Error while starting Virtualmin
Yesterday I installed Webmin + Virtualmin.
I followed this Install Instructions: http://www.webmin.com/vdownload.html
When I clicking the button labeled Re-check and refresh configuration this is what I get:
[code:1]
  The Suexec command on your system is configured to only run scripts under /var/www, but the Virtualmin base directory is /home. CGI and PHP scripts run as domain owners will not be executed.
[/code:1]
How do I solve this problem ?
My box running on CentOS 4.4
Thanks to helpers !
When you say you followed the Install Instructions, does that mean you downloaded the install script and ran it? Or that you followed the old clunky, complicated, instructions linked of on the old clunky Swell Technology page (I can say that, because I made that page five or six years ago…and if I could find the password, I’d remove it, and link folks to newer stuff…I need to tell Jamie to remove that link…as it makes no sense these days).
Since you’re running on an OS that is supported by the automated install script, I would strongly suggest using it. It’ll save you tons and tons of time, and will insure your system looks like most everybody else, and will thus be easier to support and find docs and help for.
I simply downloaded those files:
[code:1]
Virtualmin can be downloaded in Webmin module format from:
http://download.webmin.com/download/virtualmin/virtual-server-3.62.gpl.wbm.gz (1.1 MB«»)
The Virtualmin framed theme in Webmin module format can be downloaded from:
http://download.webmin.com/download/virtualmin/virtual-server-theme-6.2.wbt.gz (2.2 MB«»)
[/code:1]
and installed via Webmin.
Can you please explain to me how to use automated install script ?
I’m pretty new with unix.
