gnupg-lib ?
I started getting a message from my Cron Deamon…
Every day it is sending me a messages saying…
Use of uninitialized value in pattern match (m//) at /usr/libexec/webmin/webmin/gnupg-lib.pl line 35, line 3.
Use of uninitialized value in pattern match (m//) at /usr/libexec/webmin/webmin/gnupg-lib.pl line 35, line 7.
is the pg for postgress sql… a program that I don’t use… ?
Don Peek
Do you know what cron job is generating that message?
The name of the cron job is usually included in the email subject.
Okay
Thinking it was comming in once a day…
I looked in the /etc/cron.daily but I didn’t see any webmin stuff…
Put did find /etc/webmin/virtual-server/scriptlatest.pl in the subject after looking… .
then it looks like it has been added to the end of my crontab …
23 14 * * * /etc/webmin/virtual-server/scriptlatest.pl
Don
That’s the script that checks for recent updates to the Install Scripts. The “gnupg” that you see in there is a tool used for encryption and checking digital signatures.
However, you shouldn’t be getting an error like that each night… I’ll ask Jamie if he knows what might be causing that error.
Thanks for the info!
Okay, could you post the above into a bug report, using the “Support” link above?
Due to some changes that were made in Webmin, it’s possible notices like you’re seeing could occasionally occur. Jamie fixed the majority of them, but a few slipped through.
If you post the above as a bug report, he’ll be able to get that all fixed up.
Thanks!
