I tired to edit the /etc/proftpd/proftpd.conf and remove the _ from the end of ns1.flirtsnflings.com but its not in that file.
The second issue is sending outgoing mail from thunderbird email client. I can receive mails but I cannot send them it just continually asks for the password even though i know its correct. I seen in the forums this issues has been mentioned before but I was unable to find the solution. Both sending and receiving os working fine from within usermin.
as for the mail I think this may have to do with your TLS settings in thunderbird. I would disable them if they are enabled atm and enable them if they were disabled atm. And see how that goes.
ftp -> Joe, Eric?
oh and you can always use port 22 in your ftp client…
Iv tired the mail on all setting still the same.
Whats the deal with ftp on port 22 again? that does seem to be working
Just to get one thing straight ProFTPd FTP Server is supposed to be running after a default installation of virtualmin using the install script correct?
port 22 is the ssh server which is a secure way of logging into your server. You can use your ftpclient to upload files to your server. So its not proftp, but the ssh server (and is preferred actually)
proftp should be running on a default installation, but you had trouble with FQDN which may have messed up something which I can not find.
if you save passwords in thunderbird, try deleting it for joomlaplazza and empty the cache if there is such thing. I think somehow you got the wrong password in thunderbird. Or try another mailclient to test. evolution, mulberry etc.
look at the bottom part contributed by a member. For thunderbird to login it needs ftp access as well and that’s not working yet with you. Per haps the two are related…
What are we talking about here? Mail or FTP? If mail, sending or receiving or both? (All different servers, all different protocols, and all have different troubleshooting steps and solutions.)
If mail, the maillog is where all answers will be found, so we’ll want to see the relevant entries from the maillog.
I get a reasonable response back when I look it up from my neck of the woods, but for some reason your system isn’t able to look it up. Figuring out why is the first step.
In my system FTP is running as nobody and is User:Group-> ftp:ftp
in your system it’s running as ftp:nogroup. That may cause it as it may not have the correct permissions?
edit: If I recall you also made a virtual server or user called FTP … You may want to get rid of it. And check the users:group module found under webmin
