Good Day
I’m receiving an error on phase 3 of 4 every time I try to install Virtualmin on a new Linode server.
The error is as follows:
▣▣▣◻ Phase 3 of 4: Installation
Checking and installing system package updates ✔
Installing Virtualmin 7 and all related packages touch: cannot touch 'stopspinning': No such file or directory
virtualmin-install.sh: 277: cannot create unitest.txt: Directory nonexistent
virtualmin-install.sh: 279: cannot open unitest.txt: No such file
[ERROR] Failed with error: 100
[ERROR] Something went wrong. Exiting.
[ERROR] The last few log entries were:
Processing triggers for dovecot-core (1:2.3.16+dfsg1-3ubuntu2.2) ...
Processing triggers for php8.1-fpm (8.1.2-1ubuntu2.14) ...
NOTICE: Not enabling PHP 8.1 FPM by default.
NOTICE: To enable PHP 8.1 FPM in Apache2 do:
NOTICE: a2enmod proxy_fcgi setenvif
NOTICE: a2enconf php8.1-fpm
NOTICE: You are seeing this message because you have apache2 package installed.
sa-compile
needrestart is being skipped since dpkg has failed
E: Sub-process /usr/bin/dpkg returned an error code (1)
Made it here...why?
Installing Virtualmin 7 and all related packages: [2023-09-19 14:49:40 UTC] [ERROR] Failed with error: 100
[2023-09-19 14:49:40 UTC] [ERROR] Something went wrong. Exiting.
[2023-09-19 14:49:40 UTC] [ERROR] The last few log entries were:
Regards
| SYSTEM INFORMATION | |
| OS type and version | Ubuntu OS 20.04 LTS |
| Webmin version | Installation |
| Virtualmin version | Installation |
| Related packages | Apache |
