FTP not working on a freshly installed Virtualmin
in older relases of Virtualmin (Debian) I didn’t have that problem.
I’ve just installed Virtualmin on a Debian 8, even the main user of a vhost cannot log into the ftp.
I followed these steps :
https://www.virtualmin.com/node/39547
I did the # virtualmin config-system --include ProFTPd
also I checked to No for this Proftpd > Authentication section “Only allow login by users with valid shell?”
The log file /var/log/proftpd doesn’t log anything
Version is : ProFTPD Version 1.3.5
I have Filezilla as client.
The error message is : Unable to make a Connexion
Thank you for your help.
UPDATE: I can only login using port 22, how to enable connection on port 21?
UPDATE 2:
Nov 17 16:23:01 ns3081147 systemd-logind[13630]: New session c998 of user printplusvitrine.
Nov 17 16:23:22 ns3081147 proftpd: pam_unix(proftpd:session): session opened for user printplusvitrine by (uid=0)
Nov 17 16:23:22 ns3081147 systemd-logind[13630]: New session c999 of user printplusvitrine.
Nov 17 16:24:01 ns3081147 CRON[23854]: pam_unix(cron:session): session opened for user root by (uid=0)
Nov 17 16:24:01 ns3081147 CRON[23854]: pam_unix(cron:session): session closed for user root
Nov 17 16:25:01 ns3081147 CRON[23955]: pam_unix(cron:session): session opened for user root by (uid=0)
Nov 17 16:25:01 ns3081147 CRON[23956]: pam_unix(cron:session): session opened for user root by (uid=0)
Nov 17 16:25:01 ns3081147 CRON[23955]: pam_unix(cron:session): session closed for user root
Nov 17 16:25:02 ns3081147 CRON[23956]: pam_unix(cron:session): session closed for user root
Nov 17 16:25:02 ns3081147 sshd[23953]: Invalid user support from 137.74.40.87
Nov 17 16:25:02 ns3081147 sshd[23953]: input_userauth_request: invalid user support [preauth]
Nov 17 16:25:02 ns3081147 sshd[23953]: pam_unix(sshd:auth): check pass; user unknown
Nov 17 16:25:02 ns3081147 sshd[23953]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=87.ip-137-74-40.eu
Nov 17 16:25:05 ns3081147 sshd[23953]: Failed password for invalid user support from 137.74.40.87 port 49820 ssh2
Nov 17 16:25:05 ns3081147 sshd[23953]: pam_unix(sshd:auth): check pass; user unknown
Nov 17 16:25:07 ns3081147 sshd[23953]: Failed password for invalid user support from 137.74.40.87 port 49820 ssh2
Nov 17 16:25:07 ns3081147 sshd[23953]: pam_unix(sshd:auth): check pass; user unknown
Nov 17 16:25:10 ns3081147 sshd[23953]: Failed password for invalid user support from 137.74.40.87 port 49820 ssh2
Nov 17 16:25:10 ns3081147 sshd[23953]: Connection closed by 137.74.40.87 [preauth]
Nov 17 16:25:10 ns3081147 sshd[23953]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=87.ip-137-74-40.eu
Why would you want to use FTP? Also, port 22 is SSH not FTP.
this is a very common issue if you look through the forum, this might help you: https://www.virtualmin.com/node/39547
