Ubuntu 20
I installed my sites in a VM. Got wordpress up and running then just tried getting SSL’s working. www.peterboroughbusinesstechnology.co.uk www.alicetunnicliffe.co.uk
both my sites come up with the same error ERR_SSL_PROTOCOL_ERROR
I installed let’s encrypt SSL’s with webmin for both.
I tried to post the apache2.conf ssl.conf but the forum won’t allow as limited links needed.
I’m thinking is a global setting as its affect more than one domain, has anyone got any ideas?
# Pseudo Random Number Generator (PRNG):
# Configure one or more sources to seed the PRNG of the SSL library.
# The seed data should be of good random quality.
# WARNING! On some platforms /dev/random blocks if not enough entropy
# is available. This means you then cannot use the /dev/random device
# because it would lead to very long connection times (as long as
# it requires to make more entropy available). But usually those
# platforms additionally provide a /dev/urandom device which doesn't
# block. So, if available, use this one instead. Read the mod_ssl User
# Manual for more details.
SSLRandomSeed startup builtin
SSLRandomSeed startup file:/dev/urandom 512
SSLRandomSeed connect builtin
SSLRandomSeed connect file:/dev/urandom 512
## SSL Global Context
## All SSL configuration in this context applies both to
## the main server and all SSL-enabled virtual hosts.
# Some MIME-types for downloading Certificates and CRLs
AddType application/x-x509-ca-cert .crt
AddType application/x-pkcs7-crl .crl
# Pass Phrase Dialog:
# Configure the pass phrase gathering process.
# The filtering dialog program (`builtin' is a internal
# terminal dialog) has to provide the pass phrase on stdout.
# Inter-Process Session Cache:
# Configure the SSL Session Cache: First the mechanism
# to use and second the expiring timeout (in seconds).
# (The mechanism dbm has known memory leaks and should not be used).
#SSLSessionCache dbm:${APACHE_RUN_DIR}/ssl_scache
SSLSessionCache shmcb:${APACHE_RUN_DIR}/ssl_scache(512000)
SSLSessionCacheTimeout 300
# Semaphore:
# Configure the path to the mutual exclusion semaphore the
# SSL engine uses internally for inter-process synchronization.
# (Disabled by default, the global Mutex directive consolidates by default
# this)
#Mutex file:${APACHE_LOCK_DIR}/ssl_mutex ssl-cache
# SSL Cipher Suite:
# List the ciphers that the client is permitted to negotiate. See the
# ciphers(1) man page from the openssl package for list of all available
# options.
# Enable only secure ciphers:
SSLCipherSuite HIGH:!aNULL
# SSL server cipher order preference:
# Use server priorities for cipher algorithm choice.
# Clients may prefer lower grade encryption. You should enable this
# option if you want to enforce stronger encryption, and can afford
# the CPU cost, and did not override SSLCipherSuite in a way that puts
# insecure ciphers first.
# Default: Off
#SSLHonorCipherOrder on
# The protocols to enable.
# Available values: all, SSLv3, TLSv1, TLSv1.1, TLSv1.2
# SSL v2 is no longer supported
SSLProtocol all -SSLv3
# Allow insecure renegotiation with clients which do not yet support the
# secure renegotiation protocol. Default: Off
#SSLInsecureRenegotiation on
# Whether to forbid non-SNI clients to access name based virtual hosts.
# Default: Off
#SSLStrictSNIVHostCheck On
I do have separate lets encrypt certs per domain. However I still get the same error across multiple domains. Which is what makes me think its a general server setup issue perhaps in ssl.conf. Rather than a local issue on each domain.
