Yes, i did. No errors reported.
I also ran a test with Ubuntu 22.04 on Hetzner: I rebuilt the VPS with Ubuntu 22.04 and installed Virtualmin. In this case, the repositories page correctly shows the Ubuntu 22.04 repositories. The Virtualmin repositories are not visible.
I would love to try hetzners cheaper ipv6 only boxes. But it is 2024 and Virtualmin repo is still IPv4 only.
(which is very strange because virtualmin itself has ipv6 support well implemented).
I have the same issue with Ubuntu 24.04 as well. I figured they will notice it in due time.
Are you using Hetzner?
I believe it has nothing to do with the hosting company. If there are any questions, write to their support and you will receive the necessary clarifications.
No, I have tested this on other platforms such as OVH and Vultr with same results.
I thought perhaps it was from a cloud repositories but when testing on a server in the office with a minimal iso I get the same results.
Everything else seems to work fine though aside from the repositories not showing.
For me, it’s the same thing. The repositories are not visible, but everything seems to be working fine. However, for now, I have switched to 22.04 LTS. On 22.04, the Ubuntu repositories are visible, but not the Virtualmin ones.
Same here, I guess it’s an Ubuntu thing.
Yes, this behavior is a known bug in Authentic theme and fixed in the next Webmin version, AFAIK.
