Emails not being scanned by SpamAssassin
OS type and version AlmaLinux 8.8
Webmin version 2.101
Usermin version 2.001
Virtualmin version 7.7
Theme version 21.04
Recently i’ve being getting a lot of spam ending in my inbox, i set it up to go to ./junk folder, cheking the headers i cant find X-Spam in them:
|**Return-Path:**|<redacted@gmail.com>| | --- | --- | |**X-Original-To:**|vitor@redacted.com.br| |**Delivered-To:**|vitor-redacted.com.br@redacted.com.br| |**Received:**|from mail-yw1-f182.google.com (mail-yw1-f182.google.com [209.85.128.182]) by redacted.com.br (Postfix) with ESMTPS id 9F709439CC for <vitor@redacted.com.br>; Fri, 18 Aug 2023 16:30:36 -0300 (-03)| |**DKIM-Filter:**|OpenDKIM Filter v2.11.0 redacted.com.br 9F709439CC| |**Authentication-Results:**|redacted.com.br; dkim=pass (2048-bit key, unprotected) header.d=gmail.com header.i=@gmail.com header.a=rsa-sha256 header.s=20221208 header.b=UHHT0yvi| |**Received:**|by mail-yw1-f182.google.com with SMTP id 00721157ae682-58c4dce9db8so13079847b3.1 for <vitor@redacted.com.br>; Fri, 18 Aug 2023 12:30:36 -0700 (PDT)| |**DKIM-Signature:**|v=1; a=rsa-sha256; c=relaxed/relaxed; d=gmail.com; s=20221208; t=1692387035; x=1692991835; h=to:subject:message-id:date:from:mime-version:from:to:cc:subject :date:message-id:reply-to; bh=7pdo6aZgybY4FMQk7D4ItNLKwpgIBHG7VfyzugQgeZI=; b=UHHT0yvilaj6Cs7NjFM/28s7qpd33XboXvaoTeXnAbD7mt4mcBppVawv7VsarM/8qN OHvYaOlfcYCG/WoH7Yt1J3dHUn+YEBSXhxjUCbWLrglgISxpVsjJLaIuE9GgO3XFx3wv kZVjUngNAYHUoi0DAgQXtuG/Ow7xpdw/EuZC/No/nmZXSrsyPeEZn6BtnDZftEEghahU eU+pO1pKBUrHRQdRah10LbKzJRhx/bpFOHCybKAycdZ84B8BRk4D2jttTj4av2hjhzcd xlWG9ETu9OkjwFsF1ccQAQtzzjqg1Bsmno52Mh2WtdfKEkGkKQe1/NHidsMYqGErEd/W 9fog==| |**X-Google-DKIM-Signature:**|v=1; a=rsa-sha256; c=relaxed/relaxed; d=1e100.net; s=20221208; t=1692387035; x=1692991835; h=to:subject:message-id:date:from:mime-version:x-gm-message-state :from:to:cc:subject:date:message-id:reply-to; bh=7pdo6aZgybY4FMQk7D4ItNLKwpgIBHG7VfyzugQgeZI=; b=TipxTGLVmIUAO/INhW/TKlzIVSlmMWBZdF7Mucuffky+vUrBhK2s8A2YbFEGJacIjK ShTQAU4Ek0fXqnKEN/6aob3m+bcn/as4k4dK0+DRWAkmnTBCRGgAfClLwSu40c7lkyY7 mdjujIc42ZQ3uWFtU0Wz3e0r/vIppMMLfwSj2QfOJ4Nl+bC33qS6wvZBgQhE/1zDkQXb FYTyHNhiaYari4IzR0u1uM4eXVxJ1ShXW2q40TlQbqkOHExrcLjRgTUXNJqbchJl37tH WgpspMw3hBDt+3pSwI4h+E1lFwdLKhWIHVG7Hh5V8uUToRXhe25C/Ipu8Pru6vRnXXS1 iPJg==| |**X-Gm-Message-State:**|AOJu0Yygthd9dzleBFETPoBqdz4Ed86gd1Zv9KYhLCP4sSS9nDfDPD3K 4ydfRKcrtiZDzbLu3FVXUZ0eo3620YDjfTLIPSqeMt2uIKMXqA==| |**X-Google-Smtp-Source:**|AGHT+IE0xabxw7asPSS+xqySog1UGNwndO9iJc2LRWN8X9iqcE16ZBcAIOLtRXAe+Ncjs57736U68/ZlsWOMfY6Yzfs=| |**X-Received:**|by 2002:a0d:df82:0:b0:583:c105:8501 with SMTP id i124-20020a0ddf82000000b00583c1058501mr127465ywe.42.1692387034797; Fri, 18 Aug 2023 12:30:34 -0700 (PDT)| |**MIME-Version:**|1.0| |**From:**|Vitor Hugo <redacted@gmail.com>| |**Date:**|Fri, 18 Aug 2023 16:28:56 -0300| |**Message-ID:**|<CAMab-GemswEh26Ey1BuUh7PJ7-fPG43ssU89eCcpJQ6q3nHDyw@mail.gmail.com>| |**Subject:**|teste spam| |**To:**|vitor@redacted.com.br| |**Content-Type:**|multipart/alternative; boundary="000000000000081d5806033790ce"|
When checking /var/log/procmail.log file i see the following errors when messages arrive:
procmail: Rescue of unfiltered data succeeded procmail: Program failure (78) of "/bin/spamc" Line not terminated with a newline in /etc/mail/spamassassin/spamc.conf ERROR: Could not connect to clamd on LocalSocket /run/clamd.scan/clamd.sock: Permission denied
The file /etc/mail/spamassassin/spamc.conf only has:
-d 127.0.0.1
spamd child and lookup-domain are running:
Any ideias where to go from here?
Edit: I’ve found this in the old forum that has the same log error except my mails dont get stuck in mailq so the problem is different: Postifx hold mail in mailq for a long time | Virtualmin
Seems like you have a broken spamc.conf so spamd isn’t running.
i’ve edited the spamc.conf file to the:
# connect to "server.example.com", port 783
    -d 127.0.0.1
    -p 783
    # max message size for scanning = 350k
    -s 350000
from https://spamassassin.apache.org/full/3.4.x/doc/spamc.html
now the
doesnt show anymore but i still get:
The owner of clamd.sock is clamscan:clamscan permission 0666 and it has 0 bytes changed the folder permission to 0755 and the error is gone.
Solved it, the headers showed up and all the errors are gone:
X-Spam-Checker-Version: 	SpamAssassin 3.4.6 (2021-04-09) on redacted.com.br
X-Spam-Level:
X-Spam-Status: 	No, score=-1.1 required=5.0 tests=BAYES_00,DKIM_SIGNED, DKIM_VALID,DKIM_VALID_AU,DKIM_VALID_EF,FORGED_HOTMAIL_RCVD2, FREEMAIL_FROM,HTML_MESSAGE,MIME_HTML_MOSTLY,RCVD_IN_DNSWL_NONE, RCVD_IN_MSPIKE_H2,SPF_HELO_PASS,SPF_PASS,TVD_SPACE_RATIO autolearn=no autolearn_force=no version=3.4.6
