| SYSTEM INFORMATION | |
| OS type and version | Debian Linux 12 |
| Usermin version | 2.203 |
| Virtualmin version | 7.30.8 Pro |
| Theme version | 23.03 |
| Apache version | 2.4.62 |
| Package updates | All installed packages are up to date |
I noticed that gpg compresses backups, and since it can only use one thread it’s very slow. It compresses even tar backups which is really a pain when I just want a quick backup before a major update. I found that there is an option that can be passed to gpg to disable compression or at least set the desired level of compression. These are --compression-algo none and -z 0 respectively.
Can these be added to virtualmin so gpg compression is either optional via toggle switch or tunable through compression levels?
I know this sounds like a first world problem but unencrypted tar backup for all of our virtual servers takes about 1 minute and an encrypted one takes 10, it adds up. Thank you
