Fail2ban bantime.increment options in Webmin?
To protect against mass attacks I used to setup a recidive jail that checked the fail2ban log.
Nowadays fail2ban has a built in solution against mass attacks: bantime.increment, bantime.factor, etc. The more failed tries the longer the ban. It allows a few more attempts for normal users while killing bots that try much more through exponential growing ban times.
I can add these manually in the fail2ban.local, but it would be nice if:
a) They are configurable in Webmin (default and per jail)
  • bantime.increment
  • bantime.factor
  • bantime.maxtime
  • bantime.overalljails
  • bantime.rndtime
b) Switched on by default to have a more hardened setup out of the box for those who do not dive directly in the settings.
Just found out that the recidive jail is part of the standard fail2ban setup. I mistakenly though I set it up manually a few years ago.
Still would be nice to be able to tweak the bantime.increment settings
fail2ban-client set <JAIL> banip <IP>
Was one of my past favourites.
Days gone bye when I was constantly watching my clients servers.
Just drop the scumbags.
David
I know a few years ago I did. I’m not sure but the defaults are still probably distro specific but I don’t know that for certain.
Thanks for the nice heads-up!
The upcoming Webmin 2.654 update will include all these new features. If you want to test it now, just apply the following patch:
webmin patch https://github.com/webmin/webmin/commit/0a92881
Wow that was quick. You guys rule :smiling_face_with_sunglasses:
Works fine here
