Can anyone help me fix an issue I’m having with MySQL periodically shutting down? When I try to restart the daemon, the error I get is:
Failed to start service :
MySQL Daemon failed to start.
Starting mysqld: [FAILED]
If I restart the whole server it works fine, but this is happening on a daily basis so I can’t keep restarting the server. I probably need to check the logs but can someone direct me to the right place to look?
Thanks for the help. I think you could be right, I’m currently using AWS EC2 Micro instance which is only 595MB RAM. I don’t see a beancounters file but running ‘free -m’ displays:
