I have been trying to install virtual min, (automated install) on a Centos 5.4 x86_64 architecture. Even though yum updates as suggested during the installation process were performed, however, I keep getting the installation errors on a fresh installation. Below is the output of the installation log.
I am able to login to the virtualmin through https://mysite.com:10000 but am not sure what I am missing out due to the installation errors.
Could anybody give me a heads up on this. Thanks.
INFO - 2010-05-19 23:48:08 - Started installation log in /root/virtualmin-install.log
DEBUG - 2010-05-19 23:48:08 - Install mode: full
DEBUG - 2010-05-19 23:48:08 - Product: Virtualmin GPL
DEBUG - 2010-05-19 23:48:08 - Virtualmin Meta-Package list: virtualmin-base
DEBUG - 2010-05-19 23:48:08 - install.sh version: 1.0.3
INFO - 2010-05-19 23:48:08 - Checking for fully qualified hostname…
INFO - 2010-05-19 23:48:08 - Hostname OK: fully qualified as oriental.allnetsols.com
INFO - 2010-05-19 23:48:08 - Installing serial number and license key into /etc/virtualmin-license
INFO - 2010-05-19 23:48:09 - Loading OS selection library…
INFO - 2010-05-19 23:48:21 - Download of http://software.virtualmin.com/lib/oschooser.pl Succeeded.
INFO - 2010-05-19 23:48:21 - Loading OS list…
INFO - 2010-05-19 23:48:33 - Download of http://software.virtualmin.com/lib/os_list.txt Succeeded.
INFO - 2010-05-19 23:48:33 - Operating system name: CentOS Linux
INFO - 2010-05-19 23:48:33 - Operating system version: 5
INFO - 2010-05-19 23:48:33 - Configuring package manager for CentOS Linux 5…
INFO - 2010-05-19 23:48:33 - Disabling SELinux during installation…
INFO - 2010-05-19 23:48:33 - setenforce 0 failed: 1
INFO - 2010-05-19 23:48:46 - Download of http://software.virtualmin.com/gpl/rhel/5/x86_64/virtualmin-release-latest.noarch.rpm Succeeded.
INFO - 2010-05-19 23:48:47 - Succeeded.
INFO - 2010-05-19 23:48:47 - Installing dependencies using command: /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix bind spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-domxl php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
- addons: netops.nexicom.net
- base: netops.nexicom.net
- extras: netops.nexicom.net
- updates: netops.nexicom.net
Setting up Install Process
Package 30:bind-utils-9.3.6-4.P1.el5_4.2.x86_64 already installed and latest version
Package procmail-3.22-17.1.el5.centos.x86_64 already installed and latest version
Package 1:quota-3.13-1.2.5.el5.x86_64 already installed and latest version
Package iptables-1.3.5-5.3.el5_4.1.x86_64 already installed and latest version
Package openssl-0.9.8e-12.el5_4.6.x86_64 already installed and latest version
Package python-2.4.3-27.el5.x86_64 already installed and latest version
No package rh-postgresql available.
No package rh-postgresql-server available.
Package logrotate-3.7.4-9.x86_64 already installed and latest version
No package php-domxl available.
Package cyrus-sasl-2.1.22-5.el5_4.3.x86_64 already installed and latest version
Resolving Dependencies
–> Running transaction check
—> Package bind.x86_64 30:9.3.6-4.P1.el5_4.2 set to be updated
—> Package caching-nameserver.x86_64 30:9.3.6-4.P1.el5_4.2 set to be updated
—> Package cyrus-sasl.i386 0:2.1.22-5.el5_4.3 set to be updated
–> Processing Dependency: libpam.so.0(LIBPAM_1.0) for package: cyrus-sasl
–> Processing Dependency: libgssapi_krb5.so.2 for package: cyrus-sasl
–> Processing Dependency: libsasl2.so.2 for package: cyrus-sasl
–> Processing Dependency: libkrb5.so.3(krb5_3_MIT) for package: cyrus-sasl
–> Processing Dependency: libldap-2.3.so.0 for package: cyrus-sasl
–> Processing Dependency: libk5crypto.so.3 for package: cyrus-sasl
–> Processing Dependency: libcom_err.so.2 for package: cyrus-sasl
–> Processing Dependency: libgdbm.so.2 for package: cyrus-sasl
–> Processing Dependency: libpam.so.0 for package: cyrus-sasl
–> Processing Dependency: libkrb5.so.3 for package: cyrus-sasl
–> Processing Dependency: libkrb5support.so.0 for package: cyrus-sasl
–> Processing Dependency: liblber-2.3.so.0 for package: cyrus-sasl
—> Package cyrus-sasl-gssapi.i386 0:2.1.22-5.el5_4.3 set to be updated
—> Package cyrus-sasl-gssapi.x86_64 0:2.1.22-5.el5_4.3 set to be updated
—> Package dovecot.x86_64 0:1.0.7-7.el5 set to be updated
—> Package httpd.x86_64 1:2.2.3-22.el5.1vm set to be updated
—> Package mailman.x86_64 3:2.1.9-4.el5 set to be updated
—> Package mod_dav_svn.x86_64 0:1.4.2-4.el5_3.1 set to be updated
—> Package mod_perl.x86_64 0:2.0.4-6.el5 set to be updated
–> Processing Dependency: perl(BSD::Resource) for package: mod_perl
—> Package mod_python.x86_64 0:3.2.8-3.1 set to be updated
—> Package mod_ssl.x86_64 2:2.2.3-22.el5.1vm set to be updated
–> Processing Dependency: libdistcache.so.1()(64bit) for package: mod_ssl
–> Processing Dependency: libnal.so.1()(64bit) for package: mod_ssl
—> Package mysql.i386 0:5.0.77-4.el5_4.2 set to be updated
–> Processing Dependency: perl(DBI) for package: mysql
–> Processing Dependency: libncurses.so.5 for package: mysql
–> Processing Dependency: libz.so.1 for package: mysql
–> Processing Dependency: libgcc_s.so.1(GLIBC_2.0) for package: mysql
–> Processing Dependency: libstdc++.so.6(CXXABI_1.3) for package: mysql
–> Processing Dependency: libstdc++.so.6 for package: mysql
–> Processing Dependency: libgcc_s.so.1 for package: mysql
—> Package mysql.x86_64 0:5.0.77-4.el5_4.2 set to be updated
—> Package mysql-devel.i386 0:5.0.77-4.el5_4.2 set to be updated
–> Processing Dependency: openssl-devel for package: mysql-devel
—> Package mysql-devel.x86_64 0:5.0.77-4.el5_4.2 set to be updated
—> Package mysql-server.x86_64 0:5.0.77-4.el5_4.2 set to be updated
—> Package openssl.i686 0:0.9.8e-12.el5_4.6 set to be updated
—> Package perl-Crypt-SSLeay.x86_64 0:0.51-11.el5 set to be updated
—> Package perl-DBD-MySQL.x86_64 0:3.0007-2.el5 set to be updated
—> Package perl-DBD-Pg.x86_64 0:1.49-2.el5_3.1 set to be updated
—> Package perl-XML-Simple.noarch 0:2.14-4.fc6 set to be updated
–> Processing Dependency: perl(XML::Parser) for package: perl-XML-Simple
—> Package php.x86_64 0:5.1.6-27.el5 set to be updated
–> Processing Dependency: php-common = 5.1.6-27.el5 for package: php
–> Processing Dependency: php-cli = 5.1.6-27.el5 for package: php
–> Processing Dependency: libgmp.so.3()(64bit) for package: php
—> Package php-gd.x86_64 0:5.1.6-27.el5 set to be updated
–> Processing Dependency: libfreetype.so.6()(64bit) for package: php-gd
—> Package php-imap.x86_64 0:5.1.6-27.el5 set to be updated
–> Processing Dependency: libc-client.so.1()(64bit) for package: php-imap
—> Package php-mbstring.x86_64 0:5.1.6-27.el5 set to be updated
—> Package php-mysql.x86_64 0:5.1.6-27.el5 set to be updated
–> Processing Dependency: php-pdo for package: php-mysql
—> Package php-odbc.x86_64 0:5.1.6-27.el5 set to be updated
–> Processing Dependency: libodbc.so.1()(64bit) for package: php-odbc
—> Package php-pear.noarch 1:1.4.9-6.el5 set to be updated
–> Processing Dependency: php-devel for package: php-pear
—> Package php-pgsql.x86_64 0:5.1.6-27.el5 set to be updated
—> Package php-snmp.x86_64 0:5.1.6-27.el5 set to be updated
—> Package php-xmlrpc.x86_64 0:5.1.6-27.el5 set to be updated
—> Package postfix.x86_64 2:2.3.3-2.1.el5_2 set to be updated
—> Package postgresql.x86_64 0:8.1.18-2.el5_4.1 set to be updated
—> Package postgresql-server.x86_64 0:8.1.18-2.el5_4.1 set to be updated
—> Package ruby.x86_64 0:1.8.5-5.el5_4.8 set to be updated
–> Processing Dependency: ruby-libs = 1.8.5-5.el5_4.8 for package: ruby
–> Processing Dependency: libruby.so.1.8()(64bit) for package: ruby
—> Package ruby-devel.i386 0:1.8.5-5.el5_4.8 set to be updated
–> Processing Dependency: libruby.so.1.8 for package: ruby-devel
—> Package ruby-devel.x86_64 0:1.8.5-5.el5_4.8 set to be updated
—> Package rubygems.noarch 0:0.9.2-1.el5 set to be updated
–> Processing Dependency: ruby-rdoc for package: rubygems
—> Package spamassassin.x86_64 0:3.2.5-1.el5 set to be updated
–> Processing Dependency: perl(IO::Zlib) >= 1.04 for package: spamassassin
–> Processing Dependency: perl-HTML-Parser >= 3.43 for package: spamassassin
–> Processing Dependency: perl(HTML::Parser) >= 3.43 for package: spamassassin
–> Processing Dependency: perl(Archive::Tar) >= 1.23 for package: spamassassin
–> Processing Dependency: perl(HTTP::Date) for package: spamassassin
–> Processing Dependency: perl(IO::Socket::INET6) for package: spamassassin
–> Processing Dependency: perl(LWP::UserAgent) for package: spamassassin
–> Processing Dependency: perl(IO::Socket::SSL) for package: spamassassin
–> Processing Dependency: perl(Net::DNS) for package: spamassassin
–> Processing Dependency: perl(Archive::Tar) for package: spamassassin
–> Processing Dependency: perl(Digest::SHA1) for package: spamassassin
—> Package subversion.i386 0:1.4.2-4.el5_3.1 set to be updated
–> Processing Dependency: perl(URI) >= 1.17 for package: subversion
–> Processing Dependency: neon >= 0.25.5-6.el5 for package: subversion
–> Processing Dependency: libneon.so.25 for package: subversion
–> Processing Dependency: libapr-1.so.0 for package: subversion
–> Processing Dependency: libaprutil-1.so.0 for package: subversion
–> Processing Dependency: libdb-4.3.so for package: subversion
–> Processing Dependency: libexpat.so.0 for package: subversion
—> Package subversion.x86_64 0:1.4.2-4.el5_3.1 set to be updated
—> Package webalizer.x86_64 0:2.01_10-30.1 set to be updated
–> Processing Dependency: libgd.so.2()(64bit) for package: webalizer
—> Package apr.i386 0:1.2.7-11.el5_3.1 set to be updated
—> Package apr-util.i386 0:1.2.7-11.el5 set to be updated
–> Processing Dependency: libsqlite3.so.0 for package: apr-util
–> Processing Dependency: libpq.so.4 for package: apr-util
—> Package cyrus-sasl-lib.i386 0:2.1.22-5.el5_4.3 set to be updated
—> Package db4.i386 0:4.3.29-10.el5 set to be updated
—> Package distcache.x86_64 0:1.4.5-14.1 set to be updated
—> Package e2fsprogs-libs.i386 0:1.39-23.el5 set to be updated
–> Processing Dependency: libdevmapper.so.1.02 for package: e2fsprogs-libs
–> Processing Dependency: libdevmapper.so.1.02(Base) for package: e2fsprogs-libs
—> Package expat.i386 0:1.95.8-8.3.el5_4.2 set to be updated
—> Package freetype.x86_64 0:2.2.1-21.el5_3 set to be updated
—> Package gd.x86_64 0:2.0.33-9.4.el5_4.2 set to be updated
–> Processing Dependency: pkgconfig for package: gd
–> Processing Dependency: libXpm.so.4()(64bit) for package: gd
–> Processing Dependency: libfontconfig.so.1()(64bit) for package: gd
–> Processing Dependency: libX11.so.6()(64bit) for package: gd
—> Package gdbm.i386 0:1.8.0-26.2.1 set to be updated
—> Package gmp.x86_64 0:4.1.4-10.el5 set to be updated
—> Package krb5-libs.i386 0:1.6.1-36.el5_4.1 set to be updated
–> Processing Dependency: libkeyutils.so.1 for package: krb5-libs
–> Processing Dependency: libkeyutils.so.1(KEYUTILS_0.3) for package: krb5-libs
–> Processing Dependency: libselinux.so.1 for package: krb5-libs
—> Package libc-client.x86_64 0:2004g-2.2.1 set to be updated
—> Package libgcc.i386 0:4.1.2-48.el5 set to be updated
—> Package libstdc++.i386 0:4.1.2-48.el5 set to be updated
—> Package ncurses.i386 0:5.5-24.20060715 set to be updated
—> Package neon.i386 0:0.25.5-10.el5_4.1 set to be updated
—> Package neon.x86_64 0:0.25.5-10.el5_4.1 set to be updated
—> Package openldap.i386 0:2.3.43-12.el5 set to be updated
—> Package openssl-devel.x86_64 0:0.9.8e-12.el5_4.6 set to be updated
–> Processing Dependency: zlib-devel for package: openssl-devel
–> Processing Dependency: krb5-devel for package: openssl-devel
—> Package pam.i386 0:0.99.6.2-6.el5_4.1 set to be updated
–> Processing Dependency: libcrack.so.2 for package: pam
–> Processing Dependency: libaudit.so.0 for package: pam
—> Package perl-Archive-Tar.noarch 0:1.30-1.fc6 set to be updated
–> Processing Dependency: perl(Compress::Zlib) for package: perl-Archive-Tar
—> Package perl-BSD-Resource.x86_64 0:1.28-1.fc6.1 set to be updated
—> Package perl-DBI.x86_64 0:1.52-2.el5 set to be updated
—> Package perl-Digest-SHA1.x86_64 0:2.11-1.2.1 set to be updated
—> Package perl-HTML-Parser.x86_64 0:3.55-1.fc6 set to be updated
–> Processing Dependency: perl-HTML-Tagset >= 3.03 for package: perl-HTML-Parser
–> Processing Dependency: perl(HTML::Tagset) for package: perl-HTML-Parser
—> Package perl-IO-Socket-INET6.noarch 0:2.51-2.fc6 set to be updated
–> Processing Dependency: perl(Socket6) for package: perl-IO-Socket-INET6
—> Package perl-IO-Socket-SSL.noarch 0:1.01-1.fc6 set to be updated
–> Processing Dependency: perl(Net::SSLeay) >= 1.21 for package: perl-IO-Socket-SSL
—> Package perl-IO-Zlib.noarch 0:1.04-4.2.1 set to be updated
—> Package perl-Net-DNS.x86_64 0:0.59-3.el5 set to be updated
–> Processing Dependency: perl(Digest::HMAC_MD5) for package: perl-Net-DNS
–> Processing Dependency: perl(Net::IP) for package: perl-Net-DNS
—> Package perl-URI.noarch 0:1.35-3 set to be updated
—> Package perl-XML-Parser.x86_64 0:2.34-6.1.2.2.1 set to be updated
—> Package perl-libwww-perl.noarch 0:5.805-1.1.1 set to be updated
—> Package php-cli.x86_64 0:5.1.6-27.el5 set to be updated
—> Package php-common.x86_64 0:5.1.6-27.el5 set to be updated
—> Package php-devel.x86_64 0:5.1.6-27.el5 set to be updated
–> Processing Dependency: autoconf for package: php-devel
–> Processing Dependency: automake for package: php-devel
—> Package php-pdo.x86_64 0:5.1.6-27.el5 set to be updated
—> Package ruby-libs.i386 0:1.8.5-5.el5_4.8 set to be updated
–> Processing Dependency: libtermcap.so.2 for package: ruby-libs
–> Processing Dependency: libreadline.so.5 for package: ruby-libs
—> Package ruby-libs.x86_64 0:1.8.5-5.el5_4.8 set to be updated
—> Package ruby-rdoc.x86_64 0:1.8.5-5.el5_4.8 set to be updated
–> Processing Dependency: ruby-irb = 1.8.5-5.el5_4.8 for package: ruby-rdoc
—> Package unixODBC.x86_64 0:2.2.11-7.1 set to be updated
—> Package zlib.i386 0:1.2.3-3 set to be updated
—> Package audit-libs.i386 0:1.7.17-3.el5 set to be updated
—> Package autoconf.noarch 0:2.59-12 set to be updated
–> Processing Dependency: imake for package: autoconf
—> Package automake.noarch 0:1.9.6-2.3.el5 set to be updated
—> Package cracklib.i386 0:2.8.9-3.3 set to be updated
—> Package device-mapper.i386 0:1.02.39-1.el5 set to be updated
–> Processing Dependency: libsepol.so.1 for package: device-mapper
—> Package fontconfig.x86_64 0:2.4.1-7.el5 set to be updated
—> Package keyutils-libs.i386 0:1.2-1.el5 set to be updated
—> Package krb5-devel.x86_64 0:1.6.1-36.el5_4.1 set to be updated
–> Processing Dependency: libselinux-devel for package: krb5-devel
–> Processing Dependency: e2fsprogs-devel for package: krb5-devel
–> Processing Dependency: keyutils-libs-devel for package: krb5-devel
—> Package libX11.x86_64 0:1.0.3-11.el5 set to be updated
–> Processing Dependency: xorg-x11-filesystem >= 0.99.2-3 for package: libX11
–> Processing Dependency: libXdmcp.so.6()(64bit) for package: libX11
–> Processing Dependency: libXau.so.6()(64bit) for package: libX11
—> Package libXpm.x86_64 0:3.5.5-3 set to be updated
—> Package libselinux.i386 0:1.33.4-5.5.el5 set to be updated
—> Package libtermcap.i386 0:2.0.8-46.1 set to be updated
—> Package perl-Compress-Zlib.x86_64 0:1.42-1.fc6 set to be updated
—> Package perl-Digest-HMAC.noarch 0:1.01-15 set to be updated
—> Package perl-HTML-Tagset.noarch 0:3.10-2.1.1 set to be updated
—> Package perl-Net-IP.noarch 0:1.25-2.fc6 set to be updated
—> Package perl-Net-SSLeay.x86_64 0:1.30-4.fc6 set to be updated
—> Package perl-Socket6.x86_64 0:0.19-3.fc6 set to be updated
—> Package pkgconfig.x86_64 1:0.21-2.el5 set to be updated
—> Package postgresql-libs.i386 0:8.1.18-2.el5_4.1 set to be updated
—> Package readline.i386 0:5.1-3.el5 set to be updated
—> Package ruby-irb.x86_64 0:1.8.5-5.el5_4.8 set to be updated
—> Package sqlite.i386 0:3.3.6-5 set to be updated
—> Package zlib-devel.x86_64 0:1.2.3-3 set to be updated
—> Package e2fsprogs-devel.x86_64 0:1.39-23.el5 set to be updated
—> Package imake.x86_64 0:1.0.2-3 set to be updated
—> Package keyutils-libs-devel.x86_64 0:1.2-1.el5 set to be updated
—> Package libXau.x86_64 0:1.0.1-3.1 set to be updated
—> Package libXdmcp.x86_64 0:1.0.1-2.1 set to be updated
—> Package libselinux-devel.x86_64 0:1.33.4-5.5.el5 set to be updated
–> Processing Dependency: libsepol-devel >= 1.15.2-1 for package: libselinux-devel
—> Package libsepol.i386 0:1.15.2-3.el5 set to be updated
—> Package xorg-x11-filesystem.noarch 0:7.1-2.fc6 set to be updated
—> Package libsepol-devel.x86_64 0:1.15.2-3.el5 set to be updated
–> Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository Size
Installing:
bind x86_64 30:9.3.6-4.P1.el5_4.2 base 986 k
caching-nameserver x86_64 30:9.3.6-4.P1.el5_4.2 base 61 k
cyrus-sasl i386 2.1.22-5.el5_4.3 base 1.2 M
cyrus-sasl-gssapi i386 2.1.22-5.el5_4.3 base 29 k
cyrus-sasl-gssapi x86_64 2.1.22-5.el5_4.3 base 30 k
dovecot x86_64 1.0.7-7.el5 base 1.7 M
mailman x86_64 3:2.1.9-4.el5 base 9.8 M
mod_dav_svn x86_64 1.4.2-4.el5_3.1 base 70 k
mod_perl x86_64 2.0.4-6.el5 base 4.0 M
mod_python x86_64 3.2.8-3.1 base 260 k
mod_ssl x86_64 2:2.2.3-22.el5.1vm virtualmin 335 k
mysql i386 5.0.77-4.el5_4.2 base 4.8 M
mysql x86_64 5.0.77-4.el5_4.2 base 4.8 M
mysql-devel i386 5.0.77-4.el5_4.2 base 2.4 M
mysql-devel x86_64 5.0.77-4.el5_4.2 base 2.5 M
mysql-server x86_64 5.0.77-4.el5_4.2 base 9.8 M
openssl i686 0.9.8e-12.el5_4.6 base 1.4 M
perl-Crypt-SSLeay x86_64 0.51-11.el5 base 45 k
perl-DBD-MySQL x86_64 3.0007-2.el5 base 148 k
perl-DBD-Pg x86_64 1.49-2.el5_3.1 base 115 k
perl-XML-Simple noarch 2.14-4.fc6 base 68 k
php x86_64 5.1.6-27.el5 base 2.3 M
php-gd x86_64 5.1.6-27.el5 base 117 k
php-imap x86_64 5.1.6-27.el5 base 54 k
php-mbstring x86_64 5.1.6-27.el5 base 1.0 M
php-mysql x86_64 5.1.6-27.el5 base 89 k
php-odbc x86_64 5.1.6-27.el5 base 54 k
php-pear noarch 1:1.4.9-6.el5 base 344 k
php-pgsql x86_64 5.1.6-27.el5 base 70 k
php-snmp x86_64 5.1.6-27.el5 base 30 k
php-xmlrpc x86_64 5.1.6-27.el5 base 57 k
postfix x86_64 2:2.3.3-2.1.el5_2 base 3.7 M
postgresql x86_64 8.1.18-2.el5_4.1 base 2.9 M
postgresql-server x86_64 8.1.18-2.el5_4.1 base 3.9 M
ruby x86_64 1.8.5-5.el5_4.8 base 274 k
ruby-devel i386 1.8.5-5.el5_4.8 base 556 k
ruby-devel x86_64 1.8.5-5.el5_4.8 base 564 k
rubygems noarch 0.9.2-1.el5 virtualmin 497 k
spamassassin x86_64 3.2.5-1.el5 base 1.0 M
subversion i386 1.4.2-4.el5_3.1 base 2.3 M
subversion x86_64 1.4.2-4.el5_3.1 base 2.4 M
webalizer x86_64 2.01_10-30.1 base 112 k
Updating:
httpd x86_64 1:2.2.3-22.el5.1vm virtualmin 3.1 M
Installing for dependencies:
apr i386 1.2.7-11.el5_3.1 base 123 k
apr-util i386 1.2.7-11.el5 base 80 k
audit-libs i386 1.7.17-3.el5 base 78 k
autoconf noarch 2.59-12 base 647 k
automake noarch 1.9.6-2.3.el5 base 476 k
cracklib i386 2.8.9-3.3 base 58 k
cyrus-sasl-lib i386 2.1.22-5.el5_4.3 base 127 k
db4 i386 4.3.29-10.el5 base 909 k
device-mapper i386 1.02.39-1.el5 base 719 k
distcache x86_64 1.4.5-14.1 base 121 k
e2fsprogs-devel x86_64 1.39-23.el5 base 632 k
e2fsprogs-libs i386 1.39-23.el5 base 118 k
expat i386 1.95.8-8.3.el5_4.2 base 77 k
fontconfig x86_64 2.4.1-7.el5 base 175 k
freetype x86_64 2.2.1-21.el5_3 base 309 k
gd x86_64 2.0.33-9.4.el5_4.2 base 155 k
gdbm i386 1.8.0-26.2.1 base 27 k
gmp x86_64 4.1.4-10.el5 base 201 k
imake x86_64 1.0.2-3 base 319 k
keyutils-libs i386 1.2-1.el5 base 18 k
keyutils-libs-devel x86_64 1.2-1.el5 base 27 k
krb5-devel x86_64 1.6.1-36.el5_4.1 base 1.9 M
krb5-libs i386 1.6.1-36.el5_4.1 base 661 k
libX11 x86_64 1.0.3-11.el5 base 798 k
libXau x86_64 1.0.1-3.1 base 18 k
libXdmcp x86_64 1.0.1-2.1 base 19 k
libXpm x86_64 3.5.5-3 base 44 k
libc-client x86_64 2004g-2.2.1 base 515 k
libgcc i386 4.1.2-48.el5 base 95 k
libselinux i386 1.33.4-5.5.el5 base 76 k
libselinux-devel x86_64 1.33.4-5.5.el5 base 149 k
libsepol i386 1.15.2-3.el5 base 128 k
libsepol-devel x86_64 1.15.2-3.el5 base 192 k
libstdc++ i386 4.1.2-48.el5 base 362 k
libtermcap i386 2.0.8-46.1 base 14 k
ncurses i386 5.5-24.20060715 base 1.1 M
neon i386 0.25.5-10.el5_4.1 base 101 k
neon x86_64 0.25.5-10.el5_4.1 base 100 k
openldap i386 2.3.43-12.el5 base 294 k
openssl-devel x86_64 0.9.8e-12.el5_4.6 base 1.9 M
pam i386 0.99.6.2-6.el5_4.1 base 976 k
perl-Archive-Tar noarch 1.30-1.fc6 base 47 k
perl-BSD-Resource x86_64 1.28-1.fc6.1 base 29 k
perl-Compress-Zlib x86_64 1.42-1.fc6 base 52 k
perl-DBI x86_64 1.52-2.el5 base 600 k
perl-Digest-HMAC noarch 1.01-15 base 12 k
perl-Digest-SHA1 x86_64 2.11-1.2.1 base 49 k
perl-HTML-Parser x86_64 3.55-1.fc6 base 92 k
perl-HTML-Tagset noarch 3.10-2.1.1 base 15 k
perl-IO-Socket-INET6 noarch 2.51-2.fc6 base 13 k
perl-IO-Socket-SSL noarch 1.01-1.fc6 base 49 k
perl-IO-Zlib noarch 1.04-4.2.1 base 15 k
perl-Net-DNS x86_64 0.59-3.el5 base 215 k
perl-Net-IP noarch 1.25-2.fc6 base 31 k
perl-Net-SSLeay x86_64 1.30-4.fc6 base 192 k
perl-Socket6 x86_64 0.19-3.fc6 base 21 k
perl-URI noarch 1.35-3 base 116 k
perl-XML-Parser x86_64 2.34-6.1.2.2.1 base 210 k
perl-libwww-perl noarch 5.805-1.1.1 base 376 k
php-cli x86_64 5.1.6-27.el5 base 2.2 M
php-common x86_64 5.1.6-27.el5 base 153 k
php-devel x86_64 5.1.6-27.el5 base 503 k
php-pdo x86_64 5.1.6-27.el5 base 66 k
pkgconfig x86_64 1:0.21-2.el5 base 61 k
postgresql-libs i386 8.1.18-2.el5_4.1 base 196 k
readline i386 5.1-3.el5 base 223 k
ruby-irb x86_64 1.8.5-5.el5_4.8 base 69 k
ruby-libs i386 1.8.5-5.el5_4.8 base 1.6 M
ruby-libs x86_64 1.8.5-5.el5_4.8 base 1.6 M
ruby-rdoc x86_64 1.8.5-5.el5_4.8 base 134 k
sqlite i386 3.3.6-5 base 213 k
unixODBC x86_64 2.2.11-7.1 base 835 k
xorg-x11-filesystem noarch 7.1-2.fc6 base 5.4 k
zlib i386 1.2.3-3 base 50 k
zlib-devel x86_64 1.2.3-3 base 102 k
Transaction Summary
Install 117 Package(s)
Upgrade 1 Package(s)
Total download size: 94 M
Downloading Packages:
Total 575 kB/s | 94 MB 02:48
Running rpm_check_debug
Running Transaction Test
Finished Transaction Test
Transaction Test Succeeded
Running Transaction
Installing : php-common 1/119
Updating : httpd 2/119
Installing : perl-DBI 3/119
Installing : mysql 4/119
Installing : php-pdo 5/119
Installing : freetype 6/119
Installing : perl-Compress-Zlib 7/119
Installing : perl-Digest-SHA1 8/119
Installing : gmp 9/119
Installing : php-cli 10/119
Installing : ruby-libs 11/119
Installing : neon 12/119
Installing : zlib 13/119
Installing : cyrus-sasl-lib 14/119
Installing : libgcc 15/119
Installing : ncurses 16/119
Installing : expat 17/119
Installing : libsepol 18/119
Installing : libselinux 19/119
Installing : libstdc++ 20/119
Installing : db4 21/119
Installing : readline 22/119
Installing : gdbm 23/119
Installing : keyutils-libs 24/119
Installing : php 25/119
Installing : fontconfig 26/119
Installing : perl-DBD-MySQL 27/119
Installing : postgresql 28/119
Installing : distcache 29/119
Installing : libXau 30/119
Installing : perl-Net-SSLeay 31/119
Installing : pkgconfig 32/119
Installing : perl-Socket6 33/119
Installing : imake 34/119
Installing : bind 35/119
Installing : libXdmcp 36/119
Installing : unixODBC 37/119
Installing : perl-BSD-Resource 38/119
Installing : perl-URI 39/119
Installing : autoconf 40/119
Installing : perl-IO-Zlib 41/119
Installing : subversion 42/119
Installing : perl-Archive-Tar 43/119
Installing : automake 44/119
Installing : php-devel 45/119
Installing : perl-IO-Socket-INET6 46/119
Installing : perl-IO-Socket-SSL 47/119
Installing : keyutils-libs-devel 48/119
Installing : libsepol-devel 49/119
Installing : libselinux-devel 50/119
Installing : zlib-devel 51/119
Installing : perl-Digest-HMAC 52/119
Installing : perl-Net-IP 53/119
Installing : perl-Net-DNS 54/119
Installing : xorg-x11-filesystem 55/119
Installing : libX11 56/119
Installing : libXpm 57/119
Installing : gd 58/119
Installing : perl-HTML-Tagset 59/119
Installing : perl-HTML-Parser 60/119
Installing : sqlite 61/119
Installing : device-mapper 62/119
Installing : e2fsprogs-libs 63/119
Installing : krb5-libs 64/119
Installing : openssl 65/119
Installing : openldap 66/119
Installing : mysql 67/119
Installing : postgresql-libs 68/119
Installing : apr 69/119
Installing : apr-util 70/119
Installing : neon 71/119
Installing : subversion 72/119
Installing : audit-libs 73/119
Installing : libtermcap 74/119
Installing : ruby-libs 75/119
Installing : ruby 76/119
Installing : cracklib 77/119
Installing : mod_dav_svn 78/119
Installing : postgresql-server 79/119
Installing : mysql-server 80/119
Installing : mod_ssl 81/119
Installing : dovecot 82/119
Installing : webalizer 83/119
Installing : mod_perl 84/119
Installing : php-odbc 85/119
Installing : cyrus-sasl-gssapi 86/119
Installing : php-gd 87/119
Installing : php-pgsql 88/119
Installing : php-mysql 89/119
Installing : perl-DBD-Pg 90/119
Installing : mailman 91/119
Installing : mod_python 92/119
Installing : php-xmlrpc 93/119
Installing : php-mbstring 94/119
Installing : php-snmp 95/119
Installing : perl-Crypt-SSLeay 96/119
Installing : perl-libwww-perl 97/119
Installing : perl-XML-Parser 98/119
Installing : ruby-irb 99/119
Installing : ruby-rdoc 100/119
Installing : e2fsprogs-devel 101/119
Installing : krb5-devel 102/119
Installing : spamassassin 103/119
Installing : openssl-devel 104/119
Installing : mysql-devel 105/119
Installing : mysql-devel 106/119
Installing : rubygems 107/119
Installing : perl-XML-Simple 108/119
Installing : ruby-devel 109/119
Installing : ruby-devel 110/119
Installing : php-pear 111/119
Installing : caching-nameserver 112/119
Installing : pam 113/119
Installing : libc-client 114/119
Installing : cyrus-sasl 115/119
Installing : php-imap 116/119
Installing : postfix 117/119
Installing : cyrus-sasl-gssapi 118/119
Cleanup : httpd 119/119
Installed:
Dependency Installed:
zlib.i386 0:1.2.3-3
Updated:
Complete!
INFO - 2010-05-19 23:54:20 - /usr/bin/yum -y -d 2 install bind bind-utils caching-nameserver httpd postfix bind spamassassin procmail perl-DBD-Pg perl-DBD-MySQL quota iptables openssl python mailman subversion mysql mysql-server mysql-devel postgresql postgresql-server rh-postgresql rh-postgresql-server logrotate webalizer php php-domxl php-gd php-imap php-mysql php-odbc php-pear php-pgsql php-snmp php-xmlrpc php-mbstring mod_perl mod_python cyrus-sasl dovecot spamassassin mod_dav_svn cyrus-sasl-gssapi mod_ssl ruby ruby-devel rubygems perl-XML-Simple perl-Crypt-SSLeay: Succeeded.
INFO - 2010-05-19 23:54:20 - Succeeded.
