Hi all,
My journey started with an issue of failing backups. In the process of troubleshooting this I found the validate-domain command. When I run virtualmin validate-domains I get an error.   I can find plenty of information regarding apache, but not much for an nginx/fpm install.   The command I am running that replicates the error is:
virtualmin validate-domains --domain mydomain.org  --all-features
mydomain.org
Log file rotation : No webserver log found for virtual host mydomain.org
Sounds simple right?
Well this led me down the rabbit hole of fixing this issue.  Verify that Virtualmin->System Settings->Features&Plugins shows that “Nginx website” and “Nginx PHP-FPM website”  are enabled!  (Apache website=disabled) (Are both suppose to be enabled?)
Some document on this site I found suggested: go to Webmin -> Servers-Nginx, but this is MISSING (Not an option under “Servers” for nginx…)
When I create a brand new domain, it gets created and the virtual-config is generated in /etc/nginx/sites/available. It contains the necessary (but not optimal) config to bring the site up with php & fpm. I will save that for a separate thread.
So any guidance will be greatly appreciated. I could not find a clear cut guide for nginx out there. Not saying it doesn’t exist, just I could not find it.
I am running:
Ubuntu 16.04
Webmin 1.881
Virtualmin 6.02-3
