Emails not sending or receiving in roundcube
Virtualmin version 7.1
I have set up Roundcube. While Roundcube says emails are sent successfully, users do not receive them. Furthermore, I cannot receive any emails sent to my inbox as well.
This is the mail log I see. Anything I can do to fix it?
Thanks!
Sep 15 18:09:09 centos dovecot: imap-login: Login: user=<booya-neutralscents.com>, method=PLAIN, rip=::1, lip=::1, mpid=23043, secured, session=
Sep 15 18:09:09 centos dovecot: imap(booya-neutralscents.com): Logged out in=44 out=612
Sep 15 18:09:10 centos dovecot: imap-login: Login: user=<booya-neutralscents.com>, method=PLAIN, rip=::1, lip=::1, mpid=23045, secured, session=<5cBgJLvojNQAAAAAAAAAAAAAAAAAAAAB>
Sep 15 18:09:10 centos dovecot: imap(booya-neutralscents.com): Logged out in=290 out=4463
Sep 15 18:09:11 centos dovecot: imap-login: Login: user=<booya-neutralscents.com>, method=PLAIN, rip=::1, lip=::1, mpid=23048, secured, session=
Sep 15 18:09:11 centos dovecot: imap(booya-neutralscents.com): Logged out in=119 out=785
Sep 15 18:09:33 centos postfix/smtpd[22174]: connect from unknown[103.153.78.37]
Sep 15 18:09:33 centos postfix/smtpd[22174]: warning: Wrapper-mode request dropped from unknown[103.153.78.37] for service smtps. TLS context initialization failed. For details see earlier warnings in your logs.
Sep 15 18:09:33 centos postfix/smtpd[22174]: disconnect from unknown[103.153.78.37]
Sep 15 18:09:38 centos postfix/smtp[23038]: connect to gmail-smtp-in.l.google.com[172.253.115.26]:25: Connection timed out
Sep 15 18:09:38 centos postfix/smtp[23038]: connect to alt1.gmail-smtp-in.l.google.com[2a00:1450:400b:c00::1b]:25: Network is unreachable
Sep 15 18:10:01 centos dovecot: imap-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=162.142.125.221, lip=104.248.59.242, TLS: Disconnected, session=<4GlvJ7vovK+ijn3d>
Sep 15 18:10:08 centos postfix/smtpd[22174]: connect from unknown[103.153.78.37]
Sep 15 18:10:08 centos postfix/smtpd[22174]: warning: Wrapper-mode request dropped from unknown[103.153.78.37] for service smtps. TLS context initialization failed. For details see earlier warnings in your logs.
Sep 15 18:10:08 centos postfix/smtpd[22174]: disconnect from unknown[103.153.78.37]
Sep 15 18:10:08 centos postfix/smtp[23038]: connect to alt1.gmail-smtp-in.l.google.com[209.85.202.27]:25: Connection timed out
Sep 15 18:10:11 centos dovecot: imap-login: Login: user=<booya-neutralscents.com>, method=PLAIN, rip=::1, lip=::1, mpid=23415, secured, session=
Sep 15 18:10:11 centos dovecot: imap(booya-neutralscents.com): Logged out in=126 out=1007
Sep 15 18:10:38 centos postfix/smtp[23038]: connect to alt2.gmail-smtp-in.l.google.com[64.233.184.26]:25: Connection timed out
Sep 15 18:10:38 centos postfix/smtp[23038]: AF801CB7B5: to=ken212@gmail.com, relay=none, delay=90, delays=0.06/0.04/90/0, dsn=4.4.1, status=deferred (connect to alt2.gmail-smtp-in.l.google.com[64.233.184.26]:25: Connection timed out)
Sep 15 18:10:56 centos postfix/qmgr[1567]: 9895CC6B02: from=booya@neutralscents.com, size=607, nrcpt=1 (queue active)
Sep 15 18:11:11 centos dovecot: imap-login: Login: user=<booya-neutralscents.com>, method=PLAIN, rip=::1, lip=::1, mpid=23660, secured, session=
Sep 15 18:11:11 centos dovecot: imap(booya-neutralscents.com): Logged out in=126 out=1007
Sep 15 18:11:22 centos postfix/smtpd[22174]: connect from unknown[103.153.78.37]
Sep 15 18:11:22 centos postfix/smtpd[22174]: warning: Wrapper-mode request dropped from unknown[103.153.78.37] for service smtps. TLS context initialization failed. For details see earlier warnings in your logs.
