:4 http://security.debian.org etch/updates Release.gpg [189B]
Hit http://security.debian.org etch/updates Release
Get:5 http://www.backports.org etch-backports/contrib Packages/DiffIndex [2989B]
Hit http://www.backports.org etch-backports/non-free Packages/DiffIndex
Ign http://security.debian.org etch/updates/main Packages/DiffIndex
Hit http://www.backports.org etch-backports/contrib Packages
Ign http://security.debian.org etch/updates/contrib Packages/DiffIndex
Hit http://security.debian.org etch/updates/main Packages
Hit http://security.debian.org etch/updates/contrib Packages
Fetched 46.9kB in 0s (47.4kB/s)
Reading package lists…
… done
Upgrading Virtualmin Debian packages : webmin-virtual-server= webmin-virtual-server-theme webmin
Building dependency tree…
E: Version ‘’ for ‘webmin-virtual-server’ was not found
… done
Some errors occurred while upgrading your system to Virtualmin Pro. Please check the messages above for possible causes.
But i thinks is because i need to add virtualmin repository to source.lists, or no?
i need the GPG Key.
http://software.virtualmin.com/lib/RPM-GPG-KEY-virtualmin
Once downloaded:
apt-key add RPM-GPG-KEY-virtualmin
Yes, I believe this happens if Virtualmin was installed using deb packages, but not using our install script to setup apt and install everything.
If you still have the Upgrade option, try creating a GPL entry in your sources list:
deb http://software.virtualmin.com/gpl/debian/ virtualmin-etch main
I believe the upgrade process will correctly process this line to give it access to the Professional repository. (But you should check to be sure…I’ve also seen an upgrade that left the GPL repo configured, though I believe that bug has been fixed.)
This is probably buggy behavior, though it upgrades are a somewhat hazardous process and we’re trying not to break things that are not configured the way we expect them to be configured, so I’ve asked Jamie to check out this thread.
Tahnk You Joe,
now Virtualmin PRO is working successfully.
Where do i find that !: “GPL entry in your sources list” cause i have the exact same problem but can’t find where to put that entry.
I found it ^^
etc/apt/
