Error inside virtuallmin when trying to enable or disable awstats
debian 12
Version 7.30.8 Pro
24 cpu
64 gigs of ram
50 accounts
Deleting AWStats configuration file and Cron job ..
.. done
Removing password protection for AWStats ..
.. done
Updating Webmin user ..
.. done
.. done
Saving server details ..
.. done
Applying webserver configuration ..
.. failed! An Apache configuration error was detected :
AH00526: Syntax error on line 83 of /etc/apache2/sites-enabled/testing.nvcmd.org.conf:
SSLCACertificateFile: file ‘/home/nvcmd/domains/testing.nvcmd.org/ssl.ca’ does not exist or is empty
Action ‘configtest’ failed.
The Apache error log may have more information.
Re-loading Webmin ..
.. done
the site throwing this error is aminerdetail.com. both sites are operating normally otherwise. this is a new server that i restored form backups..i am wondering why this is now occurring. I deleted that testing domain and now all sites are saying the awstats.conf is missing. I am cycling through every site to regenerate this file. i am curious what caused that file to get wiped across the system.
What happened to that file?
i reformateed the mahcine..instlaled from sratach and did a manual restore wqithout the exiwting vrt settingsw..my usual fix for when virt acts up these days…:slight_smile:
