I am getting the following error for SSL certificate installation
Renewing an existing certificate for amazingzoology.com and *.amazingzoology.comCertbot failed to authenticate some domains (authenticator: manual). The Certificate Authority reported these problems:
Domain: amazingzoology.com
Type: unauthorized
Detail: Incorrect TXT record “_acme-challenge.amazingzoology.com” found at _acme-challenge.amazingzoology.comDomain: amazingzoology.com
Type: unauthorized
Detail: Incorrect TXT record “_acme-challenge.amazingzoology.com” found at _acme-challenge.amazingzoology.comHint: The Certificate Authority failed to verify the DNS TXT records created by the --manual-auth-hook. Ensure that this hook is functioning correctly and that it waits a sufficient duration of time for DNS propagation. Refer to “certbot --help manual” and the Certbot User Guide
Some challenges have failed.