INFO - 2010-05-19 23:54:20 - Installing Virtualmin and all related packages now using the command:
INFO - 2010-05-19 23:54:20 - yum clean all
INFO - 2010-05-19 23:54:21 - yum -y -d 2 install virtualmin-base
Determining fastest mirrors
- addons: centos.mirror.iweb.ca
- base: centos.mirror.iweb.ca
- extras: centos.mirror.iweb.ca
- updates: centos.mirror.iweb.ca
—> Package virtualmin-base.noarch 0:1.0-61.rh set to be updated
–> Processing Dependency: usermin >= 1.160 for package: virtualmin-base
–> Processing Dependency: webmin >= 1.334 for package: virtualmin-base
–> Processing Dependency: wbt-virtual-server-mobile for package: virtualmin-base
–> Processing Dependency: wbm-virtualmin-svn for package: virtualmin-base
–> Processing Dependency: wbm-virtualmin-init for package: virtualmin-base
–> Processing Dependency: scponly for package: virtualmin-base
–> Processing Dependency: clamav for package: virtualmin-base
–> Processing Dependency: wbm-virtualmin-dav for package: virtualmin-base
–> Processing Dependency: proftpd for package: virtualmin-base
–> Processing Dependency: cyrus-sasl-plain for package: virtualmin-base
–> Processing Dependency: wbm-virtualmin-htpasswd for package: virtualmin-base
–> Processing Dependency: wbm-virtualmin-mailman for package: virtualmin-base
–> Processing Dependency: procmail-wrapper for package: virtualmin-base
–> Processing Dependency: /usr/bin/freshclam for package: virtualmin-base
–> Processing Dependency: wbm-security-updates for package: virtualmin-base
–> Processing Dependency: wbm-php-pear for package: virtualmin-base
–> Processing Dependency: wbt-virtual-server-theme for package: virtualmin-base
–> Processing Dependency: wbm-virtualmin-awstats for package: virtualmin-base
–> Processing Dependency: cyrus-sasl-md5 for package: virtualmin-base
–> Processing Dependency: mod_fcgid for package: virtualmin-base
–> Processing Dependency: wbm-virtualmin-registrar for package: virtualmin-base
–> Processing Dependency: /usr/sbin/clamd for package: virtualmin-base
–> Processing Dependency: wbm-virtual-server for package: virtualmin-base
–> Processing Dependency: awstats for package: virtualmin-base
–> Processing Dependency: ust-virtual-server-theme for package: virtualmin-base
–> Processing Dependency: wbm-ruby-gems for package: virtualmin-base
—> Package awstats.noarch 0:6.8-1.el5 set to be updated
—> Package clamav.x86_64 0:0.95.2-1.vm.el5 set to be updated
–> Processing Dependency: clamav-lib = 0.95.2-1.vm.el5 for package: clamav
–> Processing Dependency: data(clamav) for package: clamav
–> Processing Dependency: libclamav.so.6(CLAMAV_PUBLIC)(64bit) for package: clamav
–> Processing Dependency: libclamav.so.6(CLAMAV_PRIVATE)(64bit) for package: clamav
–> Processing Dependency: libclamav.so.6()(64bit) for package: clamav
—> Package clamav-server.x86_64 0:0.95.2-1.vm.el5 set to be updated
–> Processing Dependency: clamav-filesystem = 0.95.2-1.vm.el5 for package: clamav-server
–> Processing Dependency: init(clamav-server) for package: clamav-server
—> Package clamav-update.x86_64 0:0.95.2-1.vm.el5 set to be updated
—> Package cyrus-sasl-md5.x86_64 0:2.1.22-5.el5_4.3 set to be updated
—> Package cyrus-sasl-plain.x86_64 0:2.1.22-5.el5_4.3 set to be updated
—> Package mod_fcgid.x86_64 0:2.2-1.el5.vm set to be updated
—> Package procmail-wrapper.x86_64 0:1.0-1.vm set to be updated
—> Package proftpd.x86_64 0:1.3.0a-3el5 set to be updated
—> Package scponly.x86_64 0:4.6-1.vm set to be updated
—> Package usermin.noarch 0:1.430-1 set to be updated
—> Package ust-virtual-server-theme.noarch 2:6.9-1 set to be updated
—> Package wbm-php-pear.noarch 2:1.5-1 set to be updated
—> Package wbm-ruby-gems.noarch 2:1.4-1 set to be updated
—> Package wbm-security-updates.noarch 2:4.0-1 set to be updated
—> Package wbm-virtual-server.noarch 0:3.78.gpl-1 set to be updated
—> Package wbm-virtualmin-awstats.noarch 2:4.3-1 set to be updated
—> Package wbm-virtualmin-dav.noarch 2:3.3-1 set to be updated
—> Package wbm-virtualmin-htpasswd.noarch 2:2.3-1 set to be updated
—> Package wbm-virtualmin-init.noarch 2:2.1-1 set to be updated
—> Package wbm-virtualmin-mailman.noarch 2:5.9-1 set to be updated
—> Package wbm-virtualmin-registrar.noarch 2:2.0-1 set to be updated
—> Package wbm-virtualmin-svn.noarch 2:4.7-1 set to be updated
—> Package wbt-virtual-server-mobile.noarch 2:2.3-1 set to be updated
—> Package wbt-virtual-server-theme.noarch 2:7.7-1 set to be updated
—> Package webmin.noarch 0:1.510-1 set to be updated
—> Package clamav-data.x86_64 0:0.95.2-1.vm.el5 set to be updated
—> Package clamav-filesystem.x86_64 0:0.95.2-1.vm.el5 set to be updated
–> Processing Dependency: fedora-usermgmt for package: clamav-filesystem
—> Package clamav-lib.x86_64 0:0.95.2-1.vm.el5 set to be updated
—> Package clamav-server-sysv.x86_64 0:0.95.2-1.vm.el5 set to be updated
—> Package fedora-usermgmt.noarch 0:0.9-1.el5 set to be updated
–> Processing Dependency: fedora-usermgmt-core = 0.9-1.el5 for package: fedora-usermgmt
–> Processing Dependency: instance(fedora-usermgmt) for package: fedora-usermgmt
–> Processing Dependency: setup(fedora-usermgmt) for package: fedora-usermgmt
—> Package fedora-usermgmt-core.noarch 0:0.9-1.el5 set to be updated
—> Package fedora-usermgmt-default-fedora-setup.noarch 0:0.9-1.el5 set to be updated
—> Package fedora-usermgmt-shadow-utils.noarch 0:0.9-1.el5 set to be updated
Installing:
virtualmin-base noarch 1.0-61.rh virtualmin 27 k
awstats noarch 6.8-1.el5 virtualmin 1.2 M
clamav x86_64 0.95.2-1.vm.el5 virtualmin 837 k
clamav-data x86_64 0.95.2-1.vm.el5 virtualmin 21 M
clamav-filesystem x86_64 0.95.2-1.vm.el5 virtualmin 18 k
clamav-lib x86_64 0.95.2-1.vm.el5 virtualmin 888 k
clamav-server x86_64 0.95.2-1.vm.el5 virtualmin 92 k
clamav-server-sysv x86_64 0.95.2-1.vm.el5 virtualmin 18 k
clamav-update x86_64 0.95.2-1.vm.el5 virtualmin 82 k
cyrus-sasl-md5 x86_64 2.1.22-5.el5_4.3 base 47 k
cyrus-sasl-plain x86_64 2.1.22-5.el5_4.3 base 27 k
fedora-usermgmt noarch 0.9-1.el5 virtualmin 6.7 k
fedora-usermgmt-core noarch 0.9-1.el5 virtualmin 7.7 k
noarch 0.9-1.el5 virtualmin 6.6 k
noarch 0.9-1.el5 virtualmin 7.4 k
mod_fcgid x86_64 2.2-1.el5.vm virtualmin 124 k
procmail-wrapper x86_64 1.0-1.vm virtualmin 4.8 k
proftpd x86_64 1.3.0a-3el5 virtualmin 1.0 M
scponly x86_64 4.6-1.vm virtualmin 24 k
usermin noarch 1.430-1 virtualmin-universal 6.2 M
ust-virtual-server-theme noarch 2:6.9-1 virtualmin-universal 2.2 M
wbm-php-pear noarch 2:1.5-1 virtualmin-universal 14 k
wbm-ruby-gems noarch 2:1.4-1 virtualmin-universal 14 k
wbm-security-updates noarch 2:4.0-1 virtualmin-universal 29 k
wbm-virtual-server noarch 3.78.gpl-1 virtualmin-universal 1.4 M
wbm-virtualmin-awstats noarch 2:4.3-1 virtualmin-universal 39 k
wbm-virtualmin-dav noarch 2:3.3-1 virtualmin-universal 18 k
wbm-virtualmin-htpasswd noarch 2:2.3-1 virtualmin-universal 17 k
wbm-virtualmin-init noarch 2:2.1-1 virtualmin-universal 23 k
wbm-virtualmin-mailman noarch 2:5.9-1 virtualmin-universal 42 k
wbm-virtualmin-registrar noarch 2:2.0-1 virtualmin-universal 58 k
wbm-virtualmin-svn noarch 2:4.7-1 virtualmin-universal 43 k
wbt-virtual-server-mobile noarch 2:2.3-1 virtualmin-universal 69 k
wbt-virtual-server-theme noarch 2:7.7-1 virtualmin-universal 2.2 M
webmin noarch 1.510-1 virtualmin-universal 15 M
Transaction Summary
Install 35 Package(s)
Upgrade 0 Package(s)
Total download size: 53 M
Total 113 kB/s | 53 MB 07:58
Running Transaction
Installing : cyrus-sasl-md5 1/35
Installing : proftpd 2/35
Installing : cyrus-sasl-plain 3/35
Installing : mod_fcgid 4/35
Installing : procmail-wrapper 5/35Operating system is CentOS Linux
Installing : webmin 6/35Webmin install complete. You can now login to https://oriental.allnetsols.com:10000/
as root with your root password.
Installing : wbm-virtual-server 7/35virtual-server
Installing : usermin 8/35Usermin install complete. You can now login to https://oriental.allnetsols.com:20000/
as any user on your system.
Installing : ust-virtual-server-theme 9/35
Installing : wbm-virtualmin-dav 10/35virtualmin-dav
Installing : wbm-virtualmin-mailman 11/35virtualmin-mailman
Installing : wbm-virtualmin-registrar 12/35virtualmin-registrar
Installing : wbm-virtualmin-awstats 13/35virtualmin-awstats
Installing : wbm-virtualmin-svn 14/35virtualmin-svn
Installing : wbm-virtualmin-htpasswd 15/35virtualmin-htpasswd
Installing : wbt-virtual-server-theme 16/35
Installing : wbm-security-updates 17/35security-updates
Installing : wbm-ruby-gems 18/35ruby-gems
Installing : wbt-virtual-server-mobile 19/35
Installing : wbm-virtualmin-init 20/35virtualmin-init
Installing : wbm-php-pear 21/35php-pear
Installing : awstats 22/35
Installing : scponly 23/35
Installing : fedora-usermgmt-default-fedora-setup 24/35
Installing : fedora-usermgmt-core 25/35
Installing : fedora-usermgmt-shadow-utils 26/35
Installing : fedora-usermgmt 27/35
Installing : clamav-filesystem 28/35
Installing : clamav-data 29/35
Installing : clamav-lib 30/35
Installing : clamav-update 31/35
Installing : clamav 32/35
Installing : clamav-server 33/35
Installing : virtualmin-base 34/35Setting Webmin theme
Setting Usermin theme
Configuring Postfix
Enabling Postfix and disabling Sendmail
Setting up freshclam
ClamAV update process started at Thu May 20 00:07:58 2010
DON’T PANIC! Read http://www.clamav.net/support/faq
Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 0%]Downloading main-52.cdiff [ 1%]Downloading main-52.cdiff [ 1%]Downloading main-52.cdiff [ 1%]Downloading main-52.cdiff [ 1%]Downloading main-52.cdiff [ 1%]Downloading main-52.cdiff [ 1%]Downloading main-52.cdiff [ 1%]Downloading main-52.cdiff [ 1%]Downloading main-52.cdiff [ 1%]Downloading main-52.cdiff [ 1%]Downloading main-52.cdiff [ 1%]Downloading main-52.cdiff [ 1%]Downloading main-52.cdiff [ 1%]Downloading main-52.cdiff [ 1%]Downloading main-52.cdiff [ 1%]Downloading main-52.cdiff [ 1%]Downloading main-52.cdiff [ 2%]Downloading main-52.cdiff [ 2%]Downloading main-52.cdiff [ 2%]Downloading main-52.cdiff [ 2%]Downloading main-52.cdiff [ 2%]Downloading main-52.cdiff [ 2%]Downloading main-52.cdiff [ 2%]Downloading main-52.cdiff [ 2%]Downloading main-52.cdiff [ 2%]Downloading main-52.cdiff [ 2%]Downloading main-52.cdiff [ 2%]Downloading main-52.cdiff [ 2%]Downloading main-52.cdiff [ 2%]Downloading main-52.cdiff [ 2%]Downloading main-52.cdiff [ 2%]Downloading main-52.cdiff [ 2%]Downloading main-52.cdiff [ 3%]Downloading main-52.cdiff [ 3%]Downloading main-52.cdiff [ 3%]Downloading main-52.cdiff [ 3%]Downloading main-52.cdiff [ 3%]Downloading main-52.cdiff [ 3%]Downloading main-52.cdiff [ 3%]Downloading main-52.cdiff [ 3%]Downloading main-52.cdiff [ 3%]Downloading main-52.cdiff [ 3%]Downloading main-52.cdiff [ 3%]Downloading main-52.cdiff [ 3%]Downloading main-52.cdiff [ 3%]Downloading main-52.cdiff [ 3%]Downloading main-52.cdiff [ 3%]Downloading main-52.cdiff [ 3%]Downloading main-52.cdiff [ 3%]Downloading main-52.cdiff [ 3%]Downloading main-52.cdiff [ 3%]Downloading main-52.cdiff [ 4%]Downloading main-52.cdiff [ 4%]Downloading main-52.cdiff [ 4%]Downloading main-52.cdiff [ 4%]Downloading main-52.cdiff [ 4%]Downloading main-52.cdiff [ 4%]Downloading main-52.cdiff [ 4%]Downloading main-52.cdiff [ 4%]Downloading main-52.cdiff [ 4%]Downloading main-52.cdiff [ 4%]Downloading main-52.cdiff [ 4%]Downloading main-52.cdiff [ 4%]Downloading main-52.cdiff [ 4%]Downloading main-52.cdiff [ 4%]Downloading main-52.cdiff [ 4%]Downloading main-52.cdiff [ 4%]Downloading main-52.cdiff [ 5%]Downloading main-52.cdiff [ 5%]Downloading main-52.cdiff [ 5%]Downloading main-52.cdiff [ 5%]Downloading main-52.cdiff [ 5%]Downloading main-52.cdiff [ 5%]Downloading main-52.cdiff [ 5%]Downloading main-52.cdiff [ 5%]Downloading main-52.cdiff [ 5%]Downloading main-52.cdiff [ 5%]Downloading main-52.cdiff [ 5%]Downloading main-52.cdiff [ 5%]Downloading main-52.cdiff [ 5%]Downloading main-52.cdiff [ 5%]Downloading main-52.cdiff [ 5%]Downloading main-52.cdiff [ 5%]Downloading main-52.cdiff [ 5%]Downloading main-52.cdiff [ 5%]Downloading main-52.cdiff [ 5%]Downloading main-52.cdiff [ 5%]Downloading main-52.cdiff [ 6%]Downloading main-52.cdiff [ 6%]Downloading main-52.cdiff [ 6%]Downloading main-52.cdiff [ 6%]Downloading main-52.cdiff [ 6%]Downloading main-52.cdiff [ 6%]Downloading main-52.cdiff [ 6%]Downloading main-52.cdiff [ 6%]Downloading main-52.cdiff [ 6%]Downloading main-52.cdiff [ 6%]Downloading main-52.cdiff [ 6%]Downloading main-52.cdiff [ 6%]Downloading main-52.cdiff [ 6%]Downloading main-52.cdiff [ 6%]Downloading main-52.cdiff [ 6%]Downloading main-52.cdiff [ 6%]Downloading main-52.cdiff [ 6%]Downloading main-52.cdiff [ 6%]Downloading main-52.cdiff [ 6%]Downloading main-52.cdiff [ 7%]Downloading main-52.cdiff [ 7%]Downloading main-52.cdiff [ 7%]Downloading main-52.cdiff [ 7%]Downloading main-52.cdiff [ 7%]Downloading main-52.cdiff [ 7%]Downloading main-52.cdiff [ 7%]Downloading main-52.cdiff [ 7%]Downloading main-52.cdiff [ 7%]Downloading main-52.cdiff [ 8%]Downloading main-52.cdiff [ 8%]Downloading main-52.cdiff [ 8%]Downloading main-52.cdiff [ 8%]Downloading main-52.cdiff [ 8%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 9%]Downloading main-52.cdiff [ 10%]Downloading main-52.cdiff [ 10%]Downloading main-52.cdiff [ 10%]Downloading main-52.cdiff [ 10%]Downloading main-52.cdiff [ 10%]Downloading main-52.cdiff [ 10%]Downloading main-52.cdiff [ 10%]Downloading main-52.cdiff [ 10%]Downloading main-52.cdiff [ 10%]Downloading main-52.cdiff [ 10%]Downloading main-52.cdiff [ 10%]Downloading main-52.cdiff [ 10%]Downloading main-52.cdiff [ 10%]Downloading main-52.cdiff [ 10%]Downloading main-52.cdiff [ 10%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 11%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 12%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 13%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 14%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 15%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 16%]Downloading main-52.cdiff [ 17%]Downloading main-52.cdiff [ 17%]Downloading main-52.cdiff [ 17%]Downloading main-52.cdiff [ 17%]Downloading main-52.cdiff [ 17%]Downloading main-52.cdiff [ 17%]Downloading main-52.cdiff [ 17%]Downloading main-52.cdiff [ 17%]Downloading main-52.cdiff [ 17%]Downloading main-52.cdiff [ 17%]Downloading main-52.cdiff [ 17%]Downloading main-52.cdiff [ 17%]Downloading main-52.cdiff [ 17%]Downloading main-52.cdiff [ 17%]Downloading main-52.cdiff [ 17%]Downloading main-52.cdiff [ 17%]Downloading main-52.cdiff [ 17%]Downloading main-52.cdiff [ 17%]Downloading main-52.cdiff [ 17%]Downloading main-52.cdiff [ 18%]Downloading main-52.cdiff [ 18%]Downloading main-52.cdiff [ 18%]Downloading main-52.cdiff [ 18%]Downloading main-52.cdiff [ 18%]Downloading main-52.cdiff [ 18%]Downloading main-52.cdiff [ 18%]Downloading main-52.cdiff [ 18%]Downloading main-52.cdiff [ 18%]Downloading main-52.cdiff [ 18%]Downloading main-52.cdiff [ 18%]Downloading main-52.cdiff [ 18%]Downloading main-52.cdiff [ 18%]Downloading main-52.cdiff [ 18%]Downloading main-52.cdiff [ 18%]Downloading main-52.cdiff [ 18%]Downloading main-52.cdiff [ 18%]Downloading main-52.cdiff [ 18%]Downloading main-52.cdiff [ 18%]Downloading main-52.cdiff [ 18%]Downloading main-52.cdiff [ 19%]Downloading main-52.cdiff [ 19%]Downloading main-52.cdiff [ 19%]Downloading main-52.cdiff [ 19%]Downloading main-52.cdiff [ 19%]Downloading main-52.cdiff [ 19%]Downloading main-52.cdiff [ 19%]Downloading main-52.cdiff [ 19%]Downloading main-52.cdiff [ 19%]Downloading main-52.cdiff [ 19%]Downloading main-52.cdiff [ 19%]Downloading main-52.cdiff [ 19%]Downloading main-52.cdiff [ 19%]Downloading main-52.cdiff [ 19%]Downloading main-52.cdiff [ 19%]Downloading main-52.cdiff [ 19%]Downloading main-52.cdiff [ 19%]Downloading main-52.cdiff [ 19%]Downloading main-52.cdiff [ 19%]Downloading main-52.cdiff [ 20%]Downloading main-52.cdiff [ 20%]Downloading main-52.cdiff [ 20%]Downloading main-52.cdiff [ 20%]Downloading main-52.cdiff [ 20%]Downloading main-52.cdiff [ 20%]Downloading main-52.cdiff [ 20%]Downloading main-52.cdiff [ 20%]Downloading main-52.cdiff [ 20%]Downloading main-52.cdiff [ 20%]Downloading main-52.cdiff [ 20%]Downloading main-52.cdiff [ 20%]Downloading main-52.cdiff [ 20%]Downloading main-52.cdiff [ 20%]Downloading main-52.cdiff [ 20%]Downloading main-52.cdiff [ 20%]Downloading main-52.cdiff [ 20%]Downloading main-52.cdiff [ 20%]Downloading main-52.cdiff [ 20%]Downloading main-52.cdiff [ 20%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 21%]Downloading main-52.cdiff [ 22%]Downloading main-52.cdiff [ 22%]Downloading main-52.cdiff [ 22%]Downloading main-52.cdiff [ 22%]Downloading main-52.cdiff [ 22%]Downloading main-52.cdiff [ 22%]Downloading main-52.cdiff [ 22%]Downloading main-52.cdiff [ 22%]Downloading main-52.cdiff [ 22%]Downloading main-52.cdiff [ 22%]Downloading main-52.cdiff [ 22%]Downloading main-52.cdiff [ 22%]Downloading main-52.cdiff [ 22%]Downloading main-52.cdiff [ 22%]Downloading main-52.cdiff [ 22%]Downloading main-52.cdiff [ 22%]Downloading main-52.cdiff [ 22%]Downloading main-52.cdiff [ 22%]Downloading main-52.cdiff [ 22%]Downloading main-52.cdiff [ 23%]Downloading main-52.cdiff [ 23%]Downloading main-52.cdiff [ 23%]Downloading main-52.cdiff [ 23%]Downloading main-52.cdiff [ 23%]Downloading main-52.cdiff [ 23%]Downloading main-52.cdiff [ 23%]Downloading main-52.cdiff [ 23%]Downloading main-52.cdiff [ 23%]Downloading main-52.cdiff [ 23%]Downloading main-52.cdiff [ 23%]Downloading main-52.cdiff [ 23%]Downloading main-52.cdiff [ 23%]Downloading main-52.cdiff [ 23%]Downloading main-52.cdiff [ 23%]Downloading main-52.cdiff [ 23%]Downloading main-52.cdiff [ 23%]Downloading main-52.cdiff [ 24%]Downloading main-52.cdiff [ 24%]Downloading main-52.cdiff [ 24%]Downloading main-52.cdiff [ 24%]Downloading main-52.cdiff [ 24%]Downloading main-52.cdiff [ 24%]Downloading main-52.cdiff [ 24%]Downloading main-52.cdiff [ 24%]Downloading main-52.cdiff [ 24%]Downloading main-52.cdiff [ 24%]Downloading main-52.cdiff [ 24%]Downloading main-52.cdiff [ 24%]Downloading main-52.cdiff [ 24%]Downloading main-52.cdiff [ 24%]Downloading main-52.cdiff [ 24%]Downloading main-52.cdiff [ 24%]Downloading main-52.cdiff [ 24%]Downloading main-52.cdiff [ 24%]Downloading main-52.cdiff [ 24%]Downloading main-52.cdiff [ 24%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 25%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 26%]Downloading main-52.cdiff [ 27%]Downloading main-52.cdiff [ 27%]Downloading main-52.cdiff [ 27%]Downloading main-52.cdiff [ 27%]Downloading main-52.cdiff [ 27%]Downloading main-52.cdiff [ 27%]Downloading main-52.cdiff [ 27%]Downloading main-52.cdiff [ 27%]Downloading main-52.cdiff [ 27%]Downloading main-52.cdiff [ 27%]Downloading main-52.cdiff [ 27%]Downloading main-52.cdiff [ 27%]Downloading main-52.cdiff [ 27%]Downloading main-52.cdiff [ 27%]Downloading main-52.cdiff [ 27%]Downloading main-52.cdiff [ 27%]Downloading main-52.cdiff [ 27%]Downloading main-52.cdiff [ 27%]Downloading main-52.cdiff [ 27%]Downloading main-52.cdiff [ 27%]Downloading main-52.cdiff [ 28%]Downloading main-52.cdiff [ 28%]Downloading main-52.cdiff [ 28%]Downloading main-52.cdiff [ 28%]Downloading main-52.cdiff [ 28%]Downloading main-52.cdiff [ 28%]Downloading main-52.cdiff [ 28%]Downloading main-52.cdiff [ 28%]Downloading main-52.cdiff [ 28%]Downloading main-52.cdiff [ 28%]Downloading main-52.cdiff [ 28%]Downloading main-52.cdiff [ 28%]Downloading main-52.cdiff [ 28%]Downloading main-52.cdiff [ 28%]Downloading main-52.cdiff [ 28%]Downloading main-52.cdiff [ 28%]Downloading main-52.cdiff [ 28%]Downloading main-52.cdiff [ 28%]Downloading main-52.cdiff [ 28%]Downloading main-52.cdiff [ 28%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 29%]Downloading main-52.cdiff [ 30%]Downloading main-52.cdiff [ 30%]Downloading main-52.cdiff [ 30%]Downloading main-52.cdiff [ 30%]Downloading main-52.cdiff [ 30%]Downloading main-52.cdiff [ 30%]Downloading main-52.cdiff [ 30%]Downloading main-52.cdiff [ 30%]Downloading main-52.cdiff [ 30%]Downloading main-52.cdiff [ 30%]Downloading main-52.cdiff [ 30%]Downloading main-52.cdiff [ 30%]Downloading main-52.cdiff [ 30%]Downloading main-52.cdiff [ 30%]Downloading main-52.cdiff [ 30%]Downloading main-52.cdiff [ 30%]Downloading main-52.cdiff [ 30%]Downloading main-52.cdiff [ 30%]Downloading main-52.cdiff [ 30%]Downloading main-52.cdiff [ 31%]Downloading main-52.cdiff [ 31%]Downloading main-52.cdiff [ 31%]Downloading main-52.cdiff [ 31%]Downloading main-52.cdiff [ 31%]Downloading main-52.cdiff [ 31%]Downloading main-52.cdiff [ 31%]Downloading main-52.cdiff [ 31%]Downloading main-52.cdiff [ 31%]Downloading main-52.cdiff [ 31%]Downloading main-52.cdiff [ 31%]Downloading main-52.cdiff [ 31%]Downloading main-52.cdiff [ 31%]Downloading main-52.cdiff [ 31%]Downloading main-52.cdiff [ 31%]Downloading main-52.cdiff [ 31%]Downloading main-52.cdiff [ 31%]Downloading main-52.cdiff [ 31%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 32%]Downloading main-52.cdiff [ 33%]Downloading main-52.cdiff [ 33%]Downloading main-52.cdiff [ 33%]Downloading main-52.cdiff [ 33%]Downloading main-52.cdiff [ 33%]Downloading main-52.cdiff [ 33%]Downloading main-52.cdiff [ 33%]Downloading main-52.cdiff [ 33%]Downloading main-52.cdiff [ 33%]Downloading main-52.cdiff [ 33%]Downloading main-52.cdiff [ 33%]Downloading main-52.cdiff [ 33%]Downloading main-52.cdiff [ 33%]Downloading main-52.cdiff [ 33%]Downloading main-52.cdiff [ 33%]Downloading main-52.cdiff [ 33%]Downloading main-52.cdiff [ 33%]Downloading main-52.cdiff [ 33%]Downloading main-52.cdiff [ 34%]Downloading main-52.cdiff [ 34%]Downloading main-52.cdiff [ 34%]Downloading main-52.cdiff [ 34%]Downloading main-52.cdiff [ 34%]Downloading main-52.cdiff [ 34%]Downloading main-52.cdiff [ 34%]Downloading main-52.cdiff [ 34%]Downloading main-52.cdiff [ 34%]Downloading main-52.cdiff [ 34%]Downloading main-52.cdiff [ 34%]Downloading main-52.cdiff [ 34%]Downloading main-52.cdiff [ 34%]Downloading main-52.cdiff [ 34%]Downloading main-52.cdiff [ 34%]Downloading main-52.cdiff [ 34%]Downloading main-52.cdiff [ 34%]Downloading main-52.cdiff [ 34%]Downloading main-52.cdiff [ 35%]Downloading main-52.cdiff [ 35%]Downloading main-52.cdiff [ 35%]Downloading main-52.cdiff [ 35%]Downloading main-52.cdiff [ 35%]Downloading main-52.cdiff [ 35%]Downloading main-52.cdiff [ 35%]Downloading main-52.cdiff [ 35%]Downloading main-52.cdiff [ 35%]Downloading main-52.cdiff [ 35%]Downloading main-52.cdiff [ 35%]Downloading main-52.cdiff [ 35%]Downloading main-52.cdiff [ 35%]Downloading main-52.cdiff [ 35%]Downloading main-52.cdiff [ 35%]Downloading main-52.cdiff [ 35%]Downloading main-52.cdiff [ 35%]Downloading main-52.cdiff [ 35%]Downloading main-52.cdiff [ 36%]Downloading main-52.cdiff [ 36%]Downloading main-52.cdiff [ 36%]Downloading main-52.cdiff [ 36%]Downloading main-52.cdiff [ 36%]Downloading main-52.cdiff [ 36%]Downloading main-52.cdiff [ 36%]Downloading main-52.cdiff [ 36%]Downloading main-52.cdiff [ 36%]Downloading main-52.cdiff [ 36%]Downloading main-52.cdiff [ 36%]Downloading main-52.cdiff [ 36%]Downloading main-52.cdiff [ 36%]Downloading main-52.cdiff [ 36%]Downloading main-52.cdiff [ 36%]Downloading main-52.cdiff [ 36%]Downloading main-52.cdiff [ 36%]Downloading main-52.cdiff [ 37%]Downloading main-52.cdiff [ 37%]Downloading main-52.cdiff [ 37%]Downloading main-52.cdiff [ 37%]Downloading main-52.cdiff [ 37%]Downloading main-52.cdiff [ 37%]Downloading main-52.cdiff [ 37%]Downloading main-52.cdiff [ 37%]Downloading main-52.cdiff [ 37%]Downloading main-52.cdiff [ 37%]Downloading main-52.cdiff [ 37%]Downloading main-52.cdiff [ 37%]Downloading main-52.cdiff [ 37%]Downloading main-52.cdiff [ 37%]Downloading main-52.cdiff [ 37%]Downloading main-52.cdiff [ 37%]Downloading main-52.cdiff [ 37%]Downloading main-52.cdiff [ 37%]Downloading main-52.cdiff [ 38%]Downloading main-52.cdiff [ 38%]Downloading main-52.cdiff [ 38%]Downloading main-52.cdiff [ 38%]Downloading main-52.cdiff [ 38%]Downloading main-52.cdiff [ 38%]Downloading main-52.cdiff [ 38%]Downloading main-52.cdiff [ 38%]Downloading main-52.cdiff [ 38%]Downloading main-52.cdiff [ 38%]Downloading main-52.cdiff [ 38%]Downloading main-52.cdiff [ 38%]Downloading main-52.cdiff [ 38%]Downloading main-52.cdiff [ 38%]Downloading main-52.cdiff [ 38%]Downloading main-52.cdiff [ 38%]Downloading main-52.cdiff [ 38%]Downloading main-52.cdiff [ 38%]Downloading main-52.cdiff [ 39%]Downloading main-52.cdiff [ 39%]Downloading main-52.cdiff [ 39%]Downloading main-52.cdiff [ 39%]Downloading main-52.cdiff [ 39%]Downloading main-52.cdiff [ 39%]Downloading main-52.cdiff [ 39%]Downloading main-52.cdiff [ 39%]Downloading main-52.cdiff [ 39%]Downloading main-52.cdiff [ 39%]Downloading main-52.cdiff [ 39%]Downloading main-52.cdiff [ 39%]Downloading main-52.cdiff [ 39%]Downloading main-52.cdiff [ 39%]Downloading main-52.cdiff [ 39%]Downloading main-52.cdiff [ 39%]Downloading main-52.cdiff [ 39%]Downloading main-52.cdiff [ 39%]Downloading main-52.cdiff [ 40%]Downloading main-52.cdiff [ 40%]Downloading main-52.cdiff [ 40%]Downloading main-52.cdiff [ 40%]Downloading main-52.cdiff [ 40%]Downloading main-52.cdiff [ 40%]Downloading main-52.cdiff [ 40%]Downloading main-52.cdiff [ 40%]Downloading main-52.cdiff [ 40%]Downloading main-52.cdiff [ 40%]Downloading main-52.cdiff [ 40%]Downloading main-52.cdiff [ 40%]Downloading main-52.cdiff [ 40%]Downloading main-52.cdiff [ 40%]Downloading main-52.cdiff [ 40%]Downloading main-52.cdiff [ 40%]Downloading main-52.cdiff [ 40%]Downloading main-52.cdiff [ 41%]Downloading main-52.cdiff [ 41%]Downloading main-52.cdiff [ 41%]Downloading main-52.cdiff [ 41%]Downloading main-52.cdiff [ 41%]Downloading main-52.cdiff [ 41%]Downloading main-52.cdiff [ 41%]Downloading main-52.cdiff [ 41%]Downloading main-52.cdiff [ 41%]Downloading main-52.cdiff [ 41%]Downloading main-52.cdiff [ 41%]Downloading main-52.cdiff [ 41%]Downloading main-52.cdiff [ 41%]Downloading main-52.cdiff [ 41%]Downloading main-52.cdiff [ 41%]Downloading main-52.cdiff [ 41%]Downloading main-52.cdiff [ 41%]Downloading main-52.cdiff [ 41%]Downloading main-52.cdiff [ 42%]Downloading main-52.cdiff [ 42%]Downloading main-52.cdiff [ 42%]Downloading main-52.cdiff [ 42%]Downloading main-52.cdiff [ 42%]Downloading main-52.cdiff [ 42%]Downloading main-52.cdiff [ 42%]Downloading main-52.cdiff [ 42%]Downloading main-52.cdiff [ 42%]Downloading main-52.cdiff [ 42%]Downloading main-52.cdiff [ 42%]Downloading main-52.cdiff [ 42%]Downloading main-52.cdiff [ 42%]Downloading main-52.cdiff [ 42%]Downloading main-52.cdiff [ 42%]Downloading main-52.cdiff [ 42%]Downloading main-52.cdiff [ 42%]Downloading main-52.cdiff [ 42%]Downloading main-52.cdiff [ 43%]Downloading main-52.cdiff [ 43%]Downloading main-52.cdiff [ 43%]Downloading main-52.cdiff [ 43%]Downloading main-52.cdiff [ 43%]Downloading main-52.cdiff [ 43%]Downloading main-52.cdiff [ 43%]Downloading main-52.cdiff [ 43%]Downloading main-52.cdiff [ 43%]Downloading main-52.cdiff [ 43%]Downloading main-52.cdiff [ 43%]Downloading main-52.cdiff [ 43%]Downloading main-52.cdiff [ 43%]Downloading main-52.cdiff [ 43%]Downloading main-52.cdiff [ 43%]Downloading main-52.cdiff [ 43%]Downloading main-52.cdiff [ 43%]Downloading main-52.cdiff [ 43%]Downloading main-52.cdiff [ 44%]Downloading main-52.cdiff [ 44%]Downloading main-52.cdiff [ 44%]Downloading main-52.cdiff [ 44%]Downloading main-52.cdiff [ 44%]Downloading main-52.cdiff [ 44%]Downloading main-52.cdiff [ 44%]Downloading main-52.cdiff [ 44%]Downloading main-52.cdiff [ 44%]Downloading main-52.cdiff [ 44%]Downloading main-52.cdiff [ 44%]Downloading main-52.cdiff [ 44%]Downloading main-52.cdiff [ 44%]Downloading main-52.cdiff [ 44%]Downloading main-52.cdiff [ 44%]Downloading main-52.cdiff [ 44%]Downloading main-52.cdiff [ 44%]Downloading main-52.cdiff [ 44%]Downloading main-52.cdiff [ 45%]Downloading main-52.cdiff [ 45%]Downloading main-52.cdiff [ 45%]Downloading main-52.cdiff [ 45%]Downloading main-52.cdiff [ 45%]Downloading main-52.cdiff [ 45%]Downloading main-52.cdiff [ 45%]Downloading main-52.cdiff [ 45%]Downloading main-52.cdiff [ 45%]Downloading main-52.cdiff [ 45%]Downloading main-52.cdiff [ 45%]Downloading main-52.cdiff [ 45%]Downloading main-52.cdiff [ 45%]Downloading main-52.cdiff [ 45%]Downloading main-52.cdiff [ 45%]Downloading main-52.cdiff [ 45%]Downloading main-52.cdiff [ 45%]Downloading main-52.cdiff [ 46%]Downloading main-52.cdiff [ 46%]Downloading main-52.cdiff [ 46%]Downloading main-52.cdiff [ 46%]Downloading main-52.cdiff [ 46%]Downloading main-52.cdiff [ 46%]Downloading main-52.cdiff [ 46%]Downloading main-52.cdiff [ 46%]Downloading main-52.cdiff [ 46%]Downloading main-52.cdiff [ 46%]Downloading main-52.cdiff [ 46%]Downloading main-52.cdiff [ 46%]Downloading main-52.cdiff [ 46%]Downloading main-52.cdiff [ 46%]Downloading main-52.cdiff [ 46%]Downloading main-52.cdiff [ 46%]Downloading main-52.cdiff [ 46%]Downloading main-52.cdiff [ 46%]Downloading main-52.cdiff [ 47%]Downloading main-52.cdiff [ 47%]Downloading main-52.cdiff [ 47%]Downloading main-52.cdiff [ 47%]Downloading main-52.cdiff [ 47%]Downloading