Error on setting up slave dns
source system debian 12
destination ubuntu 24.02 LTS
webmin versions 2.303
i have the source able to see the destination…and i keep getting this error
Failed to add server : Could not work out this system’s IP address. You should set the Default master server IP for remote slave zones on the Module Config page.
right now in the module config page doesn’t show me…obviously…i cannot find…i know i am missing something…and yes i ahve read the documentation…i am missing something simple i know it…just wondering what it is.
Don’t use the hostname, use the IP address instead and disable the SSL (or other security option, I do not recall exactly which one) on the same screen.
I had this error too, once, and this was the workaround.
yeah that’s what i had to do…:slight_smile:
Mark this as the solution then, so that others who get the error can find a confirmed workaround here.