Sep 15 18:11:22 centos postfix/smtpd[22174]: disconnect from unknown[103.153.78.37]
Sep 15 18:11:27 centos postfix/smtp[23038]: connect to reception.mail-tester.com[94.23.206.89]:25: Connection timed out
Sep 15 18:11:27 centos postfix/smtp[23038]: 9895CC6B02: to=test-pvs54lpkb@srv1.mail-tester.com, relay=none, delay=640, delays=609/0.01/30/0, dsn=4.4.1, status=deferred (connect to reception.mail-tester.com[94.23.206.89]:25: Connection timed out)
Sep 15 18:11:39 centos dovecot: imap-login: Login: user=<booya-neutralscents.com>, method=PLAIN, rip=::1, lip=::1, mpid=23769, secured, session=<8xBDLbvonNQAAAAAAAAAAAAAAAAAAAAB>
Sep 15 18:11:39 centos dovecot: imap(booya-neutralscents.com): Logged out in=32 out=510
Sep 15 18:11:39 centos dovecot: imap-login: Login: user=<booya-neutralscents.com>, method=PLAIN, rip=::1, lip=::1, mpid=23771, secured, session=
Sep 15 18:11:39 centos dovecot: imap(booya-neutralscents.com): Logged out in=44 out=612
Sep 15 18:11:49 centos postfix/smtpd[23791]: warning: No server certs available. TLS won’t be enabled
Sep 15 18:11:49 centos postfix/smtpd[23791]: connect from centos.neutralscents.com[::1]
Sep 15 18:11:49 centos postfix/smtpd[23791]: 721FCB61A2: client=centos.neutralscents.com[::1]
Sep 15 18:11:49 centos postfix/cleanup[23793]: 721FCB61A2: message-id=b02b8c5455fbeb87ee00e26bc3e285dd@neutralscents.com
Sep 15 18:11:49 centos postfix/qmgr[1567]: 721FCB61A2: from=booya@neutralscents.com, size=640, nrcpt=1 (queue active)
Sep 15 18:11:49 centos postfix/smtpd[23791]: disconnect from centos.neutralscents.com[::1]
Sep 15 18:11:49 centos dovecot: imap-login: Login: user=<booya-neutralscents.com>, method=PLAIN, rip=::1, lip=::1, mpid=23795, secured, session=<gt/cLbvopNQAAAAAAAAAAAAAAAAAAAAB>
Sep 15 18:11:49 centos dovecot: imap(booya-neutralscents.com): Logged out in=506 out=679
Sep 15 18:11:50 centos dovecot: imap-login: Login: user=<booya-neutralscents.com>, method=PLAIN, rip=::1, lip=::1, mpid=23800, secured, session=
Sep 15 18:11:50 centos dovecot: imap(booya-neutralscents.com): Logged out in=44 out=612
Sep 15 18:11:51 centos dovecot: imap-login: Login: user=<booya-neutralscents.com>, method=PLAIN, rip=::1, lip=::1, mpid=23802, secured, session=
Sep 15 18:11:51 centos dovecot: imap(booya-neutralscents.com): Logged out in=290 out=4914
Sep 15 18:11:51 centos dovecot: imap-login: Login: user=<booya-neutralscents.com>, method=PLAIN, rip=::1, lip=::1, mpid=23804, secured, session=
Sep 15 18:11:51 centos dovecot: imap(booya-neutralscents.com): Logged out in=119 out=785
Sep 15 18:11:55 centos postfix/smtpd[22174]: connect from unknown[103.153.78.37]
Sep 15 18:11:55 centos postfix/smtpd[22174]: warning: Wrapper-mode request dropped from unknown[103.153.78.37] for service smtps. TLS context initialization failed. For details see earlier warnings in your logs.
