hey, when i try to creat a new virtual server i see this error Failed to create virtual server : Failed to work out externally visible IP address
i tired to change the Network interface for virtual addresses from eth0 to Detect automatically and same error
and also i tired to chane the Default virtual server IPv4 address From “From network interface” To 192.168.122.216 and same error
what can i do now to add a new virual server
Thanks.
Virtualmin/System Settings/Virtualmin Configuration then in the configuration catagory go to the dropdown that says Network Settings and see if Default IP for DNS records is set to Same as Virtual Server IP
