Can’t locate Virtualmin/Config.pm in @INC (you may need to install the Virtualmin::Config module) (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.30.0 /usr/local/share/perl/5.30.0 /usr/lib/x86_64-linux-gnu/perl5/5.30 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.30 /usr/share/perl/5.30 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at /usr/bin/virtualmin-config-system line 9.
Thanks for heads up! It’s been fixed already.
Either re-install from scratch if it’s recent install or simply run the following command, making sure things will get configured correctly:
apt-get update && apt-get upgrade -y && virtualmin-config-system -b=LAMP # or LEMP
… re-run config check afterwards.
