Git Read/Write Access
I am puzzled by the following in the documentation on the Git Repositories feature:
The “Read/write access to repositories field” appears to relate only to subversion repos. The git repos created in a domain do not appear in that field.
Is this just referring to http access via gitweb? If so, would that not be read only?
Is there a way to enable read/write access to a mailbox user, other than to give the individual ssh access to the server?
Further to my last message, I find that after I create an empty Git repository called “Test” on “example.com”, point a browser at “example.com/git/Test.git” , and login in with the credentials of a user authorized to access the repository, the server says “Forbidden
You don’t have permission to access /git/Test.git/ on this server.”
If I point the browser at "“example.com/git/” I get access to a page with a link to Test.git. Clicking the link takes me to a page with this url: “http://exmple.com/git/gitweb.cgi?p=Test.git;a=summary”
Is this the expected behaviour of the Git Repositories feature?
Hi otis
I know this is over two years old post but.
Did you get anywhere with the permissions?
I have not tried to use the http interface to get write access to repos. I use ssh for that. The http interface gives read access if you start by pointing your browser at yourdomain.com/git - which gives a list of repo links - rather than directly at yourdomain.com/git/YourRepo.git.
