I’m trying to integrate a javascript file with a validation function with the ui-lib functions that generate forms. To do so i create my interface as follows:
[snip] use WebminCore;my $js = "<script type='text/javascript' src='/virtualmin-myextension/validate.js' ></script>\n";
print header("Mailboxes Configuration", null, undef, undef,0,0,undef, $js);
[snip]
print ui_form_start("","post",undef,
"onSubmit=\"return check_form_valid()\");
the mailbox.js content is:
function check_form_valid() { alert("hello"); return false; }the produced HTML code is like this:
[snip] [snip] [snip]apparently the form validation does not happen (no alert is executed). on the contrary, if I build the form as:
print ui_form_start("",“post”,undef,
"onSubmit=“return alert(‘something’)”);
i can see the alert popup.
the js path seems to be correct, because in firefox i can see the source file and double click in the “src” link of the element “<script src=”/virtualmin-myextension/validate.js’ >" and it loads the correct file.
is it possible I’m missing something?
thanks in advance