Sep 15 18:11:55 centos postfix/smtpd[22174]: disconnect from unknown[103.153.78.37]
Sep 15 18:12:19 centos postfix/smtp[23038]: connect to reception.mail-tester.com[94.23.206.89]:25: Connection timed out
Sep 15 18:12:19 centos postfix/smtp[23038]: 721FCB61A2: to=test-frxchum5f@srv1.mail-tester.com, relay=none, delay=30, delays=0.05/0/30/0, dsn=4.4.1, status=deferred (connect to reception.mail-tester.com[94.23.206.89]:25: Connection timed out)
Sep 15 18:12:52 centos dovecot: imap-login: Login: user=<booya-neutralscents.com>, method=PLAIN, rip=::1, lip=::1, mpid=24095, secured, session=
Sep 15 18:12:52 centos dovecot: imap(booya-neutralscents.com): Logged out in=126 out=1009
Sep 15 18:12:55 centos postfix/smtpd[22174]: connect from unknown[103.153.78.37]
Sep 15 18:12:55 centos postfix/smtpd[22174]: warning: Wrapper-mode request dropped from unknown[103.153.78.37] for service smtps. TLS context initialization failed. For details see earlier warnings in your logs.
Sep 15 18:12:55 centos postfix/smtpd[22174]: disconnect from unknown[103.153.78.37]
Sep 15 18:13:43 centos postfix/smtpd[22174]: connect from unknown[103.153.78.37]
Sep 15 18:13:43 centos postfix/smtpd[22174]: warning: Wrapper-mode request dropped from unknown[103.153.78.37] for service smtps. TLS context initialization failed. For details see earlier warnings in your logs.
Sep 15 18:13:43 centos postfix/smtpd[22174]: disconnect from unknown[103.153.78.37]
Sep 15 18:13:51 centos postfix/smtpd[22174]: connect from unknown[103.153.78.37]
Sep 15 18:13:51 centos postfix/smtpd[22174]: warning: Wrapper-mode request dropped from unknown[103.153.78.37] for service smtps. TLS context initialization failed. For details see earlier warnings in your logs.
Sep 15 18:13:51 centos postfix/smtpd[22174]: disconnect from unknown[103.153.78.37]
Sep 15 18:13:52 centos dovecot: imap-login: Login: user=<booya-neutralscents.com>, method=PLAIN, rip=::1, lip=::1, mpid=24253, secured, session=<058uNbvosNQAAAAAAAAAAAAAAAAAAAAB>
Sep 15 18:13:52 centos dovecot: imap(booya-neutralscents.com): Logged out in=126 out=1009
Sep 15 18:14:26 centos postfix/smtpd[22174]: connect from unknown[103.153.78.37]
Sep 15 18:14:26 centos postfix/smtpd[22174]: warning: Wrapper-mode request dropped from unknown[103.153.78.37] for service smtps. TLS context initialization failed. For details see earlier warnings in your logs.
Sep 15 18:14:26 centos postfix/smtpd[22174]: disconnect from unknown[103.153.78.37]
Sep 15 18:14:26 centos postfix/smtpd[22174]: connect from 45-33-81-208.ip.linodeusercontent.com[45.33.81.208]
Sep 15 18:14:26 centos postfix/smtpd[22174]: warning: Wrapper-mode request dropped from 45-33-81-208.ip.linodeusercontent.com[45.33.81.208] for service smtps. TLS context initialization failed. For details see earlier warnings in your logs.
Sep 15 18:14:26 centos postfix/smtpd[22174]: disconnect from 45-33-81-208.ip.linodeusercontent.com[45.33.81.208]
Sep 15 18:14:52 centos dovecot: imap-login: Login: user=<booya-neutralscents.com>, method=PLAIN, rip=::1, lip=::1, mpid=24328, secured, session=
Sep 15 18:14:52 centos dovecot: imap(booya-neutralscents.com): Logged out in=126 out=1009
Sep 15 18:14:58 centos postfix/smtpd[22174]: connect from unknown[103.153.78.37]
Sep 15 18:14:58 centos postfix/smtpd[22174]: warning: Wrapper-mode request dropped from unknown[103.153.78.37] for service smtps. TLS context initialization failed. For details see earlier warnings in your logs.
Sep 15 18:14:58 centos postfix/smtpd[22174]: disconnect from unknown[103.153.78.37]
Sep 15 18:15:35 centos postfix/smtpd[22174]: connect from unknown[103.153.78.37]
Sep 15 18:15:35 centos postfix/smtpd[22174]: warning: Wrapper-mode request dropped from unknown[103.153.78.37] for service smtps. TLS context initialization failed. For details see earlier warnings in your logs.