main-52.cdiff [ 47%]Downloading main-52.cdiff [ 47%]Downloading main-52.cdiff [ 47%]Downloading main-52.cdiff [ 47%]Downloading main-52.cdiff [ 47%]Downloading main-52.cdiff [ 47%]Downloading main-52.cdiff [ 47%]Downloading main-52.cdiff [ 47%]Downloading main-52.cdiff [ 47%]Downloading main-52.cdiff [ 47%]Downloading main-52.cdiff [ 47%]Downloading main-52.cdiff [ 47%]Downloading main-52.cdiff [ 47%]Downloading main-52.cdiff [ 47%]Downloading main-52.cdiff [ 48%]Downloading main-52.cdiff [ 48%]Downloading main-52.cdiff [ 48%]Downloading main-52.cdiff [ 48%]Downloading main-52.cdiff [ 48%]Downloading main-52.cdiff [ 48%]Downloading main-52.cdiff [ 48%]Downloading main-52.cdiff [ 48%]Downloading main-52.cdiff [ 48%]Downloading main-52.cdiff [ 48%]Downloading main-52.cdiff [ 48%]Downloading main-52.cdiff [ 48%]Downloading main-52.cdiff [ 48%]Downloading main-52.cdiff [ 48%]Downloading main-52.cdiff [ 48%]Downloading main-52.cdiff [ 48%]Downloading main-52.cdiff [ 48%]Downloading main-52.cdiff [ 48%]Downloading main-52.cdiff [ 49%]Downloading main-52.cdiff [ 49%]Downloading main-52.cdiff [ 49%]Downloading main-52.cdiff [ 49%]Downloading main-52.cdiff [ 49%]Downloading main-52.cdiff [ 49%]Downloading main-52.cdiff [ 49%]Downloading main-52.cdiff [ 49%]Downloading main-52.cdiff [ 49%]Downloading main-52.cdiff [ 49%]Downloading main-52.cdiff [ 49%]Downloading main-52.cdiff [ 49%]Downloading main-52.cdiff [ 49%]Downloading main-52.cdiff [ 49%]Downloading main-52.cdiff [ 49%]Downloading main-52.cdiff [ 49%]Downloading main-52.cdiff [ 49%]Downloading main-52.cdiff [ 50%]Downloading main-52.cdiff [ 50%]Downloading main-52.cdiff [ 50%]Downloading main-52.cdiff [ 50%]Downloading main-52.cdiff [ 50%]Downloading main-52.cdiff [ 50%]Downloading main-52.cdiff [ 50%]Downloading main-52.cdiff [ 50%]Downloading main-52.cdiff [ 50%]Downloading main-52.cdiff [ 50%]Downloading main-52.cdiff [ 50%]Downloading main-52.cdiff [ 50%]Downloading main-52.cdiff [ 50%]Downloading main-52.cdiff [ 50%]Downloading main-52.cdiff [ 50%]Downloading main-52.cdiff [ 50%]Downloading main-52.cdiff [ 50%]Downloading main-52.cdiff [ 51%]Downloading main-52.cdiff [ 51%]Downloading main-52.cdiff [ 51%]Downloading main-52.cdiff [ 51%]Downloading main-52.cdiff [ 51%]Downloading main-52.cdiff [ 51%]Downloading main-52.cdiff [ 51%]Downloading main-52.cdiff [ 51%]Downloading main-52.cdiff [ 51%]Downloading main-52.cdiff [ 51%]Downloading main-52.cdiff [ 51%]Downloading main-52.cdiff [ 51%]Downloading main-52.cdiff [ 51%]Downloading main-52.cdiff [ 51%]Downloading main-52.cdiff [ 51%]Downloading main-52.cdiff [ 51%]Downloading main-52.cdiff [ 51%]Downloading main-52.cdiff [ 51%]Downloading main-52.cdiff [ 51%]Downloading main-52.cdiff [ 52%]Downloading main-52.cdiff [ 52%]Downloading main-52.cdiff [ 52%]Downloading main-52.cdiff [ 52%]Downloading main-52.cdiff [ 52%]Downloading main-52.cdiff [ 52%]Downloading main-52.cdiff [ 52%]Downloading main-52.cdiff [ 52%]Downloading main-52.cdiff [ 52%]Downloading main-52.cdiff [ 52%]Downloading main-52.cdiff [ 52%]Downloading main-52.cdiff [ 52%]Downloading main-52.cdiff [ 52%]Downloading main-52.cdiff [ 52%]Downloading main-52.cdiff [ 52%]Downloading main-52.cdiff [ 52%]Downloading main-52.cdiff [ 52%]Downloading main-52.cdiff [ 52%]Downloading main-52.cdiff [ 53%]Downloading main-52.cdiff [ 53%]Downloading main-52.cdiff [ 53%]Downloading main-52.cdiff [ 53%]Downloading main-52.cdiff [ 53%]Downloading main-52.cdiff [ 53%]Downloading main-52.cdiff [ 53%]Downloading main-52.cdiff [ 53%]Downloading main-52.cdiff [ 53%]Downloading main-52.cdiff [ 53%]Downloading main-52.cdiff [ 53%]Downloading main-52.cdiff [ 53%]Downloading main-52.cdiff [ 53%]Downloading main-52.cdiff [ 53%]Downloading main-52.cdiff [ 53%]Downloading main-52.cdiff [ 53%]Downloading main-52.cdiff [ 53%]Downloading main-52.cdiff [ 53%]Downloading main-52.cdiff [ 53%]Downloading main-52.cdiff [ 54%]Downloading main-52.cdiff [ 54%]Downloading main-52.cdiff [ 54%]Downloading main-52.cdiff [ 54%]Downloading main-52.cdiff [ 54%]Downloading main-52.cdiff [ 54%]Downloading main-52.cdiff [ 54%]Downloading main-52.cdiff [ 54%]Downloading main-52.cdiff [ 54%]Downloading main-52.cdiff [ 54%]Downloading main-52.cdiff [ 54%]Downloading main-52.cdiff [ 54%]Downloading main-52.cdiff [ 54%]Downloading main-52.cdiff [ 54%]Downloading main-52.cdiff [ 54%]Downloading main-52.cdiff [ 54%]Downloading main-52.cdiff [ 54%]Downloading main-52.cdiff [ 55%]Downloading main-52.cdiff [ 55%]Downloading main-52.cdiff [ 55%]Downloading main-52.cdiff [ 55%]Downloading main-52.cdiff [ 55%]Downloading main-52.cdiff [ 55%]Downloading main-52.cdiff [ 55%]Downloading main-52.cdiff [ 55%]Downloading main-52.cdiff [ 55%]Downloading main-52.cdiff [ 55%]Downloading main-52.cdiff [ 55%]Downloading main-52.cdiff [ 55%]Downloading main-52.cdiff [ 55%]Downloading main-52.cdiff [ 55%]Downloading main-52.cdiff [ 55%]Downloading main-52.cdiff [ 55%]Downloading main-52.cdiff [ 55%]Downloading main-52.cdiff [ 55%]Downloading main-52.cdiff [ 56%]Downloading main-52.cdiff [ 56%]Downloading main-52.cdiff [ 56%]Downloading main-52.cdiff [ 56%]Downloading main-52.cdiff [ 56%]Downloading main-52.cdiff [ 56%]Downloading main-52.cdiff [ 56%]Downloading main-52.cdiff [ 56%]Downloading main-52.cdiff [ 56%]Downloading main-52.cdiff [ 56%]Downloading main-52.cdiff [ 56%]Downloading main-52.cdiff [ 56%]Downloading main-52.cdiff [ 56%]Downloading main-52.cdiff [ 56%]Downloading main-52.cdiff [ 56%]Downloading main-52.cdiff [ 56%]Downloading main-52.cdiff [ 56%]Downloading main-52.cdiff [ 56%]Downloading main-52.cdiff [ 56%]Downloading main-52.cdiff [ 56%]Downloading main-52.cdiff [ 57%]Downloading main-52.cdiff [ 57%]Downloading main-52.cdiff [ 57%]Downloading main-52.cdiff [ 57%]Downloading main-52.cdiff [ 57%]Downloading main-52.cdiff [ 57%]Downloading main-52.cdiff [ 57%]Downloading main-52.cdiff [ 57%]Downloading main-52.cdiff [ 57%]Downloading main-52.cdiff [ 57%]Downloading main-52.cdiff [ 57%]Downloading main-52.cdiff [ 57%]Downloading main-52.cdiff [ 57%]Downloading main-52.cdiff [ 57%]Downloading main-52.cdiff [ 57%]Downloading main-52.cdiff [ 57%]Downloading main-52.cdiff [ 57%]Downloading main-52.cdiff [ 57%]Downloading main-52.cdiff [ 58%]Downloading main-52.cdiff [ 58%]Downloading main-52.cdiff [ 58%]Downloading main-52.cdiff [ 58%]Downloading main-52.cdiff [ 58%]Downloading main-52.cdiff [ 58%]Downloading main-52.cdiff [ 58%]Downloading main-52.cdiff [ 58%]Downloading main-52.cdiff [ 58%]Downloading main-52.cdiff [ 58%]Downloading main-52.cdiff [ 58%]Downloading main-52.cdiff [ 58%]Downloading main-52.cdiff [ 58%]Downloading main-52.cdiff [ 58%]Downloading main-52.cdiff [ 58%]Downloading main-52.cdiff [ 58%]Downloading main-52.cdiff [ 58%]Downloading main-52.cdiff [ 58%]Downloading main-52.cdiff [ 59%]Downloading main-52.cdiff [ 59%]Downloading main-52.cdiff [ 59%]Downloading main-52.cdiff [ 59%]Downloading main-52.cdiff [ 59%]Downloading main-52.cdiff [ 59%]Downloading main-52.cdiff [ 59%]Downloading main-52.cdiff [ 59%]Downloading main-52.cdiff [ 59%]Downloading main-52.cdiff [ 59%]Downloading main-52.cdiff [ 59%]Downloading main-52.cdiff [ 59%]Downloading main-52.cdiff [ 59%]Downloading main-52.cdiff [ 59%]Downloading main-52.cdiff [ 59%]Downloading main-52.cdiff [ 59%]Downloading main-52.cdiff [ 59%]Downloading main-52.cdiff [ 59%]Downloading main-52.cdiff [ 60%]Downloading main-52.cdiff [ 60%]Downloading main-52.cdiff [ 60%]Downloading main-52.cdiff [ 60%]Downloading main-52.cdiff [ 60%]Downloading main-52.cdiff [ 60%]Downloading main-52.cdiff [ 60%]Downloading main-52.cdiff [ 60%]Downloading main-52.cdiff [ 60%]Downloading main-52.cdiff [ 60%]Downloading main-52.cdiff [ 60%]Downloading main-52.cdiff [ 60%]Downloading main-52.cdiff [ 60%]Downloading main-52.cdiff [ 60%]Downloading main-52.cdiff [ 60%]Downloading main-52.cdiff [ 60%]Downloading main-52.cdiff [ 60%]Downloading main-52.cdiff [ 60%]Downloading main-52.cdiff [ 60%]Downloading main-52.cdiff [ 60%]Downloading main-52.cdiff [ 61%]Downloading main-52.cdiff [ 61%]Downloading main-52.cdiff [ 61%]Downloading main-52.cdiff [ 61%]Downloading main-52.cdiff [ 61%]Downloading main-52.cdiff [ 61%]Downloading main-52.cdiff [ 61%]Downloading main-52.cdiff [ 61%]Downloading main-52.cdiff [ 61%]Downloading main-52.cdiff [ 61%]Downloading main-52.cdiff [ 61%]Downloading main-52.cdiff [ 61%]Downloading main-52.cdiff [ 61%]Downloading main-52.cdiff [ 61%]Downloading main-52.cdiff [ 61%]Downloading main-52.cdiff [ 61%]Downloading main-52.cdiff [ 61%]Downloading main-52.cdiff [ 61%]Downloading main-52.cdiff [ 62%]Downloading main-52.cdiff [ 62%]Downloading main-52.cdiff [ 62%]Downloading main-52.cdiff [ 62%]Downloading main-52.cdiff [ 62%]Downloading main-52.cdiff [ 62%]Downloading main-52.cdiff [ 62%]Downloading main-52.cdiff [ 62%]Downloading main-52.cdiff [ 62%]Downloading main-52.cdiff [ 62%]Downloading main-52.cdiff [ 62%]Downloading main-52.cdiff [ 62%]Downloading main-52.cdiff [ 62%]Downloading main-52.cdiff [ 62%]Downloading main-52.cdiff [ 62%]Downloading main-52.cdiff [ 62%]Downloading main-52.cdiff [ 62%]Downloading main-52.cdiff [ 63%]Downloading main-52.cdiff [ 63%]Downloading main-52.cdiff [ 63%]Downloading main-52.cdiff [ 63%]Downloading main-52.cdiff [ 63%]Downloading main-52.cdiff [ 63%]Downloading main-52.cdiff [ 63%]Downloading main-52.cdiff [ 63%]Downloading main-52.cdiff [ 63%]Downloading main-52.cdiff [ 63%]Downloading main-52.cdiff [ 63%]Downloading main-52.cdiff [ 63%]Downloading main-52.cdiff [ 63%]Downloading main-52.cdiff [ 63%]Downloading main-52.cdiff [ 63%]Downloading main-52.cdiff [ 63%]Downloading main-52.cdiff [ 63%]Downloading main-52.cdiff [ 63%]Downloading main-52.cdiff [ 63%]Downloading main-52.cdiff [ 64%]Downloading main-52.cdiff [ 64%]Downloading main-52.cdiff [ 64%]Downloading main-52.cdiff [ 64%]Downloading main-52.cdiff [ 64%]Downloading main-52.cdiff [ 64%]Downloading main-52.cdiff [ 64%]Downloading main-52.cdiff [ 64%]Downloading main-52.cdiff [ 64%]Downloading main-52.cdiff [ 64%]Downloading main-52.cdiff [ 64%]Downloading main-52.cdiff [ 64%]Downloading main-52.cdiff [ 64%]Downloading main-52.cdiff [ 64%]Downloading main-52.cdiff [ 64%]Downloading main-52.cdiff [ 64%]Downloading main-52.cdiff [ 64%]Downloading main-52.cdiff [ 64%]Downloading main-52.cdiff [ 65%]Downloading main-52.cdiff [ 65%]Downloading main-52.cdiff [ 65%]Downloading main-52.cdiff [ 65%]Downloading main-52.cdiff [ 65%]Downloading main-52.cdiff [ 65%]Downloading main-52.cdiff [ 65%]Downloading main-52.cdiff [ 65%]Downloading main-52.cdiff [ 65%]Downloading main-52.cdiff [ 65%]Downloading main-52.cdiff [ 65%]Downloading main-52.cdiff [ 65%]Downloading main-52.cdiff [ 65%]Downloading main-52.cdiff [ 65%]Downloading main-52.cdiff [ 65%]Downloading main-52.cdiff [ 65%]Downloading main-52.cdiff [ 65%]Downloading main-52.cdiff [ 65%]Downloading main-52.cdiff [ 65%]Downloading main-52.cdiff [ 66%]Downloading main-52.cdiff [ 66%]Downloading main-52.cdiff [ 66%]Downloading main-52.cdiff [ 66%]Downloading main-52.cdiff [ 66%]Downloading main-52.cdiff [ 66%]Downloading main-52.cdiff [ 66%]Downloading main-52.cdiff [ 66%]Downloading main-52.cdiff [ 66%]Downloading main-52.cdiff [ 66%]Downloading main-52.cdiff [ 66%]Downloading main-52.cdiff [ 66%]Downloading main-52.cdiff [ 66%]Downloading main-52.cdiff [ 66%]Downloading main-52.cdiff [ 66%]Downloading main-52.cdiff [ 66%]Downloading main-52.cdiff [ 66%]Downloading main-52.cdiff [ 67%]Downloading main-52.cdiff [ 67%]Downloading main-52.cdiff [ 67%]Downloading main-52.cdiff [ 67%]Downloading main-52.cdiff [ 67%]Downloading main-52.cdiff [ 67%]Downloading main-52.cdiff [ 67%]Downloading main-52.cdiff [ 67%]Downloading main-52.cdiff [ 67%]Downloading main-52.cdiff [ 67%]Downloading main-52.cdiff [ 67%]Downloading main-52.cdiff [ 67%]Downloading main-52.cdiff [ 67%]Downloading main-52.cdiff [ 67%]Downloading main-52.cdiff [ 67%]Downloading main-52.cdiff [ 67%]Downloading main-52.cdiff [ 67%]Downloading main-52.cdiff [ 67%]Downloading main-52.cdiff [ 68%]Downloading main-52.cdiff [ 68%]Downloading main-52.cdiff [ 68%]Downloading main-52.cdiff [ 68%]Downloading main-52.cdiff [ 68%]Downloading main-52.cdiff [ 68%]Downloading main-52.cdiff [ 68%]Downloading main-52.cdiff [ 68%]Downloading main-52.cdiff [ 68%]Downloading main-52.cdiff [ 68%]Downloading main-52.cdiff [ 68%]Downloading main-52.cdiff [ 68%]Downloading main-52.cdiff [ 68%]Downloading main-52.cdiff [ 68%]Downloading main-52.cdiff [ 68%]Downloading main-52.cdiff [ 68%]Downloading main-52.cdiff [ 68%]Downloading main-52.cdiff [ 68%]Downloading main-52.cdiff [ 69%]Downloading main-52.cdiff [ 69%]Downloading main-52.cdiff [ 69%]Downloading main-52.cdiff [ 69%]Downloading main-52.cdiff [ 69%]Downloading main-52.cdiff [ 69%]Downloading main-52.cdiff [ 69%]Downloading main-52.cdiff [ 69%]Downloading main-52.cdiff [ 69%]Downloading main-52.cdiff [ 69%]Downloading main-52.cdiff [ 69%]Downloading main-52.cdiff [ 69%]Downloading main-52.cdiff [ 69%]Downloading main-52.cdiff [ 69%]Downloading main-52.cdiff [ 69%]Downloading main-52.cdiff [ 69%]Downloading main-52.cdiff [ 69%]Downloading main-52.cdiff [ 69%]Downloading main-52.cdiff [ 70%]Downloading main-52.cdiff [ 70%]Downloading main-52.cdiff [ 70%]Downloading main-52.cdiff [ 70%]Downloading main-52.cdiff [ 70%]Downloading main-52.cdiff [ 70%]Downloading main-52.cdiff [ 70%]Downloading main-52.cdiff [ 70%]Downloading main-52.cdiff [ 70%]Downloading main-52.cdiff [ 70%]Downloading main-52.cdiff [ 70%]Downloading main-52.cdiff [ 70%]Downloading main-52.cdiff [ 70%]Downloading main-52.cdiff [ 70%]Downloading main-52.cdiff [ 70%]Downloading main-52.cdiff [ 70%]Downloading main-52.cdiff [ 70%]Downloading main-52.cdiff [ 71%]Downloading main-52.cdiff [ 71%]Downloading main-52.cdiff [ 71%]Downloading main-52.cdiff [ 71%]Downloading main-52.cdiff [ 71%]Downloading main-52.cdiff [ 71%]Downloading main-52.cdiff [ 71%]Downloading main-52.cdiff [ 71%]Downloading main-52.cdiff [ 71%]Downloading main-52.cdiff [ 71%]Downloading main-52.cdiff [ 71%]Downloading main-52.cdiff [ 71%]Downloading main-52.cdiff [ 71%]Downloading main-52.cdiff [ 71%]Downloading main-52.cdiff [ 71%]Downloading main-52.cdiff [ 71%]Downloading main-52.cdiff [ 71%]Downloading main-52.cdiff [ 71%]Downloading main-52.cdiff [ 72%]Downloading main-52.cdiff [ 72%]Downloading main-52.cdiff [ 72%]Downloading main-52.cdiff [ 72%]Downloading main-52.cdiff [ 72%]Downloading main-52.cdiff [ 72%]Downloading main-52.cdiff [ 72%]Downloading