this i on a VM working yesterday.
prompted to package update “Webmin”
which when done suggests “Re-check and refresh configuration”
which results in
where in BIND (Webmin) do I fix?
| SYSTEM INFORMATION |
| OS type and version |
Debian Linux 12 |
| Webmin version |
2.640 |
| Usermin version |
2.530 |
| Virtualmin version |
8.1.0 GPL |
| Theme version |
26.41 |
| Apache version |
2.4.67 |
| Package updates |
All installed packages are up to date |
Joe
2
So, why’d you change mydestination from its default value, which includes the system hostname ($myhostname)?
i did not.
it was working fine then prompted with package update. just Webmin 2.640
which seemed pretty sensible
where do i find the fix to this remembering that Webmin is a place i am unfamiliar with
ok, i think i found it deep in Webmin
now at least check configuration completed
but also had to do a security update on the way + reboot
