Hi everyone.
I have installed webmin and virtualmin 3.8 on CentOS 5.5 and configured the webmin and virtualmin,and
when I Checking Configuration, I got the message below:
your system is ready for use by Virtualmin.
but when I try to Create Virtual Server,I got a message below:
Creating administration group abctext …
… failed to create administration group : useradmin::create_group failed : Failed to replace /etc/gshadow with /etc/gshadow.webmintmp.11530 : Operation not permitted at /usr/libexec/webmin/web-lib-funcs.pl line 1331.
Failed to create virtual server : Critical feature Administration user was not properly created - Virtual server creation halted.
Please please,anyone who can tell me How can I fix the trouble…
Thanks.
It looks like your gshadow file has the “immutable” attribute set, which means that even root isn’t allowed to modify that file. I have no idea how that might have happened, and that’s certainly not a default.
Thanks all of you.
I have change the attribute of the gshadow,and there are some files have the same problem,And I follow the method andreychek told to run some command.
Now,It work.
Thanks everyone.