main-52.cdiff [ 72%]Downloading main-52.cdiff [ 72%]Downloading main-52.cdiff [ 72%]Downloading main-52.cdiff [ 72%]Downloading main-52.cdiff [ 72%]Downloading main-52.cdiff [ 72%]Downloading main-52.cdiff [ 72%]Downloading main-52.cdiff [ 72%]Downloading main-52.cdiff [ 72%]Downloading main-52.cdiff [ 72%]Downloading main-52.cdiff [ 73%]Downloading main-52.cdiff [ 73%]Downloading main-52.cdiff [ 73%]Downloading main-52.cdiff [ 73%]Downloading main-52.cdiff [ 73%]Downloading main-52.cdiff [ 73%]Downloading main-52.cdiff [ 73%]Downloading main-52.cdiff [ 73%]Downloading main-52.cdiff [ 73%]Downloading main-52.cdiff [ 73%]Downloading main-52.cdiff [ 73%]Downloading main-52.cdiff [ 73%]Downloading main-52.cdiff [ 73%]Downloading main-52.cdiff [ 73%]Downloading main-52.cdiff [ 73%]Downloading main-52.cdiff [ 73%]Downloading main-52.cdiff [ 73%]Downloading main-52.cdiff [ 73%]Downloading main-52.cdiff [ 74%]Downloading main-52.cdiff [ 74%]Downloading main-52.cdiff [ 74%]Downloading main-52.cdiff [ 74%]Downloading main-52.cdiff [ 74%]Downloading main-52.cdiff [ 74%]Downloading main-52.cdiff [ 74%]Downloading main-52.cdiff [ 74%]Downloading main-52.cdiff [ 74%]Downloading main-52.cdiff [ 74%]Downloading main-52.cdiff [ 74%]Downloading main-52.cdiff [ 74%]Downloading main-52.cdiff [ 74%]Downloading main-52.cdiff [ 74%]Downloading main-52.cdiff [ 74%]Downloading main-52.cdiff [ 74%]Downloading main-52.cdiff [ 74%]Downloading main-52.cdiff [ 75%]Downloading main-52.cdiff [ 75%]Downloading main-52.cdiff [ 75%]Downloading main-52.cdiff [ 75%]Downloading main-52.cdiff [ 75%]Downloading main-52.cdiff [ 75%]Downloading main-52.cdiff [ 75%]Downloading main-52.cdiff [ 75%]Downloading main-52.cdiff [ 75%]Downloading main-52.cdiff [ 75%]Downloading main-52.cdiff [ 75%]Downloading main-52.cdiff [ 75%]Downloading main-52.cdiff [ 75%]Downloading main-52.cdiff [ 75%]Downloading main-52.cdiff [ 75%]Downloading main-52.cdiff [ 75%]Downloading main-52.cdiff [ 75%]Downloading main-52.cdiff [ 75%]Downloading main-52.cdiff [ 76%]Downloading main-52.cdiff [ 76%]Downloading main-52.cdiff [ 76%]Downloading main-52.cdiff [ 76%]Downloading main-52.cdiff [ 76%]Downloading main-52.cdiff [ 76%]Downloading main-52.cdiff [ 76%]Downloading main-52.cdiff [ 76%]Downloading main-52.cdiff [ 76%]Downloading main-52.cdiff [ 76%]Downloading main-52.cdiff [ 76%]Downloading main-52.cdiff [ 77%]Downloading main-52.cdiff [ 77%]Downloading main-52.cdiff [ 77%]Downloading main-52.cdiff [ 77%]Downloading main-52.cdiff [ 77%]Downloading main-52.cdiff [ 77%]Downloading main-52.cdiff [ 77%]Downloading main-52.cdiff [ 77%]Downloading main-52.cdiff [ 77%]Downloading main-52.cdiff [ 77%]Downloading main-52.cdiff [ 77%]Downloading main-52.cdiff [ 77%]Downloading main-52.cdiff [ 77%]Downloading main-52.cdiff [ 77%]Downloading main-52.cdiff [ 77%]Downloading main-52.cdiff [ 77%]Downloading main-52.cdiff [ 77%]Downloading main-52.cdiff [ 77%]Downloading main-52.cdiff [ 77%]Downloading main-52.cdiff [ 77%]Downloading main-52.cdiff [ 78%]Downloading main-52.cdiff [ 78%]Downloading main-52.cdiff [ 78%]Downloading main-52.cdiff [ 78%]Downloading main-52.cdiff [ 78%]Downloading main-52.cdiff [ 78%]Downloading main-52.cdiff [ 78%]Downloading main-52.cdiff [ 78%]Downloading main-52.cdiff [ 78%]Downloading main-52.cdiff [ 78%]Downloading main-52.cdiff [ 78%]Downloading main-52.cdiff [ 78%]Downloading main-52.cdiff [ 78%]Downloading main-52.cdiff [ 78%]Downloading main-52.cdiff [ 78%]Downloading main-52.cdiff [ 78%]Downloading main-52.cdiff [ 78%]Downloading main-52.cdiff [ 79%]Downloading main-52.cdiff [ 79%]Downloading main-52.cdiff [ 79%]Downloading main-52.cdiff [ 79%]Downloading main-52.cdiff [ 79%]Downloading main-52.cdiff [ 79%]Downloading main-52.cdiff [ 79%]Downloading main-52.cdiff [ 79%]Downloading main-52.cdiff [ 79%]Downloading main-52.cdiff [ 79%]Downloading main-52.cdiff [ 79%]Downloading main-52.cdiff [ 79%]Downloading main-52.cdiff [ 79%]Downloading main-52.cdiff [ 79%]Downloading main-52.cdiff [ 79%]Downloading main-52.cdiff [ 79%]Downloading main-52.cdiff [ 79%]Downloading main-52.cdiff [ 80%]Downloading main-52.cdiff [ 80%]Downloading main-52.cdiff [ 80%]Downloading main-52.cdiff [ 80%]Downloading main-52.cdiff [ 80%]Downloading main-52.cdiff [ 80%]Downloading main-52.cdiff [ 80%]Downloading main-52.cdiff [ 80%]Downloading main-52.cdiff [ 80%]Downloading main-52.cdiff [ 80%]Downloading main-52.cdiff [ 80%]Downloading main-52.cdiff [ 80%]Downloading main-52.cdiff [ 80%]Downloading main-52.cdiff [ 80%]Downloading main-52.cdiff [ 80%]Downloading main-52.cdiff [ 80%]Downloading main-52.cdiff [ 80%]Downloading main-52.cdiff [ 80%]Downloading main-52.cdiff [ 80%]Downloading main-52.cdiff [ 80%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 81%]Downloading main-52.cdiff [ 82%]Downloading main-52.cdiff [ 82%]Downloading main-52.cdiff [ 82%]Downloading main-52.cdiff [ 82%]Downloading main-52.cdiff [ 82%]Downloading main-52.cdiff [ 82%]Downloading main-52.cdiff [ 82%]Downloading main-52.cdiff [ 82%]Downloading main-52.cdiff [ 82%]Downloading main-52.cdiff [ 82%]Downloading main-52.cdiff [ 82%]Downloading main-52.cdiff [ 82%]Downloading main-52.cdiff [ 82%]Downloading main-52.cdiff [ 82%]Downloading main-52.cdiff [ 82%]Downloading main-52.cdiff [ 82%]Downloading main-52.cdiff [ 82%]Downloading main-52.cdiff [ 82%]Downloading main-52.cdiff [ 82%]Downloading main-52.cdiff [ 82%]Downloading main-52.cdiff [ 83%]Downloading main-52.cdiff [ 83%]Downloading main-52.cdiff [ 83%]Downloading main-52.cdiff [ 83%]Downloading main-52.cdiff [ 83%]Downloading main-52.cdiff [ 83%]Downloading main-52.cdiff [ 83%]Downloading main-52.cdiff [ 83%]Downloading main-52.cdiff [ 83%]Downloading main-52.cdiff [ 83%]Downloading main-52.cdiff [ 83%]Downloading main-52.cdiff [ 83%]Downloading main-52.cdiff [ 83%]Downloading main-52.cdiff [ 83%]Downloading main-52.cdiff [ 83%]Downloading main-52.cdiff [ 83%]Downloading main-52.cdiff [ 83%]Downloading main-52.cdiff [ 83%]Downloading main-52.cdiff [ 83%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 84%]Downloading main-52.cdiff [ 85%]Downloading main-52.cdiff [ 85%]Downloading main-52.cdiff [ 85%]Downloading main-52.cdiff [ 85%]Downloading main-52.cdiff [ 85%]Downloading main-52.cdiff [ 85%]Downloading main-52.cdiff [ 85%]Downloading main-52.cdiff [ 85%]Downloading main-52.cdiff [ 85%]Downloading main-52.cdiff [ 85%]Downloading main-52.cdiff [ 85%]Downloading main-52.cdiff [ 85%]Downloading main-52.cdiff [ 85%]Downloading main-52.cdiff [ 85%]Downloading main-52.cdiff [ 85%]Downloading main-52.cdiff [ 85%]Downloading main-52.cdiff [ 85%]Downloading main-52.cdiff [ 85%]Downloading main-52.cdiff [ 85%]Downloading main-52.cdiff [ 85%]Downloading main-52.cdiff [ 86%]Downloading main-52.cdiff [ 86%]Downloading main-52.cdiff [ 86%]Downloading main-52.cdiff [ 86%]Downloading main-52.cdiff [ 86%]Downloading main-52.cdiff [ 86%]Downloading main-52.cdiff [ 86%]Downloading main-52.cdiff [ 86%]Downloading main-52.cdiff [ 86%]Downloading main-52.cdiff [ 86%]Downloading main-52.cdiff [ 86%]Downloading main-52.cdiff [ 86%]Downloading main-52.cdiff [ 86%]Downloading main-52.cdiff [ 86%]Downloading main-52.cdiff [ 86%]Downloading main-52.cdiff [ 86%]Downloading main-52.cdiff [ 86%]Downloading main-52.cdiff [ 86%]Downloading main-52.cdiff [ 86%]Downloading main-52.cdiff [ 86%]Downloading main-52.cdiff [ 87%]Downloading main-52.cdiff [ 87%]Downloading main-52.cdiff [ 87%]Downloading main-52.cdiff [ 87%]Downloading main-52.cdiff [ 87%]Downloading main-52.cdiff [ 87%]Downloading main-52.cdiff [ 87%]Downloading main-52.cdiff [ 87%]Downloading main-52.cdiff [ 87%]Downloading main-52.cdiff [ 87%]Downloading main-52.cdiff [ 87%]Downloading main-52.cdiff [ 87%]Downloading main-52.cdiff [ 87%]Downloading main-52.cdiff [ 87%]Downloading main-52.cdiff [ 87%]Downloading main-52.cdiff [ 87%]Downloading main-52.cdiff [ 87%]Downloading main-52.cdiff [ 87%]Downloading main-52.cdiff [ 87%]Downloading main-52.cdiff [ 87%]Downloading main-52.cdiff [ 88%]Downloading main-52.cdiff [ 88%]Downloading main-52.cdiff [ 88%]Downloading main-52.cdiff [ 88%]Downloading main-52.cdiff [ 88%]Downloading main-52.cdiff [ 88%]Downloading main-52.cdiff [ 88%]Downloading main-52.cdiff [ 88%]Downloading main-52.cdiff [ 88%]Downloading main-52.cdiff [ 88%]Downloading main-52.cdiff [ 88%]Downloading main-52.cdiff [ 88%]Downloading main-52.cdiff [ 88%]Downloading main-52.cdiff [ 88%]Downloading main-52.cdiff [ 88%]Downloading main-52.cdiff [ 88%]Downloading main-52.cdiff [ 88%]Downloading main-52.cdiff [ 88%]Downloading main-52.cdiff [ 89%]Downloading main-52.cdiff [ 89%]Downloading main-52.cdiff [ 89%]Downloading main-52.cdiff [ 89%]Downloading main-52.cdiff [ 89%]Downloading main-52.cdiff [ 89%]Downloading main-52.cdiff [ 89%]Downloading main-52.cdiff [ 89%]Downloading main-52.cdiff [ 89%]Downloading main-52.cdiff [ 89%]Downloading main-52.cdiff [ 89%]Downloading main-52.cdiff [ 89%]Downloading main-52.cdiff [ 89%]Downloading main-52.cdiff [ 89%]Downloading main-52.cdiff [ 89%]Downloading main-52.cdiff [ 89%]Downloading main-52.cdiff [ 89%]Downloading main-52.cdiff [ 89%]Downloading main-52.cdiff [ 89%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 90%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 91%]Downloading main-52.cdiff [ 92%]Downloading main-52.cdiff [ 92%]Downloading main-52.cdiff [ 92%]Downloading main-52.cdiff [ 92%]Downloading main-52.cdiff [ 92%]Downloading main-52.cdiff [ 92%]Downloading main-52.cdiff [ 92%]Downloading main-52.cdiff [ 92%]Downloading main-52.cdiff [ 92%]Downloading main-52.cdiff [ 92%]Downloading main-52.cdiff [ 92%]Downloading main-52.cdiff [ 92%]Downloading main-52.cdiff [ 92%]Downloading main-52.cdiff [ 92%]Downloading main-52.cdiff [ 92%]Downloading main-52.cdiff [ 92%]Downloading main-52.cdiff [ 92%]Downloading main-52.cdiff [ 92%]Downloading main-52.cdiff [ 92%]Downloading main-52.cdiff [ 92%]Downloading main-52.cdiff [ 93%]Downloading main-52.cdiff [ 93%]Downloading main-52.cdiff [ 93%]Downloading main-52.cdiff [ 93%]Downloading main-52.cdiff [ 93%]Downloading main-52.cdiff [ 93%]Downloading main-52.cdiff [ 93%]Downloading main-52.cdiff [ 93%]Downloading main-52.cdiff [ 93%]Downloading main-52.cdiff [ 93%]Downloading main-52.cdiff [ 93%]Downloading main-52.cdiff [ 93%]Downloading main-52.cdiff [ 93%]Downloading main-52.cdiff [ 93%]Downloading main-52.cdiff [ 93%]Downloading main-52.cdiff [ 93%]Downloading main-52.cdiff [ 93%]Downloading main-52.cdiff [ 93%]Downloading main-52.cdiff [ 93%]Downloading main-52.cdiff [ 93%]Downloading main-52.cdiff [ 94%]Downloading main-52.cdiff [ 94%]Downloading main-52.cdiff [ 94%]Downloading main-52.cdiff [ 94%]Downloading main-52.cdiff [ 94%]Downloading main-52.cdiff [ 94%]Downloading main-52.cdiff [ 94%]Downloading main-52.cdiff [ 94%]Downloading main-52.cdiff [ 94%]Downloading main-52.cdiff [ 94%]Downloading main-52.cdiff [ 94%]Downloading main-52.cdiff [ 94%]Downloading main-52.cdiff [ 94%]Downloading main-52.cdiff [ 94%]Downloading main-52.cdiff [ 94%]Downloading main-52.cdiff [ 94%]Downloading main-52.cdiff [ 94%]Downloading main-52.cdiff [ 94%]Downloading main-52.cdiff [ 94%]Downloading main-52.cdiff [ 94%]Downloading main-52.cdiff [ 95%]Downloading main-52.cdiff [ 95%]Downloading main-52.cdiff [ 95%]Downloading main-52.cdiff [ 95%]Downloading main-52.cdiff [ 95%]Downloading main-52.cdiff [ 95%]Downloading main-52.cdiff [ 95%]Downloading main-52.cdiff [ 95%]Downloading main-52.cdiff [ 95%]Downloading main-52.cdiff [ 95%]Downloading main-52.cdiff [ 95%]Downloading main-52.cdiff [ 95%]Downloading main-52.cdiff [ 95%]Downloading main-52.cdiff [ 95%]Downloading main-52.cdiff [ 95%]Downloading main-52.cdiff [ 95%]Downloading main-52.cdiff [ 95%]Downloading main-52.cdiff [ 95%]Downloading main-52.cdiff [ 96%]Downloading main-52.cdiff [ 96%]Downloading main-52.cdiff [ 96%]Downloading main-52.cdiff [ 96%]Downloading main-52.cdiff [ 96%]Downloading main-52.cdiff [ 96%]Downloading main-52.cdiff [ 96%]Downloading main-52.cdiff [ 96%]Downloading main-52.cdiff [ 96%]Downloading main-52.cdiff [ 96%]Downloading main-52.cdiff [ 96%]Downloading main-52.cdiff [ 96%]Downloading main-52.cdiff [ 96%]Downloading main-52.cdiff [ 96%]Downloading main-52.cdiff [ 96%]Downloading main-52.cdiff [ 96%]Downloading main-52.cdiff [ 96%]Downloading main-52.cdiff [ 96%]Downloading main-52.cdiff [ 96%]Downloading main-52.cdiff [ 96%]Downloading main-52.cdiff [ 97%]Downloading main-52.cdiff [ 97%]Downloading main-52.cdiff [ 97%]Downloading main-52.cdiff [ 97%]Downloading main-52.cdiff [ 97%]Downloading main-52.cdiff [ 97%]Downloading main-52.cdiff [ 97%]Downloading main-52.cdiff [ 97%]Downloading main-52.cdiff [ 97%]Downloading main-52.cdiff [ 97%]Downloading main-52.cdiff [ 97%]Downloading main-52.cdiff [ 97%]Downloading main-52.cdiff [ 97%]Downloading main-52.cdiff [ 97%]Downloading main-52.cdiff [ 97%]Downloading main-52.cdiff [ 97%]Downloading main-52.cdiff [ 97%]Downloading main-52.cdiff [ 97%]Downloading main-52.cdiff [ 97%]Downloading main-52.cdiff [ 97%]Downloading main-52.cdiff [ 98%]Downloading main-52.cdiff [ 98%]Downloading main-52.cdiff [ 98%]Downloading main-52.cdiff [ 98%]Downloading main-52.cdiff [ 98%]Downloading main-52.cdiff [ 98%]Downloading main-52.cdiff [ 98%]Downloading main-52.cdiff [ 98%]Downloading main-52.cdiff [ 98%]Downloading main-52.cdiff [ 98%]Downloading main-52.cdiff [ 98%]Downloading main-52.cdiff [ 98%]Downloading main-52.cdiff [ 98%]Downloading main-52.cdiff [ 98%]Downloading main-52.cdiff [ 98%]Downloading main-52.cdiff [ 98%]Downloading main-52.cdiff [ 98%]Downloading main-52.cdiff [ 98%]Downloading main-52.cdiff [ 98%]Downloading main-52.cdiff [ 98%]Downloading main-52.cdiff [ 99%]Downloading main-52.cdiff [ 99%]Downloading main-52.cdiff [ 99%]Downloading main-52.cdiff [ 99%]Downloading main-52.cdiff [ 99%]Downloading main-52.cdiff [ 99%]Downloading main-52.cdiff [ 99%]Downloading main-52.cdiff [ 99%]Downloading main-52.cdiff [ 99%]Downloading main-52.cdiff [ 99%]Downloading main-52.cdiff [ 99%]Downloading main-52.cdiff [ 99%]Downloading main-52.cdiff [ 99%]Downloading main-52.cdiff [ 99%]Downloading main-52.cdiff [ 99%]Downloading main-52.cdiff [ 99%]Downloading main-52.cdiff [ 99%]Downloading main-52.cdiff [ 99%]Downloading main-52.cdiff [ 99%]Downloading main-52.cdiff [100%]Downloading main-52.cdiff [100%]
main.cld updated (version: 52, sigs: 704727, f-level: 44, builder: sven)
Trying host database.clamav.net (194.47.250.218)…
nonblock_connect: connect timing out (30 secs)
