Error: stty: standard input: Inappropriate ioctl for device
Virtualmin Version 7.0.0
I am receiving the following error when i try to install Virtualmin for the first time.
Someone, please help how to resolve this issue.
Continue? (y/n) stty: standard input: Inappropriate ioctl for device
Something is wrong with your terminal. What ssh client are you using? What is your default shell on the system you’re trying to login on?
Actually, it looks like you’re trying to use a non-interactive terminal (like a simple web shell or something) to install. You can’t do that. The install script needs a real interactive terminal. (Well, you can force it to run in a non-interactive mode, but you shouldn’t do that if you’re running it manually.)
