Error during nextcloud script installation
OS type and version Debian Linux 10
Webmin version 2.021
Virtualmin version 7.7 Pro
Related packages Nextcloud 26.0.1
creating: nextcloud/apps/recommendations/js/
inflating: nextcloud/apps/recommendations/js/files_recommendation-dashboard.js.map
nextcloud/apps/recommendations/js/files_recommendation-dashboard.js.map: write error (disk full?). Continue? (y/n/^C)
warning: nextcloud/apps/recommendations/js/files_recommendation-dashboard.js.map is probably truncated
Quota = 5 GB
Filesystem Size Used Avail Use% Mounted on
udev 7.7G 0 7.7G 0% /dev
tmpfs 1.6G 156M 1.4G 10% /run
/dev/mapper/tine–vg-root 6.1G 4.4G 1.5G 76% /
tmpfs 7.7G 16K 7.7G 1% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 7.7G 0 7.7G 0% /sys/fs/cgroup
/dev/sda1 470M 118M 328M 27% /boot
/dev/mapper/tine–vg-home 123G 46G 72G 39% /home
/dev/mapper/tine–vg-var 7.2G 4.3G 2.6G 63% /var
/dev/mapper/tine–vg-tmp 467M 23K 438M 1% /tmp
tnas1.l.vrc.dk:/mnt/data1/data_tine 11T 5.9T 4.5T 57% /data
tmpfs 1.6G 0 1.6G 0% /run/user/0