Can’t connect to port 80 of host database.clamav.net (IP: 194.47.250.218)
Trying host database.clamav.net (207.57.106.31)…
Trying host database.clamav.net (155.98.64.87)…
Trying host database.clamav.net (209.222.131.222)…
Downloading daily.cvd [ 0%]Downloading daily.cvd [ 0%]Downloading daily.cvd [ 0%]Downloading daily.cvd [ 0%]Downloading daily.cvd [ 0%]Downloading daily.cvd [ 0%]Downloading daily.cvd [ 0%]Downloading daily.cvd [ 1%]Downloading daily.cvd [ 1%]Downloading daily.cvd [ 1%]Downloading daily.cvd [ 1%]Downloading daily.cvd [ 1%]Downloading daily.cvd [ 1%]Downloading daily.cvd [ 1%]Downloading daily.cvd [ 1%]Downloading daily.cvd [ 1%]Downloading daily.cvd [ 1%]Downloading daily.cvd [ 1%]Downloading daily.cvd [ 2%]Downloading daily.cvd [ 2%]Downloading daily.cvd [ 2%]Downloading daily.cvd [ 2%]Downloading daily.cvd [ 2%]Downloading daily.cvd [ 2%]Downloading daily.cvd [ 2%]Downloading daily.cvd [ 2%]Downloading daily.cvd [ 2%]Downloading daily.cvd [ 2%]Downloading daily.cvd [ 3%]Downloading daily.cvd [ 3%]Downloading daily.cvd [ 3%]Downloading daily.cvd [ 3%]Downloading daily.cvd [ 3%]Downloading daily.cvd [ 3%]Downloading daily.cvd [ 3%]Downloading daily.cvd [ 3%]Downloading daily.cvd [ 3%]Downloading daily.cvd [ 4%]Downloading daily.cvd [ 4%]Downloading daily.cvd [ 4%]Downloading daily.cvd [ 4%]Downloading daily.cvd [ 4%]Downloading daily.cvd [ 4%]Downloading daily.cvd [ 4%]Downloading daily.cvd [ 4%]Downloading daily.cvd [ 4%]Downloading daily.cvd [ 5%]Downloading daily.cvd [ 5%]Downloading daily.cvd [ 5%]Downloading daily.cvd [ 5%]Downloading daily.cvd [ 5%]Downloading daily.cvd [ 5%]Downloading daily.cvd [ 5%]Downloading daily.cvd [ 5%]Downloading daily.cvd [ 5%]Downloading daily.cvd [ 5%]Downloading daily.cvd [ 6%]Downloading daily.cvd [ 6%]Downloading daily.cvd [ 6%]Downloading daily.cvd [ 6%]Downloading daily.cvd [ 6%]Downloading daily.cvd [ 6%]Downloading daily.cvd [ 6%]Downloading daily.cvd [ 6%]Downloading daily.cvd [ 6%]Downloading daily.cvd [ 6%]Downloading daily.cvd [ 7%]Downloading daily.cvd [ 7%]Downloading daily.cvd [ 7%]Downloading daily.cvd [ 7%]Downloading daily.cvd [ 7%]Downloading daily.cvd [ 7%]Downloading daily.cvd [ 7%]Downloading daily.cvd [ 7%]Downloading daily.cvd [ 7%]Downloading daily.cvd [ 8%]Downloading daily.cvd [ 8%]Downloading daily.cvd [ 8%]Downloading daily.cvd [ 8%]Downloading daily.cvd [ 8%]Downloading daily.cvd [ 8%]Downloading daily.cvd [ 8%]Downloading daily.cvd [ 8%]Downloading daily.cvd [ 8%]Downloading daily.cvd [ 9%]Downloading daily.cvd [ 9%]Downloading daily.cvd [ 9%]Downloading daily.cvd [ 9%]Downloading daily.cvd [ 9%]Downloading daily.cvd [ 9%]Downloading daily.cvd [ 9%]Downloading daily.cvd [ 9%]Downloading daily.cvd [ 9%]Downloading daily.cvd [ 9%]Downloading daily.cvd [ 9%]Downloading daily.cvd [ 10%]Downloading daily.cvd [ 10%]Downloading daily.cvd [ 10%]Downloading daily.cvd [ 10%]Downloading daily.cvd [ 10%]Downloading daily.cvd [ 10%]Downloading daily.cvd [ 10%]Downloading daily.cvd [ 10%]Downloading daily.cvd [ 10%]Downloading daily.cvd [ 10%]Downloading daily.cvd [ 11%]Downloading daily.cvd [ 11%]Downloading daily.cvd [ 11%]Downloading daily.cvd [ 11%]Downloading daily.cvd [ 11%]Downloading daily.cvd [ 11%]Downloading daily.cvd [ 11%]Downloading daily.cvd [ 11%]Downloading daily.cvd [ 11%]Downloading daily.cvd [ 11%]Downloading daily.cvd [ 12%]Downloading daily.cvd [ 12%]Downloading daily.cvd [ 12%]Downloading daily.cvd [ 12%]Downloading daily.cvd [ 12%]Downloading daily.cvd [ 12%]Downloading daily.cvd [ 12%]Downloading daily.cvd [ 12%]Downloading daily.cvd [ 12%]Downloading daily.cvd [ 12%]Downloading daily.cvd [ 13%]Downloading daily.cvd [ 13%]Downloading daily.cvd [ 13%]Downloading daily.cvd [ 13%]Downloading daily.cvd [ 13%]Downloading daily.cvd [ 13%]Downloading daily.cvd [ 13%]Downloading daily.cvd [ 13%]Downloading daily.cvd [ 13%]Downloading daily.cvd [ 14%]Downloading daily.cvd [ 14%]Downloading daily.cvd [ 14%]Downloading daily.cvd [ 14%]Downloading daily.cvd [ 14%]Downloading daily.cvd [ 14%]Downloading daily.cvd [ 14%]Downloading daily.cvd [ 14%]Downloading daily.cvd [ 14%]Downloading daily.cvd [ 15%]Downloading daily.cvd [ 15%]Downloading daily.cvd [ 15%]Downloading daily.cvd [ 15%]Downloading daily.cvd [ 15%]Downloading daily.cvd [ 15%]Downloading daily.cvd [ 15%]Downloading daily.cvd [ 15%]Downloading daily.cvd [ 16%]Downloading daily.cvd [ 16%]Downloading daily.cvd [ 16%]Downloading daily.cvd [ 16%]Downloading daily.cvd [ 16%]Downloading daily.cvd [ 16%]Downloading daily.cvd [ 16%]Downloading daily.cvd [ 16%]Downloading daily.cvd [ 16%]Downloading daily.cvd [ 16%]Downloading daily.cvd [ 17%]Downloading daily.cvd [ 17%]Downloading daily.cvd [ 17%]Downloading daily.cvd [ 17%]Downloading daily.cvd [ 17%]Downloading daily.cvd [ 17%]Downloading daily.cvd [ 17%]Downloading daily.cvd [ 17%]Downloading daily.cvd [ 17%]Downloading daily.cvd [ 17%]Downloading daily.cvd [ 18%]Downloading daily.cvd [ 18%]Downloading daily.cvd [ 18%]Downloading daily.cvd [ 18%]Downloading daily.cvd [ 18%]Downloading daily.cvd [ 18%]Downloading daily.cvd [ 18%]Downloading daily.cvd [ 18%]Downloading daily.cvd [ 18%]Downloading daily.cvd [ 18%]Downloading daily.cvd [ 19%]Downloading daily.cvd [ 19%]Downloading daily.cvd [ 19%]Downloading daily.cvd [ 19%]Downloading daily.cvd [ 19%]Downloading daily.cvd [ 19%]Downloading daily.cvd [ 19%]Downloading daily.cvd [ 19%]Downloading daily.cvd [ 20%]Downloading daily.cvd [ 20%]Downloading daily.cvd [ 20%]Downloading daily.cvd [ 20%]Downloading daily.cvd [ 20%]Downloading daily.cvd [ 20%]Downloading daily.cvd [ 20%]Downloading daily.cvd [ 20%]Downloading daily.cvd [ 21%]Downloading daily.cvd [ 21%]Downloading daily.cvd [ 21%]Downloading daily.cvd [ 21%]Downloading daily.cvd [ 21%]Downloading daily.cvd [ 21%]Downloading daily.cvd [ 21%]Downloading daily.cvd [ 21%]Downloading daily.cvd [ 21%]Downloading daily.cvd [ 21%]Downloading daily.cvd [ 22%]Downloading daily.cvd [ 22%]Downloading daily.cvd [ 22%]Downloading daily.cvd [ 22%]Downloading daily.cvd [ 22%]Downloading daily.cvd [ 22%]Downloading daily.cvd [ 22%]Downloading daily.cvd [ 22%]Downloading daily.cvd [ 22%]Downloading daily.cvd [ 23%]Downloading daily.cvd [ 23%]Downloading daily.cvd [ 23%]Downloading daily.cvd [ 23%]Downloading daily.cvd [ 23%]Downloading daily.cvd [ 23%]Downloading daily.cvd [ 23%]Downloading daily.cvd [ 23%]Downloading daily.cvd [ 24%]Downloading daily.cvd [ 24%]Downloading daily.cvd [ 24%]Downloading daily.cvd [ 24%]Downloading daily.cvd [ 24%]Downloading daily.cvd [ 24%]Downloading daily.cvd [ 24%]Downloading daily.cvd [ 24%]Downloading daily.cvd [ 24%]Downloading daily.cvd [ 24%]Downloading daily.cvd [ 24%]Downloading daily.cvd [ 25%]Downloading daily.cvd [ 25%]Downloading daily.cvd [ 25%]Downloading daily.cvd [ 25%]Downloading daily.cvd [ 25%]Downloading daily.cvd [ 25%]Downloading daily.cvd [ 25%]Downloading daily.cvd [ 25%]Downloading daily.cvd [ 25%]Downloading daily.cvd [ 26%]Downloading daily.cvd [ 26%]Downloading daily.cvd [ 26%]Downloading daily.cvd [ 26%]Downloading daily.cvd [ 26%]Downloading daily.cvd [ 26%]Downloading daily.cvd [ 26%]Downloading daily.cvd [ 26%]Downloading daily.cvd [ 26%]Downloading daily.cvd [ 26%]Downloading daily.cvd [ 27%]Downloading daily.cvd [ 27%]Downloading daily.cvd [ 27%]Downloading daily.cvd [ 27%]Downloading daily.cvd [ 27%]Downloading daily.cvd [ 27%]Downloading daily.cvd [ 27%]Downloading daily.cvd [ 27%]Downloading daily.cvd [ 27%]Downloading daily.cvd [ 28%]Downloading daily.cvd [ 28%]Downloading daily.cvd [ 28%]Downloading daily.cvd [ 28%]Downloading daily.cvd [ 28%]Downloading daily.cvd [ 28%]Downloading daily.cvd [ 28%]Downloading daily.cvd [ 28%]Downloading daily.cvd [ 28%]Downloading daily.cvd [ 29%]Downloading daily.cvd [ 29%]Downloading daily.cvd [ 29%]Downloading daily.cvd [ 29%]Downloading daily.cvd [ 29%]Downloading daily.cvd [ 29%]Downloading daily.cvd [ 29%]Downloading daily.cvd [ 29%]Downloading daily.cvd [ 29%]Downloading daily.cvd [ 29%]Downloading daily.cvd [ 30%]Downloading daily.cvd [ 30%]Downloading daily.cvd [ 30%]Downloading daily.cvd [ 30%]Downloading daily.cvd [ 30%]Downloading daily.cvd [ 30%]Downloading daily.cvd [ 30%]Downloading daily.cvd [ 30%]Downloading daily.cvd [ 30%]Downloading daily.cvd [ 31%]Downloading daily.cvd [ 31%]Downloading daily.cvd [ 31%]Downloading daily.cvd [ 31%]Downloading daily.cvd [ 31%]Downloading daily.cvd [ 31%]Downloading daily.cvd [ 31%]Downloading daily.cvd [ 31%]Downloading daily.cvd [ 32%]Downloading daily.cvd [ 32%]Downloading daily.cvd [ 32%]Downloading daily.cvd [ 32%]Downloading daily.cvd [ 32%]Downloading daily.cvd [ 32%]Downloading daily.cvd [ 32%]Downloading daily.cvd [ 33%]Downloading daily.cvd [ 33%]Downloading daily.cvd [ 33%]Downloading daily.cvd [ 33%]Downloading daily.cvd [ 33%]Downloading daily.cvd [ 33%]Downloading daily.cvd [ 33%]Downloading daily.cvd [ 33%]Downloading daily.cvd [ 33%]Downloading daily.cvd [ 34%]Downloading daily.cvd [ 34%]Downloading daily.cvd [ 34%]Downloading daily.cvd [ 34%]Downloading daily.cvd [ 34%]Downloading daily.cvd [ 34%]Downloading daily.cvd [ 34%]Downloading daily.cvd [ 35%]Downloading daily.cvd [ 35%]Downloading daily.cvd [ 35%]Downloading daily.cvd [ 35%]Downloading daily.cvd [ 35%]Downloading daily.cvd [ 35%]Downloading daily.cvd [ 35%]Downloading daily.cvd [ 35%]Downloading daily.cvd [ 36%]Downloading daily.cvd [ 36%]Downloading daily.cvd [ 36%]Downloading daily.cvd [ 36%]Downloading daily.cvd [ 36%]Downloading daily.cvd [ 36%]Downloading daily.cvd [ 36%]Downloading daily.cvd [ 36%]Downloading daily.cvd [ 37%]Downloading daily.cvd [ 37%]Downloading daily.cvd [ 37%]Downloading daily.cvd [ 37%]Downloading daily.cvd [ 37%]Downloading daily.cvd [ 37%]Downloading daily.cvd [ 37%]Downloading daily.cvd [ 37%]Downloading daily.cvd [ 37%]Downloading daily.cvd [ 38%]Downloading daily.cvd [ 38%]Downloading daily.cvd [ 38%]Downloading daily.cvd [ 38%]Downloading daily.cvd [ 38%]Downloading daily.cvd [ 38%]Downloading daily.cvd [ 38%]Downloading daily.cvd [ 39%]Downloading daily.cvd [ 39%]Downloading daily.cvd [ 39%]Downloading daily.cvd [ 39%]Downloading daily.cvd [ 39%]Downloading daily.cvd [ 39%]Downloading daily.cvd [ 39%]Downloading daily.cvd [ 39%]Downloading daily.cvd [ 40%]Downloading daily.cvd [ 40%]Downloading daily.cvd [ 40%]Downloading daily.cvd [ 40%]Downloading daily.cvd [ 40%]Downloading daily.cvd [ 40%]Downloading daily.cvd [ 40%]Downloading daily.cvd [ 40%]Downloading daily.cvd [ 40%]Downloading daily.cvd [ 41%]Downloading daily.cvd [ 41%]Downloading daily.cvd [ 41%]Downloading daily.cvd [ 41%]Downloading daily.cvd [ 41%]Downloading daily.cvd [ 41%]Downloading daily.cvd [ 41%]Downloading daily.cvd [ 42%]Downloading daily.cvd [ 42%]Downloading daily.cvd [ 42%]Downloading daily.cvd [ 42%]Downloading daily.cvd [ 42%]Downloading daily.cvd [ 42%]Downloading daily.cvd [ 42%]Downloading daily.cvd [ 42%]Downloading daily.cvd [ 42%]Downloading daily.cvd [ 42%]Downloading daily.cvd [ 43%]Downloading daily.cvd [ 43%]Downloading daily.cvd [ 43%]Downloading daily.cvd [ 43%]Downloading daily.cvd [ 43%]Downloading daily.cvd [ 43%]Downloading daily.cvd [ 43%]Downloading daily.cvd [ 43%]Downloading daily.cvd [ 43%]Downloading daily.cvd [ 43%]Downloading daily.cvd [ 44%]Downloading daily.cvd [ 44%]Downloading daily.cvd [ 44%]Downloading daily.cvd [ 44%]Downloading daily.cvd [ 44%]Downloading daily.cvd [ 44%]Downloading daily.cvd [ 44%]Downloading daily.cvd [ 44%]Downloading daily.cvd [ 45%]Downloading daily.cvd [ 45%]Downloading daily.cvd [ 45%]Downloading daily.cvd [ 45%]Downloading daily.cvd [ 45%]Downloading daily.cvd [ 45%]Downloading daily.cvd [ 45%]Downloading daily.cvd [ 45%]Downloading daily.cvd [ 45%]Downloading daily.cvd [ 46%]Downloading daily.cvd [ 46%]Downloading daily.cvd [ 46%]Downloading daily.cvd [ 46%]Downloading daily.cvd [ 46%]Downloading daily.cvd [ 46%]Downloading daily.cvd [ 46%]Downloading daily.cvd [ 46%]Downloading daily.cvd [ 47%]Downloading daily.cvd [ 47%]Downloading daily.cvd [ 47%]Downloading daily.cvd [ 47%]Downloading daily.cvd [ 47%]Downloading daily.cvd [ 47%]Downloading daily.cvd [ 47%]Downloading daily.cvd [ 47%]Downloading daily.cvd [ 47%]Downloading daily.cvd [ 47%]Downloading daily.cvd [ 48%]Downloading daily.cvd [ 48%]Downloading daily.cvd [ 48%]Downloading daily.cvd [ 48%]Downloading daily.cvd [ 48%]Downloading daily.cvd [ 48%]Downloading daily.cvd [ 48%]Downloading daily.cvd [ 48%]Downloading daily.cvd [ 48%]Downloading daily.cvd [ 49%]Downloading daily.cvd [ 49%]Downloading daily.cvd [ 49%]Downloading daily.cvd [ 49%]Downloading daily.cvd [ 49%]Downloading daily.cvd [ 49%]Downloading daily.cvd [ 49%]Downloading daily.cvd [ 49%]Downloading daily.cvd [ 49%]Downloading daily.cvd [ 49%]Downloading daily.cvd [ 50%]Downloading daily.cvd [ 50%]Downloading daily.cvd [ 50%]Downloading daily.cvd [ 50%]Downloading daily.cvd [ 50%]Downloading daily.cvd [ 50%]Downloading daily.cvd [ 50%]Downloading daily.cvd [ 50%]Downloading daily.cvd [ 50%]Downloading daily.cvd [ 51%]Downloading daily.cvd [ 51%]Downloading daily.cvd [ 51%]Downloading daily.cvd [ 51%]Downloading daily.cvd [ 51%]Downloading daily.cvd [ 51%]Downloading daily.cvd [ 51%]Downloading daily.cvd [ 51%]Downloading daily.cvd [ 51%]Downloading daily.cvd [ 52%]Downloading daily.cvd [ 52%]Downloading daily.cvd [ 52%]Downloading daily.cvd [ 52%]Downloading daily.cvd [ 52%]Downloading daily.cvd [ 52%]Downloading daily.cvd [ 52%]Downloading daily.cvd [ 52%]Downloading daily.cvd [ 52%]Downloading daily.cvd [ 52%]Downloading daily.cvd [ 52%]Downloading daily.cvd [ 53%]Downloading daily.cvd [ 53%]Downloading daily.cvd [ 53%]Downloading daily.cvd [ 53%]Downloading daily.cvd [ 53%]Downloading daily.cvd [ 53%]Downloading daily.cvd [ 53%]Downloading daily.cvd [ 53%]Downloading daily.cvd [ 53%]Downloading daily.cvd [ 54%]Downloading daily.cvd [ 54%]Downloading daily.cvd [ 54%]Downloading daily.cvd [ 54%]Downloading daily.cvd [ 54%]Downloading daily.cvd [ 54%]Downloading daily.cvd [ 54%]Downloading daily.cvd [ 54%]Downloading daily.cvd [ 54%]Downloading daily.cvd [ 54%]Downloading daily.cvd [ 55%]Downloading daily.cvd [ 55%]Downloading daily.cvd [ 55%]Downloading daily.cvd [ 55%]Downloading daily.cvd [ 55%]Downloading daily.cvd [ 55%]Downloading daily.cvd [ 55%]Downloading daily.cvd [ 55%]Downloading daily.cvd [ 55%]Downloading daily.cvd [ 56%]Downloading daily.cvd [ 56%]Downloading daily.cvd [ 56%]Downloading daily.cvd [ 56%]Downloading daily.cvd [ 56%]Downloading daily.cvd [ 56%]Downloading daily.cvd [ 56%]Downloading