Issue is regarding to this post: Git cannot be enabled (Nginx)
I currently have a need for git in an VirtualServer and don’t got it to work.
Any suggestions?
Any suggestions?
Did you notice that line? Did you try disabling it to see if it then started working like it did for this guy?
The Thread-Opener at the other post described that he was able to create the new SubServer if he uncheck git.
I need to use git, so unchecking is not a solution for me.
Ah. I took it as he unchecked it then it worked. Was thinking maybe it was just a bug that had the selection reversed or something.
Oh well. Sorry about that.
No Problem. Do you have an Idea what the issue might be?
BTW: I do have an NGINX / Apache installation on this Server.
