I have subscribed for PRO version of Virtualmin just for reason to get easy Foswiki installation script. But have trouble doing it.
First I’ve got error that some packages missing but easily sorted it https://www.virtualmin.com/comment/795603#comment-795603
Now something else.
Now installing Foswiki version 2.1.6 ..
Initial Foswiki installation complete. Go to http://wiki0.mydomain.com/foswiki/bin/view to configure it.
More information on using this script can be found at http://foswiki.org/.
.. done
Applying web server configuration
.. done
Script installation states about successful finish, but when opening site to configure foswiki…
Link to screenshot: https://www.dropbox.com/s/cp5fxemlfu6hazn/Screenshot_20180511_204555.png?dl=0
and error when clicking on one of those links.
**** ERROR ****
The following critical dependencies are missing from your installation:
… JSON: Can’t locate JSON.pm in @INC
Please install these modules and then ensure all dependencies are installed by either:
- viewing the System.PerlDependencyReport in your local Foswki, or
- running the CLI shell script tools/dependencies from your server’s command line.
You can get a complete list of Perl module dependencies by viewing System.SystemRequirements
on your local system or at http://foswiki.org/System/SystemRequirements.
Foswiki will not operate correctly unless the required dependencies are installed.
Your current library search path @INC contains:
/home/mydomain/domains/wiki0.mydomain.com/public_html/foswiki/lib
/etc/perl
/usr/local/lib/x86_64-linux-gnu/perl/5.20.2
/usr/local/share/perl/5.20.2
/usr/lib/x86_64-linux-gnu/perl5/5.20
/usr/share/perl5
/usr/lib/x86_64-linux-gnu/perl/5.20
/usr/share/perl/5.20
/usr/local/lib/site_perl
/home/mydomain/domains/wiki0.mydomain.com/public_html/foswiki/lib/CPAN/lib
You can adjust the search path by editing bin/LocalLib.cfg
any ideas?
Thank you for your time…
