Failed to download metadata for repo 'virtualmin'
Rocky Linux 9.1 Raspberry Pi (aarch64)
N/A
Virtualmin 7
Unfortunately I cannot upload the virtualmin-install.log file because I am a new user.
Here is the log: virtualmin-install.log · GitHub
More specific https://software.virtualmin.com/vm/7/rpm/aarch64/repodata/repomd.xml is 404.
This is a fresh install with only dnf update, wget, and sshd setup. The rocky linux 9.1 OS was imaged with the official raspberry pi imager tool. I reformatted and have tried this twice with the same issue.
That’s not a supported OS. (We don’t have ARM repositories.)
Virtualmin can still work, and it’s pretty easy to trick the installer into running. It’s been discussed quite a bit, just search the forum. Everything will probably work, except mail processing which will be missing the procmail-wrapper package.
He had told me @Ilia a while ago that they had added support for “procmail-wrapper” in the aarch64 architecture…
That PR has not been merged. And, there are no ARM repos.
