Error establishing a database connection /usr/bin/mysqlshow: Too many connections
Hi all,
Need your help, I got the problem with my site after my traffic increase. I can’t access to my site and get error message: Error establishing a database connection. When I want manage mysql database, I got the message: /usr/bin/mysqlshow: Too many connections.
May you help me to solve this problem? Thanks in advance.
Kind regards,
This document here describes how to resolve the “too many connections” error:
http://dev.mysql.com/doc/refman/5.5/en/too-many-connections.html
You’ll essentially need to edit your my.cnf file in /etc, and increase your “max_connections” variable.
Hi Eric,
Thanks for your advice,
I have type /etc/my.cnf use Putty and got the message:
“bash: /etc/my.cnf: Permission denied”
and I also try type /etc/mysql/my.cnf and got the message:
“bash: /etc/mysql/my.cnf: No such file or directory”
I also failed to WebMin dashboard and still got message: “Click this button to start the MySQL database server on your system with the command /etc/rc.d/init.d/mysqld start. This Webmin module cannot administer the database until it is started.”
Can I know detail step by step to resolve it? I’m so confuse… If it possible i can change it from Virtualmin dasboard. Thanks for your valuable time and kind help.
Kind regards,
Hi Eric,
I can run my site again after:
I stop mysql with command:
/etc/rc.d/init.d/mysqld stop
and restart it with command:
but I still have a problem with command /etc/my.cnf
Need your advice to increase max_connections…
Thanks and kind regards,
You would want to edit “/etc/mysql/my.cnf” with a text editor in order to tweak the max_connections variable.
@alex: One hint and one advice. :slight_smile: The hint: you can do the stop and start thing in one command with /etc/init.d/mysqld restart.
To edit text files, you might want to install “Midnight Commander”, which, among being a very good file manager, comes with an easy-to-use text editor named “mcedit”. So, mcedit /etc/mysql/my.cnf will do the trick once MC is installed.
