Failed to save two-factor authentication : The Perl module Authen::OATH needed for two-factor authentication is not installed
I tried to install two-factor authentication in webmin but I’m getting this error.
Failed to save two-factor authentication : The Perl module Authen::OATH needed for two-factor authentication is not installed. Use the Perl Modules page in Webmin to install it.
I tried to install Perl modules via webmin in Other>Perl modules. I selected google Authenticator and I received an error.
At the end is written:
Installation of Authen::OATH failed. Check the output above and try installing manually.
You can also install the module from CPAN with the command perl -MCPAN -e shell.
I used this guide
https://scunster.co.uk/?p=1411
And I installed, with some dependency problems but at the end I have done it.
yum -y install perl-CPAN
Now, install the following:
perl -MCPAN -e “install Test::Moose”
perl -MCPAN -e “install Types::Standard”
perl -MCPAN -e “install Moo”
perl -MCPAN -e “install Authen::OATH”
I double checked the installation.
[root@localhost download]# yum -y install perl-CPAN
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
Package perl-CPAN-1.9800-294.el7_6.noarch already installed and latest version
Nothing to do
[root@localhost download]# perl -MCPAN -e “install Test::Moose”
Reading ‘/root/.cpan/Metadata’
Database was generated on Sun, 29 Dec 2019 21:41:03 GMT
Fetching with LWP:
http://www.planet-elektronik.de/CPAN/authors/01mailrc.txt.gz
Reading ‘/root/.cpan/sources/authors/01mailrc.txt.gz’
…DONE
Fetching with LWP:
http://www.planet-elektronik.de/CPAN/modules/02packages.details.txt.gz
Reading ‘/root/.cpan/sources/modules/02packages.details.txt.gz’
Database was generated on Wed, 08 Jan 2020 21:55:18 GMT
New CPAN.pm version (v2.27) available.
[Currently running version is v1.9800]
You might want to try
install CPAN
reload cpan
to both upgrade CPAN.pm and run the new version without leaving
the current session.
…DONE
Fetching with LWP:
http://www.planet-elektronik.de/CPAN/modules/03modlist.data.gz
Reading ‘/root/.cpan/sources/modules/03modlist.data.gz’
DONE
Writing /root/.cpan/Metadata
Test::Moose is up to date (2.2012).
[root@localhost download]# install CPAN
install: missing destination file operand after ‘CPAN’
Try ‘install --help’ for more information.
[root@localhost download]# perl -MCPAN -e “install Types::Standard”
Types::Standard is up to date (1.008001).
[root@localhost download]# perl -MCPAN -e “install Moo”
Moo is up to date (2.003006).
[root@localhost download]# perl -MCPAN -e “install Authen::OATH”
Authen::OATH is up to date (2.0.1). >>>> Attention <<<<<
The thing is that I restarted webmin, and the virtual machine and Im still getting the same error:
How is this possible?
The thing is that I already used this method in another virtual machine and it worked(now this vm is not available)
Thank you
Regards.
Argh. I didn’t realize this dependency didn’t exist in EPEL. Installing from CPAN should always be a last resort, so I’ll see about getting it packaged for CentOS 7 and 8 (CentOS 6 is so old that I doubt it will be reasonable to support).
Hi.
Sorry I don’t won’t what you mean. I’m not a professional sysadmin.
It means is using EPEL dependencies instead of others repos?
It would work if I use other repos?
I tried to install the perl modules in the virtualmin interface and the installation fails.
I even tried to install the suggested modules in Perl modules section but it also fails.
The only way I installed a perl module in my Centos 7 system is via CLI with the commands, that I have written in the first post.
Anyway EPEL is used by virtualmin if I remember well.
Regards.
No, it’s missing from EPEL. Don’t add any other repos.
I’m gonna try to build it and add it to our repos. I don’t know why it never came to my attention that it was usually being installed from CPAN. I would have put a stop to that ages ago.
:exclamation: NOTE: Webmin 2.100 and above have Authen::OATH Perl module bundled in Webmin. There should be no additional steps taken to active 2FA! :exclamation:
Hello Joe.
Let me know when you do it.
Thank you.
Regards.
