Hi everyone!
I’m trying to install Virtualmin Pro on a fresh Ubuntu 8.04 AMD64 system.
I’ve seen that Ubuntu 8.04 amd64 is on the supported systems.
Only CentOS 4 and 5, Debian 4.0 and Ubuntu 8.04 LTS on i386 and x86_64/amd64 are supported for automated installation of Virtualmin GPL at this time.
This is the output:
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
virtualmin-base: Depends: procmail-wrapper but it is not installable
FATAL - 2008-05-13 22:52:30 - Fatal Error Occurred: Installation failed: 0
FATAL - 2008-05-13 22:52:30 - Cannot continue installation.
FATAL - 2008-05-13 22:52:30 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2008-05-13 22:52:30 - re-attempted after any problems have been resolved.
FATAL - 2008-05-13 22:52:30 - Removing temporary directory and files.
FATAL - 2008-05-13 22:52:30 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2008-05-13 22:52:30 - in /root/virtualmin-install.log
Thanks for your help!!!
Juan