daily.cvd [ 56%]Downloading daily.cvd [ 56%]Downloading daily.cvd [ 57%]Downloading daily.cvd [ 57%]Downloading daily.cvd [ 57%]Downloading daily.cvd [ 57%]Downloading daily.cvd [ 57%]Downloading daily.cvd [ 57%]Downloading daily.cvd [ 57%]Downloading daily.cvd [ 57%]Downloading daily.cvd [ 57%]Downloading daily.cvd [ 57%]Downloading daily.cvd [ 58%]Downloading daily.cvd [ 58%]Downloading daily.cvd [ 58%]Downloading daily.cvd [ 58%]Downloading daily.cvd [ 58%]Downloading daily.cvd [ 58%]Downloading daily.cvd [ 58%]Downloading daily.cvd [ 58%]Downloading daily.cvd [ 58%]Downloading daily.cvd [ 59%]Downloading daily.cvd [ 59%]Downloading daily.cvd [ 59%]Downloading daily.cvd [ 59%]Downloading daily.cvd [ 59%]Downloading daily.cvd [ 59%]Downloading daily.cvd [ 59%]Downloading daily.cvd [ 59%]Downloading daily.cvd [ 59%]Downloading daily.cvd [ 59%]Downloading daily.cvd [ 59%]Downloading daily.cvd [ 59%]Downloading daily.cvd [ 60%]Downloading daily.cvd [ 60%]Downloading daily.cvd [ 60%]Downloading daily.cvd [ 60%]Downloading daily.cvd [ 60%]Downloading daily.cvd [ 60%]Downloading daily.cvd [ 60%]Downloading daily.cvd [ 61%]Downloading daily.cvd [ 61%]Downloading daily.cvd [ 61%]Downloading daily.cvd [ 61%]Downloading daily.cvd [ 61%]Downloading daily.cvd [ 61%]Downloading daily.cvd [ 61%]Downloading daily.cvd [ 61%]Downloading daily.cvd [ 62%]Downloading daily.cvd [ 62%]Downloading daily.cvd [ 62%]Downloading daily.cvd [ 62%]Downloading daily.cvd [ 62%]Downloading daily.cvd [ 62%]Downloading daily.cvd [ 62%]Downloading daily.cvd [ 62%]Downloading daily.cvd [ 62%]Downloading daily.cvd [ 63%]Downloading daily.cvd [ 63%]Downloading daily.cvd [ 63%]Downloading daily.cvd [ 63%]Downloading daily.cvd [ 63%]Downloading daily.cvd [ 63%]Downloading daily.cvd [ 63%]Downloading daily.cvd [ 63%]Downloading daily.cvd [ 63%]Downloading daily.cvd [ 63%]Downloading daily.cvd [ 63%]Downloading daily.cvd [ 63%]Downloading daily.cvd [ 64%]Downloading daily.cvd [ 64%]Downloading daily.cvd [ 64%]Downloading daily.cvd [ 64%]Downloading daily.cvd [ 64%]Downloading daily.cvd [ 64%]Downloading daily.cvd [ 64%]Downloading daily.cvd [ 64%]Downloading daily.cvd [ 64%]Downloading daily.cvd [ 65%]Downloading daily.cvd [ 65%]Downloading daily.cvd [ 65%]Downloading daily.cvd [ 65%]Downloading daily.cvd [ 65%]Downloading daily.cvd [ 65%]Downloading daily.cvd [ 65%]Downloading daily.cvd [ 65%]Downloading daily.cvd [ 65%]Downloading daily.cvd [ 65%]Downloading daily.cvd [ 66%]Downloading daily.cvd [ 66%]Downloading daily.cvd [ 66%]Downloading daily.cvd [ 66%]Downloading daily.cvd [ 66%]Downloading daily.cvd [ 66%]Downloading daily.cvd [ 66%]Downloading daily.cvd [ 66%]Downloading daily.cvd [ 66%]Downloading daily.cvd [ 67%]Downloading daily.cvd [ 67%]Downloading daily.cvd [ 67%]Downloading daily.cvd [ 67%]Downloading daily.cvd [ 67%]Downloading daily.cvd [ 67%]Downloading daily.cvd [ 67%]Downloading daily.cvd [ 67%]Downloading daily.cvd [ 67%]Downloading daily.cvd [ 67%]Downloading daily.cvd [ 67%]Downloading daily.cvd [ 68%]Downloading daily.cvd [ 68%]Downloading daily.cvd [ 68%]Downloading daily.cvd [ 68%]Downloading daily.cvd [ 68%]Downloading daily.cvd [ 68%]Downloading daily.cvd [ 68%]Downloading daily.cvd [ 68%]Downloading daily.cvd [ 68%]Downloading daily.cvd [ 69%]Downloading daily.cvd [ 69%]Downloading daily.cvd [ 69%]Downloading daily.cvd [ 69%]Downloading daily.cvd [ 69%]Downloading daily.cvd [ 69%]Downloading daily.cvd [ 69%]Downloading daily.cvd [ 69%]Downloading daily.cvd [ 70%]Downloading daily.cvd [ 70%]Downloading daily.cvd [ 70%]Downloading daily.cvd [ 70%]Downloading daily.cvd [ 70%]Downloading daily.cvd [ 70%]Downloading daily.cvd [ 70%]Downloading daily.cvd [ 70%]Downloading daily.cvd [ 70%]Downloading daily.cvd [ 70%]Downloading daily.cvd [ 71%]Downloading daily.cvd [ 71%]Downloading daily.cvd [ 71%]Downloading daily.cvd [ 71%]Downloading daily.cvd [ 71%]Downloading daily.cvd [ 71%]Downloading daily.cvd [ 71%]Downloading daily.cvd [ 71%]Downloading daily.cvd [ 72%]Downloading daily.cvd [ 72%]Downloading daily.cvd [ 72%]Downloading daily.cvd [ 72%]Downloading daily.cvd [ 72%]Downloading daily.cvd [ 72%]Downloading daily.cvd [ 72%]Downloading daily.cvd [ 73%]Downloading daily.cvd [ 73%]Downloading daily.cvd [ 73%]Downloading daily.cvd [ 73%]Downloading daily.cvd [ 73%]Downloading daily.cvd [ 73%]Downloading daily.cvd [ 73%]Downloading daily.cvd [ 73%]Downloading daily.cvd [ 74%]Downloading daily.cvd [ 74%]Downloading daily.cvd [ 74%]Downloading daily.cvd [ 74%]Downloading daily.cvd [ 74%]Downloading daily.cvd [ 74%]Downloading daily.cvd [ 74%]Downloading daily.cvd [ 74%]Downloading daily.cvd [ 74%]Downloading daily.cvd [ 75%]Downloading daily.cvd [ 75%]Downloading daily.cvd [ 75%]Downloading daily.cvd [ 75%]Downloading daily.cvd [ 75%]Downloading daily.cvd [ 75%]Downloading daily.cvd [ 75%]Downloading daily.cvd [ 75%]Downloading daily.cvd [ 76%]Downloading daily.cvd [ 76%]Downloading daily.cvd [ 76%]Downloading daily.cvd [ 76%]Downloading daily.cvd [ 76%]Downloading daily.cvd [ 76%]Downloading daily.cvd [ 76%]Downloading daily.cvd [ 76%]Downloading daily.cvd [ 76%]Downloading daily.cvd [ 76%]Downloading daily.cvd [ 77%]Downloading daily.cvd [ 77%]Downloading daily.cvd [ 77%]Downloading daily.cvd [ 77%]Downloading daily.cvd [ 77%]Downloading daily.cvd [ 77%]Downloading daily.cvd [ 77%]Downloading daily.cvd [ 77%]Downloading daily.cvd [ 77%]Downloading daily.cvd [ 78%]Downloading daily.cvd [ 78%]Downloading daily.cvd [ 78%]Downloading daily.cvd [ 78%]Downloading daily.cvd [ 78%]Downloading daily.cvd [ 78%]Downloading daily.cvd [ 78%]Downloading daily.cvd [ 78%]Downloading daily.cvd [ 79%]Downloading daily.cvd [ 79%]Downloading daily.cvd [ 79%]Downloading daily.cvd [ 79%]Downloading daily.cvd [ 79%]Downloading daily.cvd [ 79%]Downloading daily.cvd [ 79%]Downloading daily.cvd [ 79%]Downloading daily.cvd [ 79%]Downloading daily.cvd [ 79%]Downloading daily.cvd [ 79%]Downloading daily.cvd [ 80%]Downloading daily.cvd [ 80%]Downloading daily.cvd [ 80%]Downloading daily.cvd [ 80%]Downloading daily.cvd [ 80%]Downloading daily.cvd [ 80%]Downloading daily.cvd [ 80%]Downloading daily.cvd [ 80%]Downloading daily.cvd [ 81%]Downloading daily.cvd [ 81%]Downloading daily.cvd [ 81%]Downloading daily.cvd [ 81%]Downloading daily.cvd [ 81%]Downloading daily.cvd [ 81%]Downloading daily.cvd [ 81%]Downloading daily.cvd [ 81%]Downloading daily.cvd [ 81%]Downloading daily.cvd [ 81%]Downloading daily.cvd [ 81%]Downloading daily.cvd [ 82%]Downloading daily.cvd [ 82%]Downloading daily.cvd [ 82%]Downloading daily.cvd [ 82%]Downloading daily.cvd [ 82%]Downloading daily.cvd [ 82%]Downloading daily.cvd [ 82%]Downloading daily.cvd [ 82%]Downloading daily.cvd [ 82%]Downloading daily.cvd [ 83%]Downloading daily.cvd [ 83%]Downloading daily.cvd [ 83%]Downloading daily.cvd [ 83%]Downloading daily.cvd [ 83%]Downloading daily.cvd [ 83%]Downloading daily.cvd [ 83%]Downloading daily.cvd [ 83%]Downloading daily.cvd [ 83%]Downloading daily.cvd [ 83%]Downloading daily.cvd [ 84%]Downloading daily.cvd [ 84%]Downloading daily.cvd [ 84%]Downloading daily.cvd [ 84%]Downloading daily.cvd [ 84%]Downloading daily.cvd [ 84%]Downloading daily.cvd [ 84%]Downloading daily.cvd [ 84%]Downloading daily.cvd [ 84%]Downloading daily.cvd [ 85%]Downloading daily.cvd [ 85%]Downloading daily.cvd [ 85%]Downloading daily.cvd [ 85%]Downloading daily.cvd [ 85%]Downloading daily.cvd [ 85%]Downloading daily.cvd [ 85%]Downloading daily.cvd [ 85%]Downloading daily.cvd [ 85%]Downloading daily.cvd [ 85%]Downloading daily.cvd [ 86%]Downloading daily.cvd [ 86%]Downloading daily.cvd [ 86%]Downloading daily.cvd [ 86%]Downloading daily.cvd [ 86%]Downloading daily.cvd [ 86%]Downloading daily.cvd [ 86%]Downloading daily.cvd [ 86%]Downloading daily.cvd [ 86%]Downloading daily.cvd [ 86%]Downloading daily.cvd [ 87%]Downloading daily.cvd [ 87%]Downloading daily.cvd [ 87%]Downloading daily.cvd [ 87%]Downloading daily.cvd [ 87%]Downloading daily.cvd [ 87%]Downloading daily.cvd [ 87%]Downloading daily.cvd [ 87%]Downloading daily.cvd [ 87%]Downloading daily.cvd [ 88%]Downloading daily.cvd [ 88%]Downloading daily.cvd [ 88%]Downloading daily.cvd [ 88%]Downloading daily.cvd [ 88%]Downloading daily.cvd [ 88%]Downloading daily.cvd [ 88%]Downloading daily.cvd [ 88%]Downloading daily.cvd [ 88%]Downloading daily.cvd [ 88%]Downloading daily.cvd [ 89%]Downloading daily.cvd [ 89%]Downloading daily.cvd [ 89%]Downloading daily.cvd [ 89%]Downloading daily.cvd [ 89%]Downloading daily.cvd [ 89%]Downloading daily.cvd [ 89%]Downloading daily.cvd [ 89%]Downloading daily.cvd [ 90%]Downloading daily.cvd [ 90%]Downloading daily.cvd [ 90%]Downloading daily.cvd [ 90%]Downloading daily.cvd [ 90%]Downloading daily.cvd [ 90%]Downloading daily.cvd [ 90%]Downloading daily.cvd [ 90%]Downloading daily.cvd [ 91%]Downloading daily.cvd [ 91%]Downloading daily.cvd [ 91%]Downloading daily.cvd [ 91%]Downloading daily.cvd [ 91%]Downloading daily.cvd [ 91%]Downloading daily.cvd [ 91%]Downloading daily.cvd [ 91%]Downloading daily.cvd [ 91%]Downloading daily.cvd [ 91%]Downloading daily.cvd [ 92%]Downloading daily.cvd [ 92%]Downloading daily.cvd [ 92%]Downloading daily.cvd [ 92%]Downloading daily.cvd [ 92%]Downloading daily.cvd [ 92%]Downloading daily.cvd [ 92%]Downloading daily.cvd [ 92%]Downloading daily.cvd [ 92%]Downloading daily.cvd [ 93%]Downloading daily.cvd [ 93%]Downloading daily.cvd [ 93%]Downloading daily.cvd [ 93%]Downloading daily.cvd [ 93%]Downloading daily.cvd [ 93%]Downloading daily.cvd [ 93%]Downloading daily.cvd [ 93%]Downloading daily.cvd [ 93%]Downloading daily.cvd [ 93%]Downloading daily.cvd [ 94%]Downloading daily.cvd [ 94%]Downloading daily.cvd [ 94%]Downloading daily.cvd [ 94%]Downloading daily.cvd [ 94%]Downloading daily.cvd [ 94%]Downloading daily.cvd [ 94%]Downloading daily.cvd [ 94%]Downloading daily.cvd [ 94%]Downloading daily.cvd [ 95%]Downloading daily.cvd [ 95%]Downloading daily.cvd [ 95%]Downloading daily.cvd [ 95%]Downloading daily.cvd [ 95%]Downloading daily.cvd [ 95%]Downloading daily.cvd [ 95%]Downloading daily.cvd [ 95%]Downloading daily.cvd [ 95%]Downloading daily.cvd [ 95%]Downloading daily.cvd [ 96%]Downloading daily.cvd [ 96%]Downloading daily.cvd [ 96%]Downloading daily.cvd [ 96%]Downloading daily.cvd [ 96%]Downloading daily.cvd [ 96%]Downloading daily.cvd [ 96%]Downloading daily.cvd [ 96%]Downloading daily.cvd [ 96%]Downloading daily.cvd [ 96%]Downloading daily.cvd [ 97%]Downloading daily.cvd [ 97%]Downloading daily.cvd [ 97%]Downloading daily.cvd [ 97%]Downloading daily.cvd [ 97%]Downloading daily.cvd [ 97%]Downloading daily.cvd [ 97%]Downloading daily.cvd [ 97%]Downloading daily.cvd [ 98%]Downloading daily.cvd [ 98%]Downloading daily.cvd [ 98%]Downloading daily.cvd [ 98%]Downloading daily.cvd [ 98%]Downloading daily.cvd [ 98%]Downloading daily.cvd [ 98%]Downloading daily.cvd [ 98%]Downloading daily.cvd [ 99%]Downloading daily.cvd [ 99%]Downloading daily.cvd [ 99%]Downloading daily.cvd [ 99%]Downloading daily.cvd [ 99%]Downloading daily.cvd [ 99%]Downloading daily.cvd [ 99%]Downloading daily.cvd [ 99%]Downloading daily.cvd [ 99%]Downloading daily.cvd [100%]Downloading daily.cvd [100%]
daily.cvd updated (version: 11056, sigs: 79250, f-level: 51, builder: ccordes)
DON’T PANIC! Read http://www.clamav.net/support/faq
Database updated (783977 signatures) from database.clamav.net (IP: 209.222.131.222)
Configuring Dovecot for POP3 and IMAP
Enabling Dovecot POP3 and IMAP servers
Enabling ProFTPd
Starting proftpd: [ OK ]
Enabling SMTP authentication
Starting saslauthd: [ OK ]
Configuring Virtualmin
Configuring Procmail
Configuring Webalizer
Updating /etc/shells
Enabling MySQL and PostgreSQL
Enabling Apache
Configuring and enabling BIND
Configuring resolv.conf to use local DNS server
Configuring and enabling Mailman
Enabling status monitoring
Hiding the Webmin upgrade page
Error occurred hiding Webmin upgrade page:
Configuring firewall rules
Allowing traffic on TCP port: ssh
Allowing traffic on TCP port: smtp
Allowing traffic on TCP port: domain
Allowing traffic on TCP port: ftp
Allowing traffic on TCP port: ftp-data
Allowing traffic on TCP port: pop3
Allowing traffic on TCP port: pop3s
Allowing traffic on TCP port: imap
Allowing traffic on TCP port: imaps
Allowing traffic on TCP port: http
Allowing traffic on TCP port: https
Allowing traffic on TCP port: 10000
Allowing traffic on TCP port: 20000
Allowing traffic on UDP port: domain
Allowing traffic on UDP port: ftp
Allowing traffic on UDP port: ftp-data
Re-checking supported Webmin modules
error: %post(virtualmin-base-1.0-61.rh.noarch) scriptlet failed, exit status 255
Installing : clamav-server-sysv 35/35
Installed:
virtualmin-base.noarch 0:1.0-61.rh
Dependency Installed:
awstats.noarch 0:6.8-1.el5
clamav.x86_64 0:0.95.2-1.vm.el5
clamav-data.x86_64 0:0.95.2-1.vm.el5
clamav-filesystem.x86_64 0:0.95.2-1.vm.el5
clamav-lib.x86_64 0:0.95.2-1.vm.el5
clamav-server.x86_64 0:0.95.2-1.vm.el5
clamav-server-sysv.x86_64 0:0.95.2-1.vm.el5
clamav-update.x86_64 0:0.95.2-1.vm.el5
cyrus-sasl-md5.x86_64 0:2.1.22-5.el5_4.3
cyrus-sasl-plain.x86_64 0:2.1.22-5.el5_4.3
fedora-usermgmt.noarch 0:0.9-1.el5
fedora-usermgmt-core.noarch 0:0.9-1.el5
fedora-usermgmt-default-fedora-setup.noarch 0:0.9-1.el5
fedora-usermgmt-shadow-utils.noarch 0:0.9-1.el5
mod_fcgid.x86_64 0:2.2-1.el5.vm
procmail-wrapper.x86_64 0:1.0-1.vm
proftpd.x86_64 0:1.3.0a-3el5
scponly.x86_64 0:4.6-1.vm
usermin.noarch 0:1.430-1
ust-virtual-server-theme.noarch 2:6.9-1
wbm-php-pear.noarch 2:1.5-1
wbm-ruby-gems.noarch 2:1.4-1
wbm-security-updates.noarch 2:4.0-1
wbm-virtual-server.noarch 0:3.78.gpl-1
wbm-virtualmin-awstats.noarch 2:4.3-1
wbm-virtualmin-dav.noarch 2:3.3-1
wbm-virtualmin-htpasswd.noarch 2:2.3-1
wbm-virtualmin-init.noarch 2:2.1-1
wbm-virtualmin-mailman.noarch 2:5.9-1
wbm-virtualmin-registrar.noarch 2:2.0-1
wbm-virtualmin-svn.noarch 2:4.7-1
wbt-virtual-server-mobile.noarch 2:2.3-1
wbt-virtual-server-theme.noarch 2:7.7-1
webmin.noarch 0:1.510-1
Complete!
FATAL - 2010-05-20 00:09:26 - Fatal Error Occurred: Installation failed: 0
FATAL - 2010-05-20 00:09:26 - Cannot continue installation.
FATAL - 2010-05-20 00:09:26 - Attempting to remove virtualmin repository configuration, so the installation can be
FATAL - 2010-05-20 00:09:26 - re-attempted after any problems have been resolved.
FATAL - 2010-05-20 00:09:27 - Removing temporary directory and files.
FATAL - 2010-05-20 00:09:27 - If you are unsure of what went wrong, you may wish to review the log
FATAL - 2010-05-20 00:09:27 - in /root/virtualmin-install.log