Sep 15 18:15:35 centos postfix/smtpd[22174]: disconnect from unknown[103.153.78.37]
Sep 15 18:15:52 centos dovecot: imap-login: Login: user=<booya-neutralscents.com>, method=PLAIN, rip=::1, lip=::1, mpid=24588, secured, session=
Sep 15 18:15:52 centos dovecot: imap(booya-neutralscents.com): Logged out in=126 out=1009
Sep 15 18:15:56 centos postfix/qmgr[1567]: 01FDAC6A32: from=booya@neutralscents.com, size=578, nrcpt=1 (queue active)
Sep 15 18:15:56 centos postfix/qmgr[1567]: AF801CB7B5: from=booya@neutralscents.com, size=591, nrcpt=1 (queue active)
Sep 15 18:15:56 centos postfix/smtp[24605]: connect to gmail-smtp-in.l.google.com[2607:f8b0:4004:c06::1b]:25: Network is unreachable
Sep 15 18:16:26 centos postfix/smtp[24604]: connect to gmail-smtp-in.l.google.com[172.253.115.27]:25: Connection timed out
Sep 15 18:16:26 centos postfix/smtp[24604]: connect to gmail-smtp-in.l.google.com[2607:f8b0:4004:c06::1b]:25: Network is unreachable
Sep 15 18:16:26 centos postfix/smtp[24605]: connect to gmail-smtp-in.l.google.com[172.253.115.27]:25: Connection timed out
Sep 15 18:16:35 centos postfix/smtpd[22174]: connect from unknown[103.153.78.37]
Sep 15 18:16:35 centos postfix/smtpd[22174]: warning: Wrapper-mode request dropped from unknown[103.153.78.37] for service smtps. TLS context initialization failed. For details see earlier warnings in your logs.
Sep 15 18:16:35 centos postfix/smtpd[22174]: disconnect from unknown[103.153.78.37]
Sep 15 18:16:52 centos dovecot: imap-login: Login: user=<booya-neutralscents.com>, method=PLAIN, rip=::1, lip=::1, mpid=24799, secured, session=
Sep 15 18:16:52 centos dovecot: imap(booya-neutralscents.com): Logged out in=126 out=1009
Sep 15 18:16:56 centos postfix/smtp[24604]: connect to alt1.gmail-smtp-in.l.google.com[209.85.202.27]:25: Connection timed out
Sep 15 18:16:56 centos postfix/smtp[24604]: connect to alt1.gmail-smtp-in.l.google.com[2a00:1450:400b:c00::1b]:25: Network is unreachable
Sep 15 18:16:56 centos postfix/smtp[24604]: connect to alt2.gmail-smtp-in.l.google.com[2a00:1450:400c:c0b::1a]:25: Network is unreachable
Sep 15 18:16:56 centos postfix/smtp[24605]: connect to alt1.gmail-smtp-in.l.google.com[209.85.202.27]:25: Connection timed out
Sep 15 18:16:56 centos postfix/smtp[24605]: connect to alt1.gmail-smtp-in.l.google.com[2a00:1450:400b:c00::1b]:25: Network is unreachable
Sep 15 18:16:56 centos postfix/smtp[24604]: 01FDAC6A32: to=ken212@gmail.com, relay=none, delay=1054, delays=993/0.03/60/0, dsn=4.4.1, status=deferred (connect to alt2.gmail-smtp-in.l.google.com[2a00:1450:400c:c0b::1a]:25: Network is unreachable)
Sep 15 18:17:14 centos postfix/smtpd[22174]: connect from unknown[103.153.78.37]
Sep 15 18:17:14 centos postfix/smtpd[22174]: warning: Wrapper-mode request dropped from unknown[103.153.78.37] for service smtps. TLS context initialization failed. For details see earlier warnings in your logs.
Sep 15 18:17:14 centos postfix/smtpd[22174]: disconnect from unknown[103.153.78.37]Sep 15 18:09:09 centos dovecot: imap-login: Login: user=<booya-neutralscents.com>, method=PLAIN, rip=::1, lip=::1, mpid=23043, secured, session=
Blockquote
I see alot of timeout, log on to server and do some ping tests. I suspect the gateway address. Trace route tests as well to see where its timing out.
@dundiebear,
I see at least one deferred status in your logs. There could be a problem with your setup.
*** Screen sharing, interactive, professional, affordable support https://tpnassist.com ***
Connections timing out on outgoing… sure you have port 25 open?
