Going GaGa (loosing it)
Usermin version 2.102
Virtualmin version 7.20.2
Theme version 21.20.7
Nginx version 1.18.0
I have several VM in different locations.
A simple request came in to move an existing VS from one location to another (along with a sub-server) - nothing too complicated about that.
OK backups done :bell:
but when I come to disable/delete the old VS on the VM - I am presented with this:
when I should have this:
Any suggestions as to where the menu has gone ?
I have tried Webmin -> Refresh Modules
did you check the option to disable the delete option ? There is a setting somewhere, but I have never used it and currently can not find it
edit :slight_smile:
look at New setting in edit virtual server, I see no info on it
Not as far as I know! (I have several disabled domains (Parked) on this VM
so have used it before.)
Was not aware of an “option to disable the menu”
To be more precise "I was not aware of just how catastrophic that option was. I thought It would just bring up a visual warning when trying to disable/delete. Not only no tooltip, but no warning about effects.
Thanks switching it off did the trick :slight_smile:
you wrote this in the thread
I did - but my thoughts / guess fell somewhat short of the real impact. (documentation)
