I’m trying to setup a filesystem backup in webmin to an FTP server. I am provided this FTP server via my dedicated server provider and the username is my hostname of the server…so is in this format jk678564.provider.com
Webmin doesn’t seem to like the ‘dots’ in the username…is there a way round this? My provider doesn’t give you the option to change your username, its default set at your domain name.
Virtualmin actually uses dots in all of it’s FTP usernames by default… in theory, that those should be a valid character for usernames for an FTP server in Webmin/Virtualmin.
I’m having the problem when I select ftp option in the filesystem backup…I put in the ftp address, username and password. Proceed with the backup and the progress comes on the screen with the various things its doing, and it flags up saying the username is incorrect format (sorry I don’t remember exact message, I will look when I get home and reply with the exact message)… If I use a username that doesn’t have an . symbol in… And it says incorrect password (obviously as the username doesn’t exist)
DUMP: Cannot open output “/”: Operation not permitted
As you can see, when i enter a username with dots i get the error message invalid username (by the way, this is the entire output message) and when i enter a username with no dots i get login auth failed.
I have replaced real servername with *****SERVERNAME for obvious reasons.
Thank you! This works perfect. I think you were right, the dump command is having problems with my user name as the ‘Tar’ backup works fine.
If I select ‘yes’ on ‘Just add new files to archive?’ will this just do a differential backup and only add the files that are new (that aren’t in the original full backup)
“When this is set to No (as it is by default), the backup destination will be replaced with an archive of all files currently in the source directories. But if you select Yes, only files that have been changed since the archive was create will be appended to it. This is useful when making incremental backups. However, it cannot be used with compressed or remote archives.”
