So I tested it on a fresh Debian 12 install. The install script runs without errors, as well as the Post-Installation Wizard and the Check Configuration process.
Still, there seems to be some troubles with spamassassin. Webmin’s module shows the following error:
**Warning!** SpamAssassin does not appear to be set up in the system's Procmail configuration file /etc/procmailrc, so any configuration done using this module will have no effect unless users have it set up individually.
And it is impossible to make any change there without getting this error:
### Failed to apply changes : Failed to restart spamassassin.service: Unit spamassassin.service not found.
Witch is confirmed when trying to look at spamassassin’s status in command line:
$ systemctl status spamassassin
Unit spamassassin.service could not be found.
There also seems to be an issue with Fail2Ban. It is not running after installation and refuses to start. There is a warning about ipv6 and an error concerning the postfix-sasl jail not finding its log file:
$ systemctl status fail2ban
Ă— fail2ban.service - Fail2Ban Service
Loaded: loaded (/lib/systemd/system/fail2ban.service; enabled; preset: enabled)
Active: failed (Result: exit-code) since Wed 2023-06-28 13:06:44 CEST; 5s ago
Duration: 81ms
Docs: man:fail2ban(1)
Process: 42850 ExecStart=/usr/bin/fail2ban-server -xf start (code=exited, status=255/EXCEPTION)
Main PID: 42850 (code=exited, status=255/EXCEPTION)
CPU: 66ms
Jun 28 13:06:44 vps.domain.com systemd[1]: Started fail2ban.service - Fail2Ban Service.
Jun 28 13:06:44 vps.domain.com fail2ban-server[42850]: 2023-06-28 13:06:44,688 fail2ban.configreader [42850]: WARNING 'allowipv6' not defined in 'Definition'. Using default one: 'auto'
Jun 28 13:06:44 vps.domain.com fail2ban-server[42850]: 2023-06-28 13:06:44,700 fail2ban [42850]: ERROR Failed during configuration: Have not found any log file for postfix-sasl jail
Jun 28 13:06:44 vps.domain.com fail2ban-server[42850]: 2023-06-28 13:06:44,707 fail2ban [42850]: ERROR Async configuration of server failed
Jun 28 13:06:44 vps.domain.com systemd[1]: fail2ban.service: Main process exited, code=exited, status=255/EXCEPTION
Jun 28 13:06:44 vps.domain.com systemd[1]: fail2ban.service: Failed with result 'exit-code'
Confirmed: installing rsyslog + restart Postfix allows fail2ban to start.
Concerning spamassassin, would it be possible that the service “spamassassin” is now called “spamd”? If yes, Webmin’s module should be adapted.
Finally, concerning the error (also in spamassassin’s module):
Yeah, Ilia noted that in one of his comments about his testing. It’ll be fixed in virtualmin-config soon.
No, but I don’t install it on my systems. It’s not necessary on a system that logs to the journal. And, journald can log to text logs, and has a syslog interface for apps, so there is no reason to have rsyslog, unless you just prefer it.
I don’t know why fail2ban doesn’t work out of the box. It’s probably bug-like that the Debian package configuration doesn’t set it up so it works for a default system. But, we can fix that kind of config problem in virtualmin-config. It just hasn’t been done yet. (Debian 12 is not a supported distro yet, so it is expected to have problems.)
$ systemctl is-enabled spamassassin
Failed to get unit file state for spamassassin.service: No such file or directory
$ apt install spamassassin
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
spamassassin is already the newest version (4.0.0-6).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
$ systemctl status spamd
* spamd.service - Perl-based spam filter using text analysis
Loaded: loaded (/lib/systemd/system/spamd.service; enabled; preset: enabled)
Active: active (running) since Thu 2023-06-29 08:11:56 CEST; 7min ago
Main PID: 37176 (spamd)
Tasks: 3 (limit: 4645)
Memory: 135.0M
CPU: 1.085s
CGroup: /system.slice/spamd.service
|-37176 /usr/bin/perl "-T -w" /usr/sbin/spamd --pidfile=/run/spamd.pid --create-prefs --max-children 5 --helper-home-dir
|-37469 "spamd child"
`-37470 "spamd child"
Yeah, that sounds like a bug in the Debian 12 fail2ban package. We’ll fix it in virtualmin-config, when we get time (I should be able to do some development this weekend).
