I do have a server at Hetzner-Cloud where I’ve playing a bit around to test some stuff.
The Server does have the IP: 49.12.235.22 AND a Failover-IP/Floating-IP: 78.47.141.18
Question: Is there better way to pre-configure that the right IP (Floating-IP) is used in DNS-Settings if I create a new VirtualServer, or can I ignore the warning and go with it like I’ve set it up now?
I have a feeling your “floating” address is meant for “inbound” not “outbound” connections and is not actually directly assigned to your server. That’s likely while your server IP address is being detected as the one ending in “.22”.
Does your network adapter actually utilize “eth0” or another naming schema? For instance my laptop which runs Ubuntu uses the naming schema of “enp4s0”… and/or are both IPs using the same adapter name as this WILL NOT work either generally speaking… Assuming you are using the documented naming schema of “eth0” then a second IP would need to be called “eth0:1” or similar which makes it a “virtual network adapter” allowing both IPs to use the same physical network adapter in the system.
