popmay
April 22, 2023, 3:00am
1
OS type and version
Ubuntu 22.04
Webmin version
2.021
Virtualmin version
7.7 GPL
Related packages
up to date
After upgrading to Virtualmin 7.7 when going to Backup and Restore on 2 servers I get:
HTTP/1.0 500 Perl execution failed Server: MiniServ/2.021 Date: Sat, 22 Apr 2023 02:18:08 GMT Content-type: text/html; Charset=utf-8 Connection: close
Error — Perl execution failed
Undefined subroutine &virtual_server::can_use_gcloud_storage_creds called at /usr/share/webmin/virtual-server/cloud-lib.pl line 304.
line 304; elsif (&can_use_gcloud_storage_creds()) {
I restart Webmin from command line as suggested in older threads and it doesn’t change.
thanks
Marvin
popmay
April 22, 2023, 3:36am
2
I just noticed the thread below and deleted
return { ‘ok’ => 1,
‘desc’ => $text{‘cloud_gcpcreds’},
from
cloud-lib.pl
it cleared the error and backup is working fine. Restored fine on new server.
The great part is that it was a large legacy email account that was migrated without having to make an extra unix user. It receives email from outside. Magic from my point of view
Cypher
April 22, 2023, 6:29am
3
When will this problem be solved? @Joe
Cypher
April 22, 2023, 8:36am
5
Problem persist on subdomains after 7.7-2 upgrade. @Joe @Jamie
Ilia
April 22, 2023, 9:40am
6
Can you explain more about what is happening? Virtualmin 7.7-2 fixes it for me. Did you try to restart Webmin manually?
Cypher
April 22, 2023, 10:05am
8
Yes I did.
I am getting this error everytime.
Creating backup for virtual server abc.domain.net …
Copying virtual server configuration …
… done
Copying records in DNS domain …
… domain not found!
Ilia
9
Was this domain created just recently, with the bugged Virtualmin 7.7-1 GPL version?
Cypher
April 22, 2023, 10:08am
10
Version is 7.7-2 GPL. No this is old domain and DNS records exist. Created on 30/Jan/2023 by user
Ilia
April 22, 2023, 10:16am
11
Does BIND DNS domain config file exists on your system and how does it look like?
The file can be found in /var/lib/bind
on Debian systems and in /var/named/
on RHEL.
Ilia
12
Also, I recommend you to open a separate ticket! This is completely unrelated issue to the original topic.
I will close this treat. Please open a new ticket!
