So I have a properly running system with no errors so far, and I ran the package update.
I do not understand why this has only now happened.
Installing package(s) with command apt-get -y install awstats …
Setting up bind9 (1:9.4.2.dfsg.P2-2ubuntu0.6) …
Configuration file `/etc/bind/named.conf.local’
==> File on system created by you or by a script.
==> File also in package provided by package maintainer.
What would you like to do about it ? Your options are:
Y or I : install the package maintainer’s version
N or O : keep your currently-installed version
D : show the differences between the versions
Z : background this process to examine the situation
The default action is to keep your current version.
*** named.conf.local (Y/I/N/O/D/Z) [default=N] ? dpkg: error processing bind9 (–configure):
EOF on stdin at conffile prompt
bind9
Reading package lists…
Building dependency tree…
Reading state information…
awstats is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
1 not fully installed or removed.
After this operation, 0B of additional disk space will be used.
bind9
E: Sub-process /usr/bin/dpkg returned an error code (1)
… install failed!
