DEar All,
Firstly , Id like to thank for marvelous Virtualmin.
Since 3.80 GPL (on my Ubuntu 8.04.), during update of Virtualmin and webmin I am encountering following error (below the message). Error: Script was not run with full path
After update, Virtualmin still shows 3.80GPL but I cant run update process again because It points me that Its already newest version.
Should I be worry?
Kind regards,
Piotr
Now updating webmin-virtual-server …
Installing package(s) with command apt-get -y install webmin-virtual-server ..
Reading package lists...
Building dependency tree...
Reading state information...
The following packages were automatically installed and are no longer required:
libmd5-perl
Use 'apt-get autoremove' to remove them.
The following packages will be upgraded:
1 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
Need to get 1484kB of archives.
After this operation, 81.9kB of additional disk space will be used.
Get:1 http://software.virtualmin.com virtualmin-hardy/main webmin-virtual-server 3.82-2.gpl [1484kB]
Fetched 1484kB in 3s (470kB/s)
(Reading database ... 65109 files and directories currently installed.)
Preparing to replace webmin-virtual-server 3.81.gpl (using .../webmin-virtual-server_3.82-2.gpl_all.deb) ...
Unpacking replacement webmin-virtual-server ...
Setting up webmin-virtual-server (3.82-2.gpl) ...
Error: Script was not run with full path (failed to find /usr/share/webmin/run-postinstalls.pl under /usr/share/webmin-1.520)
.. install complete.
Now updating webmin-virtual-server-theme …
Installing package(s) with command apt-get -y install webmin-virtual-server-theme ..
libmd5-perl
Installing package(s) with command apt-get -y install webmin-virtual-server …
Reading package lists…
Building dependency tree…
Reading state information…
1 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Need to get 3526kB of archives.
After this operation, 105MB of additional disk space will be used.
Get:1 http://software.virtualmin.com virtualmin-universal/main webmin-virtual-server 3.82-2 [3526kB]
Fetched 3526kB in 5s (663kB/s)
(Reading database … 69731 files and directories currently installed.)
Preparing to replace webmin-virtual-server 3.81 (using …/webmin-virtual-server_3.82-2_all.deb) …
Unpacking replacement webmin-virtual-server …
Setting up webmin-virtual-server (3.82-2) …
Error: Webmin server did not write new PID file
Error
… install complete.
Installing package(s) with command apt-get -y install webmin-virtual-server-theme …
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 2224kB of archives.
After this operation, 37.7MB disk space will be freed.
Get:1 http://software.virtualmin.com virtualmin-universal/main webmin-virtual-server-theme 7.9 [2224kB]
Fetched 2224kB in 4s (513kB/s)
(Reading database … 69746 files and directories currently installed.)
Preparing to replace webmin-virtual-server-theme 7.8 (using …/webmin-virtual-server-theme_7.9_all.deb) …
Unpacking replacement webmin-virtual-server-theme …
Setting up webmin-virtual-server-theme (7.9) …
… install complete.
ran dpkg -l webmin-virtual-server and got
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Cfg-files/Unpacked/Failed-cfg/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Hold/Reinst-required/X=both-problems (Status,Err: uppercase=bad)
||/ Name Version Description
ii webmin-virtual-server 3.82-2 Webmin module for ‘Virtualmin Virtual Servers’
Hi Andreychek,
I am getting following info which I presume is correct. I am just worried If everything is ok.
Server works flawless except this message.
root@vmin:~# dpkg -l webmin-virtual-server
| Status=Not/Installed/Config-f/Unpacked/Failed-cfg/Half-inst/t-aWait/T-pend
ii webmin-virtual 3.82-2.gpl Webmin module for 'Virtualmin Virtual Server
root@vmin:~#
Yeah, that all looks good. It may just mean that the old Webmin process didn’t shut down cleanly, which isn’t a big deal… you can verify that it’s not causing problems by:
Stopping Webmin, with: /etc/init.d/webmin stop
Look for any running Webmin processes: ps auxw | grep miniserv | grep webmin
